    NODE_TLS_REJECT_UNAUTHORIZED
    Raspberry Pi
    6.2k
    • H
      hogkite
      Just starting out on Triggercmd and although I've got everything up and running I did get this error during the install....
      (node:10413) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
      Is this a known problem and is there a fix for this please?
      Thx
        Russ @hogkite
        @hogkite, that warning is normal but I'll remove it in the next version of the agent.
        H 1 Reply Last reply Reply Quote 0
        • H
          hogkite @Russ
          @Russ Thanks Russ......is certificate verification disabled or is this an erroneous message?
            Russ @hogkite
            @hogkite, it is disabled.
            I just made this commit, so the next version will verify the server's cert chains up to a root cert.
            https://github.com/rvmey/TRIGGERcmd-Agent/commit/98143d487ef3a0fe9edde51d1a34c91e044af29a
            Thanks for pointing this out. This setting is no longer necessary.
            EDIT: I updated the Windows agent just now.
            • H
              hogkite @Russ
              @Russ Great stuff, thanks 👍
                Russ @hogkite
                @hogkite, you're welcome.
                I just updated the Mac agent too.
