    40 Posts 17 Posters 28.3k Views 2 Watching
    • Gerfesson Alves de OliveiraG Offline
      How could I press windows key + "P" so I can open up the projection options?
        Gerfesson Alves de OliveiraG TriboT 2 Replies Last reply Reply Quote 0
          Gerfesson Alves de Oliveira @Russ
          @Russ , I found a way thru your guidence!! Thanks a lot!
          The whole au3 document was this:
          sleep (500)
          Send("{UP}") ; Presses Up arrow
          Send("{ENTER}") ; Presses Enter
          sleep(500)
          ShellExecute("C:\Users\nosse\AppData\Local\Programs\Opera GX\launcher.exe")
          ShellExecute("https://www.primevideo.com")
          ShellExecute("https://www.netflix.com")
          sleep (2000)
          Send("^{TAB}") ; Presses Shift + Tab
          Send("{CTRLDOWN}") ; Holds the CTRL key down
          Send("{w}") ; Presses the w key
          Send("{CTRLUP}") ; Releases the CTRL key
          sleep (300)
          Send("{SHIFTDOWN}") ; Holds the Left Shift key down
          Send("{RIGHT}") ; Presses Right arrow
          Send("{SHIFTUP}") ; Releases the Shift key
          With this code I change the screen mode to extend the for my projector, open up a new opera window with netflix and prime video, close the opera's welcome window and finally put this new openned window to the second screen!
          Now I'm going to do the reverse engineering! Thanks a lot once again
            @Gerfesson-Alves-de-Oliveira, nice job!
            I hope you do a youtube video showing it off.
            • Andoni CantónA Offline
              Andoni Cantón
                Russ @Andoni Cantón
                space
                Dim Wsh
                Wsh.SendKeys " "
                wscript c:\scripts\space.vbs
                • TriboT Offline
                  Tribo @Russ
                  I added:
                  Send("{DOWN}")
                  Send("{DOWN}")
                  Send("{ENTER}")
                    Russ @Tribo
                    • Arthur NeufeldA Offline
                      Arthur Neufeld
                      I created a vbs file with
                      Dim Wsh
                      Wsh.SendKeys "{F7}"
                      in it. Safed it at
                      c:\scripts\key.vbs
                      wscript c:\scripts\key.vbs
                      What did I do wrong?
                      Cheers
                      Arthur
                        Russ @Arthur Neufeld
                        Mine looks like this:
                        • XanderX Offline
                          Xander
                            Arthur Neufeld @Russ
                            @Russ Hi Russ, no unfortunately it doesn't rund the command from a cmd prompt. This happens if I copy and paste it in cmd:
                            https://www.dropbox.com/s/se4b59gxgk43su2/Screenshot 2021-01-26 19.25.19.png?dl=0
                            The command looks exactly like yours:
                            https://www.dropbox.com/s/a1b2parwrkjf848/Screenshot 2021-01-26 19.20.48.png?dl=0
                            The F7 Button is a Hotkey for a Streaming Software called OBS to change the Scene. Does that matter?
                            Thanks for your help already
                              @Arthur-Neufeld, I'm glad you mentioned OBS. I had no luck using wscript to send hot keys to OBS, so I made this post where I made two AutoIT .exe files - one for start recording, and one for stop recording, but you could use them for start and stop streaming too.
                              I use them and it works great.
                              • Antonio LeañosA Offline
                                Antonio Leaños
                                Hey I used this and it works just fine, but I want to use the start /wait timeout command to give some space in between a couple key presses but it just ignores them and say "access denied" does anyone know why is that?
                                  Russ @Antonio Leaños
                                  @Antonio-Leaños, when I tried a command like this, it worked for me.
                                  start /min /wait timeout 5 & calc
                                  It waited 5 seconds, then ran calculator.
                                  Does that work for you? If not, can you tell me what command you're trying?
                                  • Teo castrejon escamillaT Offline
                                    Teo castrejon escamilla @Russ
                                    @russ said in Press the Down Arrow key (or any other key):
                                    does it work on mac?
                                      Russ @Teo castrejon escamilla
                                      @teo-castrejon-escamilla , no. On Mac you could use applescript.
                                      https://apple.stackexchange.com/questions/36943/how-do-i-automate-a-key-press-in-applescript
                                      • R Offline
                                        raquel @Russ
                                        @russ Would it be possible to press FN key? Cant find information about it, since its not a key present in every keyboard, but mine actually have 2 FN keys and most of my shortcuts needs both of them to be pressed on first. Any thoughts?
                                        • Marcos IbarraM Offline
                                          Marcos Ibarra
                                          Hello, i just have one question, i made an script with AutoIT to trigger some hotkeys like ALT+NUMPAD1, but sometimes is working and sometimes dont, and i can see the script running in windows processes, What could be happening or what im doing wrong? i tried different ways to define the same action like winactive in first line, and using sleep command thinking maybe than is too fast, i let you screenshots, hoping you can help me guys, thanks. Captura de pantalla (82).png Captura de pantalla (84).png
                                            Russ @Marcos Ibarra
                                            @marcos-ibarra , check out this post. I did what you seem to be doing with OBS here:
                                            https://www.triggercmd.com/forum/topic/1063/start-and-stop-obs-recording-or-streaming?_=1659268705659
                                            Marcos IbarraM 1 Reply Last reply Reply Quote 0
