    40 Posts 17 Posters 26.7k Views 2 Watching
      @Gerfesson-Alves-de-Oliveira, nice job!
      I hope you do a youtube video showing it off.
      • Andoni CantónA Offline
        Andoni Cantón
          Russ @Andoni Cantón
          space
          Dim Wsh
          Wsh.SendKeys " "
          wscript c:\scripts\space.vbs
          • TriboT Offline
            Tribo @Russ
            I added:
            Send("{DOWN}")
            Send("{DOWN}")
            Send("{ENTER}")
              Russ @Tribo
              • Arthur NeufeldA Offline
                Arthur Neufeld
                I created a vbs file with
                Dim Wsh
                Wsh.SendKeys "{F7}"
                in it. Safed it at
                c:\scripts\key.vbs
                wscript c:\scripts\key.vbs
                What did I do wrong?
                Cheers
                Arthur
                  Russ @Arthur Neufeld
                  Mine looks like this:
                  • XanderX Offline
                    Xander
                      Arthur Neufeld @Russ
                      @Russ Hi Russ, no unfortunately it doesn't rund the command from a cmd prompt. This happens if I copy and paste it in cmd:
                      https://www.dropbox.com/s/se4b59gxgk43su2/Screenshot 2021-01-26 19.25.19.png?dl=0
                      The command looks exactly like yours:
                      https://www.dropbox.com/s/a1b2parwrkjf848/Screenshot 2021-01-26 19.20.48.png?dl=0
                      The F7 Button is a Hotkey for a Streaming Software called OBS to change the Scene. Does that matter?
                      Thanks for your help already
                        @Arthur-Neufeld, I'm glad you mentioned OBS. I had no luck using wscript to send hot keys to OBS, so I made this post where I made two AutoIT .exe files - one for start recording, and one for stop recording, but you could use them for start and stop streaming too.
                        I use them and it works great.
                        • Antonio LeañosA Offline
                          Antonio Leaños
                          Hey I used this and it works just fine, but I want to use the start /wait timeout command to give some space in between a couple key presses but it just ignores them and say "access denied" does anyone know why is that?
                            Russ @Antonio Leaños
                            @Antonio-Leaños, when I tried a command like this, it worked for me.
                            start /min /wait timeout 5 & calc
                            It waited 5 seconds, then ran calculator.
                            Does that work for you? If not, can you tell me what command you're trying?
                            • Teo castrejon escamillaT Offline
                              Teo castrejon escamilla @Russ
                              @russ said in Press the Down Arrow key (or any other key):
                              does it work on mac?
                                Russ @Teo castrejon escamilla
                                @teo-castrejon-escamilla , no. On Mac you could use applescript.
                                https://apple.stackexchange.com/questions/36943/how-do-i-automate-a-key-press-in-applescript
                                • R Offline
                                  raquel @Russ
                                  @russ Would it be possible to press FN key? Cant find information about it, since its not a key present in every keyboard, but mine actually have 2 FN keys and most of my shortcuts needs both of them to be pressed on first. Any thoughts?
                                  • Marcos IbarraM Offline
                                    Marcos Ibarra
                                    Hello, i just have one question, i made an script with AutoIT to trigger some hotkeys like ALT+NUMPAD1, but sometimes is working and sometimes dont, and i can see the script running in windows processes, What could be happening or what im doing wrong? i tried different ways to define the same action like winactive in first line, and using sleep command thinking maybe than is too fast, i let you screenshots, hoping you can help me guys, thanks. Captura de pantalla (82).png Captura de pantalla (84).png
                                      Russ @Marcos Ibarra
                                      @marcos-ibarra , check out this post. I did what you seem to be doing with OBS here:
                                      https://www.triggercmd.com/forum/topic/1063/start-and-stop-obs-recording-or-streaming?_=1659268705659
                                      Marcos IbarraM 1 Reply Last reply Reply Quote 0
                                        Marcos Ibarra @Russ
                                        @russ Thanks! the hotkeys works, but i still having problems when i trigger the script, i think the script is the problem , because i use obs Lioranboard and triggercmd to change source visibility in my obs thorugh my voice, lioranboard is like a streamdeck, so i acitive buttons thorugh hotkeys than change sources visibility in my obs and i trigger the hot key from the script and sometimes works and sometimes dont, when i use the hotkye directly from my keyboard works all the time, i dont know what is happening. dont worry thanks for your help i will trigger my deck from ifttt and use triggercmd to run anything else, thanks Russ, ill be here, learning more about it. Captura de pantalla (85).png
                                        • A Offline
                                          aaaaa12345 @Marcos Ibarra
                                          @marcos-ibarra
                                          I'm not into AU3 that much (while knowing AHK better), what about triggering OBS's Control(s) directly, instead of Send(ing) a key in a less reliable way?
                                          https://www.autoitscript.com/autoit3/docs/functions/ControlCommand.htm
                                          That way the window wouldn't even have to be active, only existing!
                                          • A aaaaa12345 referenced this topic on
