    i can't add trigger on my raspberry pi
    Raspberry Pi
    • Pé de PanoP
      Pé de Pano
      Hello Russ, I managed to install the Trigger cmd on my Raspberry pi, insclusive managed to see it on the site. But I'm having trouble adding a Trigger. I could not edit the file: commands.json. I opened the terminal as root user, and typed the following code: /root/. TRIGGERcmdData/commands.json, and I received the output: Permission denied. I'd like you to help me. Thank you right now.
        Russ @Pé de Pano
        @pé-de-pano , try
        nano /root/.TRIGGERcmdData/commands.json
        Your command tried to execute the text file as if it was a script. Nano is a text editor.
        Pé de PanoP 1 Reply Last reply Reply Quote 0
        • Pé de PanoP
          Pé de Pano @Russ
          @russ hello russ, I edited the commands.json to:
          {"trigger":"Gnome Editor","command":"gedit","ground":"foreground","voice":"edit","allowParams": "false"},
          {"trigger":"python test","command":"python /root/led.py","ground":"background","voice":""}
          but when saving I can't see the trigger on the site, only Gnome Editor. Could you help me?
            Russ @Pé de Pano
            @pé-de-pano, can you check whether your background service is running?
            pi@garagepi:~ $ systemctl status triggercmdagent
               Active: active (running) since Thu 2022-03-31 10:17:03 UTC; 1 months 5 days ago
             Main PID: 262 (node)
                       └─262 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
            May 01 23:13:40 garagepi env[262]:   |>    Socket reconnected successfully after
            May 01 23:13:40 garagepi env[262]: \___/   being offline at least 28.27 seconds.
            May 01 23:13:40 garagepi env[262]:   |>    Now connected to https://www.triggercmd.com.
            May 01 23:13:40 garagepi env[262]: \___/   For help, see: http://bit.ly/2q0QDpf
            It has to be running in order to sync up the background commands in your commands.json with your computer in your account.
            • Pé de PanoP
              Pé de Pano @Russ
              @russ said in i can't add trigger on my raspberry pi:
              hello, I received the following output
                   Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vend>
                   Active: active (running) since Fri 2022-05-06 00:28:26 BST; 1 day 12h ago
                 Main PID: 404 (node)
                    Tasks: 11 (limit: 1598)
                      CPU: 3.577s
                           └─404 node /usr/share/triggercmdagent/app/src/daemon.js --run /roo>
              May 07 13:09:12 raspberrypi env[404]: _-|>_-  (attempt #3)
              May 07 13:09:12 raspberrypi env[404]:   |>    Socket reconnected successfully a>
              May 07 13:09:12 raspberrypi env[404]: \___/   being offline at least 132038.91 >
              May 07 13:09:12 raspberrypi env[404]:   |>    Now connected to https://www.trig>
              May 07 13:09:12 raspberrypi env[404]: \___/   For help, see: http://bit.ly/2q0Q>
              May 07 13:09:12 raspberrypi env[404]:         (using sails.io.js node SDK @v1.1>
              May 07 13:09:12 raspberrypi env[404]:          Connected at: Sat May 07 2022 13>
              May 07 13:09:12 raspberrypi env[404]: { message: 'Subscribed to null!' }
              lines 1-19/19 (END)...skipping...
                      CPU: 3.577s
                           └─404 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
              May 07 13:09:12 raspberrypi env[404]:   |>    Socket reconnected successfully after
              May 07 13:09:12 raspberrypi env[404]: \___/   being offline at least 132038.91 seconds.
              May 07 13:09:12 raspberrypi env[404]:   |>    Now connected to https://www.triggercmd.com.
              May 07 13:09:12 raspberrypi env[404]: \___/   For help, see: http://bit.ly/2q0QDpf
              May 07 13:09:12 raspberrypi env[404]:         (using sails.io.js node SDK @v1.1.13)
              May 07 13:09:12 raspberrypi env[404]:          Connected at: Sat May 07 2022 13:09:12 GMT+0100 (British Summer Time)
                Russ @Pé de Pano
                @pé-de-pano, I see this in your output:
                "Subscribed to null!"
                That's bad. It should not be "null". It should be your computer ID.
                I suggest you try this:
                • Delete your computer from your account
                • Login as root with this command: sudo su -
                • Run triggercmdagent
                • Re-enter your token.
                • Press CTRL-C to exit.
                • Run: systemctl restart triggercmdagent
                • Run: systemctl status triggercmdagent
                It should re-create your computer in your account, with the commands in your commands.json file.
                • Pé de PanoP
                  Pé de Pano @Russ
                  It all worked out! Thank you very much Russ, you helped me a lot.@russ
