    40 Posts 17 Posters 26.9k Views 2 Watching
    • Daniel MillanD Offline
      Daniel Millan @Russ
      Okay, thanks.
        Russ @Daniel Millan
        @Daniel-Millan, sorry. I think it would be a security flaw to allow any process to simulate key presses at that point. That said, there might be some way to do it.
        • João Paulo PugialliJ Offline
          João Paulo Pugialli
          Hello,
          Do you know if it is possible to press a F-media key? For example, I wanted to make alexa press f9 key because that is my shorcut for keyboard lights off. I tried this code:
          WshShell.SendKeys "{F9}"
          But it just keeps pressing numlock.
          Regards,
            Russ @João Paulo Pugialli
            @João-Paulo-Pugialli, according to this article, {F9} is correct, so maybe your keyboard is doing something in hardware to toggle its own light off.
            https://social.technet.microsoft.com/wiki/contents/articles/5169.vbscript-sendkeys-method.aspx
              Russ @Russ
              FYI, I found that Wsh.SendKeys can't do ALT+1 (or any other digit), but I was able to make it work with this AutoHotKey script.
              Send, !1
              ! means hold the ALT key (while pressing 1). You can see examples like this in the Tutorial page in AutoHotKey's help.
              My TRIGGERcmd command is this: start d:\tools\AutoHotKey\pressAlt1.ahk
              Let me know if you need me to do a video on this.
              • Gerfesson Alves de OliveiraG Offline
                How could I press windows key + "P" so I can open up the projection options?
                  Gerfesson Alves de OliveiraG TriboT 2 Replies Last reply Reply Quote 0
                    Gerfesson Alves de Oliveira @Russ
                    @Russ , I found a way thru your guidence!! Thanks a lot!
                    The whole au3 document was this:
                    sleep (500)
                    Send("{UP}") ; Presses Up arrow
                    Send("{ENTER}") ; Presses Enter
                    sleep(500)
                    ShellExecute("C:\Users\nosse\AppData\Local\Programs\Opera GX\launcher.exe")
                    ShellExecute("https://www.primevideo.com")
                    ShellExecute("https://www.netflix.com")
                    sleep (2000)
                    Send("^{TAB}") ; Presses Shift + Tab
                    Send("{CTRLDOWN}") ; Holds the CTRL key down
                    Send("{w}") ; Presses the w key
                    Send("{CTRLUP}") ; Releases the CTRL key
                    sleep (300)
                    Send("{SHIFTDOWN}") ; Holds the Left Shift key down
                    Send("{RIGHT}") ; Presses Right arrow
                    Send("{SHIFTUP}") ; Releases the Shift key
                    With this code I change the screen mode to extend the for my projector, open up a new opera window with netflix and prime video, close the opera's welcome window and finally put this new openned window to the second screen!
                    Now I'm going to do the reverse engineering! Thanks a lot once again
                      @Gerfesson-Alves-de-Oliveira, nice job!
                      I hope you do a youtube video showing it off.
                      • Andoni CantónA Offline
                        Andoni Cantón
                          Russ @Andoni Cantón
                          space
                          Dim Wsh
                          Wsh.SendKeys " "
                          wscript c:\scripts\space.vbs
                          • TriboT Offline
                            Tribo @Russ
                            I added:
                            Send("{DOWN}")
                            Send("{DOWN}")
                            Send("{ENTER}")
                              Russ @Tribo
                              • Arthur NeufeldA Offline
                                Arthur Neufeld
                                I created a vbs file with
                                Dim Wsh
                                Wsh.SendKeys "{F7}"
                                in it. Safed it at
                                c:\scripts\key.vbs
                                wscript c:\scripts\key.vbs
                                What did I do wrong?
                                Cheers
                                Arthur
                                  Russ @Arthur Neufeld
                                  Mine looks like this:
                                  • XanderX Offline
                                    Xander
                                      Arthur Neufeld @Russ
                                      @Russ Hi Russ, no unfortunately it doesn't rund the command from a cmd prompt. This happens if I copy and paste it in cmd:
                                      https://www.dropbox.com/s/se4b59gxgk43su2/Screenshot 2021-01-26 19.25.19.png?dl=0
                                      The command looks exactly like yours:
                                      https://www.dropbox.com/s/a1b2parwrkjf848/Screenshot 2021-01-26 19.20.48.png?dl=0
                                      The F7 Button is a Hotkey for a Streaming Software called OBS to change the Scene. Does that matter?
                                      Thanks for your help already
                                        @Arthur-Neufeld, I'm glad you mentioned OBS. I had no luck using wscript to send hot keys to OBS, so I made this post where I made two AutoIT .exe files - one for start recording, and one for stop recording, but you could use them for start and stop streaming too.
                                        I use them and it works great.
                                        • Antonio LeañosA Offline
                                          Antonio Leaños
                                          Hey I used this and it works just fine, but I want to use the start /wait timeout command to give some space in between a couple key presses but it just ignores them and say "access denied" does anyone know why is that?
                                            Russ @Antonio Leaños
                                            @Antonio-Leaños, when I tried a command like this, it worked for me.
                                            start /min /wait timeout 5 & calc
                                            It waited 5 seconds, then ran calculator.
                                            Does that work for you? If not, can you tell me what command you're trying?
