• Raspberry Pi image with TRIGGERcmd pre-loaded
    Pinned raspberry pi
    0 Votes
    1k Views
    No one has replied
  • Raspberry Pi setup
    Pinned Moved raspberry pi
    40
    0 Votes
    39k Views
    Jorge FuentesJ
    That's brilliant, thank you for the information.
  • Error while installing the triggercmdagent
    8
    0 Votes
    RussR
    @Hannibal I see an error in the json. There should be a quote (") at the beginning of the word background.
  • 0 Votes
    4k Views
    XanderX
    I use CMDNOWND for this. https://dennisbabkin.com/cmdnownd/ You pop it in the cmd line like this: cmdnownd "D:\Libraries\Documents\batchfile.bat" and it suppresses the appearance of the cmd window. Just place the exe in your path. I keep it in the Windows folder itself. [image: 1767628367785-scrsht_cmdnownd.png]
  • How do I create a trigger
    0 Votes
    RussR
    @mega_big, on a Raspberry Pi, assuming you installed the agent using these instructions, your commands are in this file: /root/.TRIGGERcmdData/commands.json You'll see the default commands in there. You can run these commands to edit it: sudo su - cd /root/.TRIGGERcmdData nano commands.json While the agent is running, it will detect changes in that commands.json file and create/remove triggers for those commands in your TRIGGERcmd account. If you mess up the json at all (an extra comma even), the agent will restore the last backup it took. You'll see that in your debug.log. If you don't want to deal with editing text, you could create a command on your Windows PC using the "GUI Command Editor" then copy/paste the json text of that command from the "Text Command Editor" into your commands.json file.
  • Issues following installation instructions
    9
    0 Votes
    2k Views
    RussR
    @jcksnftsn, awesome.
  • Commands.json reverting to previous version
    8
    0 Votes
    2k Views
    RussR
    @Al-S, do the new commands have a voice word? That's required for the skill to create devices.
  • New user on latest Raspberry Pi help please!
    0 Votes
    1k Views
    RussR
    @Al-S, great. Glad that was it.
  • How to exactly run Commands on Raspi via Voice on Alexa
    0 Votes
    1k Views
    Furkan CevikF
    @Russ ty!!
  • Turn on 3D printer, print, then turn it off
    0 Votes
    No one has replied
  • Contents of command.json getting lost
    9
    0 Votes
    3k Views
    D
    Russ, is there any other information that you need or anything else that I can do or provide to help determine what to do to get my commands.json commands into TRIGGER.cmd on my RasPi Zero W?
  • NODE_TLS_REJECT_UNAUTHORIZED
    0 Votes
    8k Views
    RussR
    @hogkite, you're welcome. I just updated the Mac agent too.
  • This topic is deleted!
    0 Votes
    No one has replied
  • Cannot execute shell scripts: Wrong json syntax?
    0 Votes
    1k Views
    RussR
    @riccardo-cereser, please try adding this to your script: SCRIPTDIR=$(dirname "$0") cd $SCRIPTDIR That way you can specify the full path to your script in the commands.json file, and when your script runs, it will cd to the directory where your script is.
  • i can't add trigger on my raspberry pi
    0 Votes
    2k Views
    Pé de PanoP
    It all worked out! Thank you very much Russ, you helped me a lot.@russ
  • I can't create triggers on the raspberry pi
    Moved
    12
    0 Votes
    5k Views
    RussR
    @dean-mcnaughton, nice. Good job getting it working.
  • installing triggercmd on a raspberry pi router that has openWRT
    0 Votes
    RussR
    @zed-master, if you can install nodejs on it, you should be able to run the agent.js with a command like this: node agent.js --console You can find the agent code at https://github.com/rvmey/TRIGGERcmdAgent
  • Command format on Raspi
    Moved
    32
    0 Votes
    17k Views
    tuicemenT
    @steve-porter yep that will mess things up. I remember reading another post about that so that isn't something that you alone have experienced. I found a couple times the file didn't update for me for different errors in command lines. I've gotten into the habit of double checking if it saves.
  • Raspbery Pi docker / docker-compose
    Moved
    0 Votes
    1k Views
    RussR
    @Andy-Kutruff, try this one. I just pushed it: docker pull rvmey/triggercmdagent:arm You'll need to create an actual computer record in your account and get the ID for it from your browser's address bar after you click view triggers.
  • Installation error on Raspberry PI 3
    Moved
    0 Votes
    2k Views
    RussR
    Very cool. Thanks @Sébastien-Pineau. I'll let you know if I get this working.
