    40 Posts 17 Posters 28.3k Views 2 Watching
    • JcjccJ Offline
      Jcjcc
      Can you hold down a button?
        Russ @Jcjcc
        @Jcjcc, tell me more - what are you trying to accomplish?
        • Daniel MillanD Offline
          Daniel Millan
          Can I run this in a background command?
            Russ @Daniel Millan
            @Daniel-Millan, you could, but it wouldn't do any good. The command would run, but as Local System, not the user, so it wouldn't press any buttons for the logged in user.
            If you make it a foreground command it might do what you're trying to accomplish though - you don't actually see the command running, you just see the results of the button(s) being pressed.
            Daniel MillanD 1 Reply Last reply Reply Quote 0
              Daniel Millan @Russ
              @Russ I want to run it before I am logged into the computer.
                Russ @Daniel Millan
                @Daniel-Millan, don't think that's possible.
                  Daniel Millan @Russ
                  Okay, thanks.
                    Russ @Daniel Millan
                    @Daniel-Millan, sorry. I think it would be a security flaw to allow any process to simulate key presses at that point. That said, there might be some way to do it.
                    • João Paulo PugialliJ Offline
                      João Paulo Pugialli
                      Hello,
                      Do you know if it is possible to press a F-media key? For example, I wanted to make alexa press f9 key because that is my shorcut for keyboard lights off. I tried this code:
                      WshShell.SendKeys "{F9}"
                      But it just keeps pressing numlock.
                      Regards,
                        Russ @João Paulo Pugialli
                        @João-Paulo-Pugialli, according to this article, {F9} is correct, so maybe your keyboard is doing something in hardware to toggle its own light off.
                        https://social.technet.microsoft.com/wiki/contents/articles/5169.vbscript-sendkeys-method.aspx
                          Russ @Russ
                          FYI, I found that Wsh.SendKeys can't do ALT+1 (or any other digit), but I was able to make it work with this AutoHotKey script.
                          Send, !1
                          ! means hold the ALT key (while pressing 1). You can see examples like this in the Tutorial page in AutoHotKey's help.
                          My TRIGGERcmd command is this: start d:\tools\AutoHotKey\pressAlt1.ahk
                          Let me know if you need me to do a video on this.
                          • Gerfesson Alves de OliveiraG Offline
                            How could I press windows key + "P" so I can open up the projection options?
                              Gerfesson Alves de OliveiraG TriboT 2 Replies Last reply Reply Quote 0
                                Gerfesson Alves de Oliveira @Russ
                                @Russ , I found a way thru your guidence!! Thanks a lot!
                                The whole au3 document was this:
                                sleep (500)
                                Send("{UP}") ; Presses Up arrow
                                Send("{ENTER}") ; Presses Enter
                                sleep(500)
                                ShellExecute("C:\Users\nosse\AppData\Local\Programs\Opera GX\launcher.exe")
                                ShellExecute("https://www.primevideo.com")
                                ShellExecute("https://www.netflix.com")
                                sleep (2000)
                                Send("^{TAB}") ; Presses Shift + Tab
                                Send("{CTRLDOWN}") ; Holds the CTRL key down
                                Send("{w}") ; Presses the w key
                                Send("{CTRLUP}") ; Releases the CTRL key
                                sleep (300)
                                Send("{SHIFTDOWN}") ; Holds the Left Shift key down
                                Send("{RIGHT}") ; Presses Right arrow
                                Send("{SHIFTUP}") ; Releases the Shift key
                                With this code I change the screen mode to extend the for my projector, open up a new opera window with netflix and prime video, close the opera's welcome window and finally put this new openned window to the second screen!
                                Now I'm going to do the reverse engineering! Thanks a lot once again
                                  @Gerfesson-Alves-de-Oliveira, nice job!
                                  I hope you do a youtube video showing it off.
                                  • Andoni CantónA Offline
                                    Andoni Cantón
                                      Russ @Andoni Cantón
                                      space
                                      Dim Wsh
                                      Wsh.SendKeys " "
                                      wscript c:\scripts\space.vbs
                                      • TriboT Offline
                                        Tribo @Russ
                                        I added:
                                        Send("{DOWN}")
                                        Send("{DOWN}")
                                        Send("{ENTER}")
                                          Russ @Tribo
                                          • Arthur NeufeldA Offline
                                            Arthur Neufeld
                                            I created a vbs file with
                                            Dim Wsh
                                            Wsh.SendKeys "{F7}"
                                            in it. Safed it at
                                            c:\scripts\key.vbs
                                            wscript c:\scripts\key.vbs
                                            What did I do wrong?
                                            Cheers
                                            Arthur
