    2. Gerfesson Alves de Oliveira
    @Gerfesson Alves de Oliveira
    Gerfesson Alves de Oliveira Unfollow Follow
    Latest posts made by Gerfesson Alves de Oliveira
    • RE: Press the Down Arrow key (or any other key)
      @Russ , I found a way thru your guidence!! Thanks a lot!
      The whole au3 document was this:
      Send("{LWINDOWN}") ; Holds the Windows key down
      Send("{p}") ; Presses the p key
      Send("{LWINUP}") ; Releases the Windows key
      sleep (500)
      Send("{UP}") ; Presses Up arrow
      Send("{ENTER}") ; Presses Enter
      sleep(500)
      ShellExecute("C:\Users\nosse\AppData\Local\Programs\Opera GX\launcher.exe")
      ShellExecute("https://www.primevideo.com")
      ShellExecute("https://www.netflix.com")
      sleep (2000)
      Send("^{TAB}") ; Presses Shift + Tab
      Send("{CTRLDOWN}") ; Holds the CTRL key down
      Send("{w}") ; Presses the w key
      Send("{CTRLUP}") ; Releases the CTRL key
      sleep (300)
      Send("{SHIFTDOWN}") ; Holds the Left Shift key down
      Send("{RIGHT}") ; Presses Right arrow
      Send("{SHIFTUP}") ; Releases the Shift key
      With this code I change the screen mode to extend the for my projector, open up a new opera window with netflix and prime video, close the opera's welcome window and finally put this new openned window to the second screen!
      Now I'm going to do the reverse engineering! Thanks a lot once again
      Gerfesson Alves de OliveiraG
      How could I press windows key + "P" so I can open up the projection options?
