    2. Marcos Ibarra
    Marcos Ibarra
    @Marcos Ibarra
    Marcos Ibarra Unfollow Follow
    Latest posts made by Marcos Ibarra
    • RE: Press the Down Arrow key (or any other key)
      @russ Thanks! the hotkeys works, but i still having problems when i trigger the script, i think the script is the problem , because i use obs Lioranboard and triggercmd to change source visibility in my obs thorugh my voice, lioranboard is like a streamdeck, so i acitive buttons thorugh hotkeys than change sources visibility in my obs and i trigger the hot key from the script and sometimes works and sometimes dont, when i use the hotkye directly from my keyboard works all the time, i dont know what is happening. dont worry thanks for your help i will trigger my deck from ifttt and use triggercmd to run anything else, thanks Russ, ill be here, learning more about it. Captura de pantalla (85).png
      Marcos IbarraM
      Marcos Ibarra
      Hello, i just have one question, i made an script with AutoIT to trigger some hotkeys like ALT+NUMPAD1, but sometimes is working and sometimes dont, and i can see the script running in windows processes, What could be happening or what im doing wrong? i tried different ways to define the same action like winactive in first line, and using sleep command thinking maybe than is too fast, i let you screenshots, hoping you can help me guys, thanks. Captura de pantalla (82).png Captura de pantalla (84).png
      Marcos IbarraM
      Marcos Ibarra
