    2. Sébastien Pineau
    Sébastien Pineau
    @Sébastien Pineau
    Sébastien Pineau Unfollow Follow
    Latest posts made by Sébastien Pineau
    • RE: Installation error on Raspberry PI 3
      They are Phoenix 433 Plug, chinese cheap, the one sold with a remote control ABCD. They are quite old now, can't find them online. You can scan the code send by the remote and repeat it with a 433MHz receiver/emitter or use this piece of code I found some time ago:
      import time
      import sys
      import RPi.GPIO as GPIO
      from DHT11_06_DC import read_temp
      a_on =  '1111111111111010101011101'
      a_off = '1111111111111010101010111'
      b_on =  '1111111111101110101011101'
      b_off = '1111111111101110101010111'
      c_on =  '1111111111101011101011101'
      c_off = '1111111111101011101010111'
      d_on =  '1111111111101010111011101'
      d_off = '1111111111101010111010111'
      r_on =  '1010101010111'
      r_off = '1010101011101'
      short_delay =    0.00045
      long_delay =     0.00090
      extended_delay = 0.0096
      NUM_ATTEMPTS = 10
      TRANSMIT_PIN = 16
      def transmit_code(code):
      	'''Transmit a chosen code string using the GPIO transmitter'''
      	GPIO.setmode(GPIO.BCM)
      	GPIO.setup(TRANSMIT_PIN, GPIO.OUT)
      	for t in range(NUM_ATTEMPTS):
      		for i in code:
      			if i == '1':
      				GPIO.output(TRANSMIT_PIN, 1)
      				time.sleep(short_delay)
      				GPIO.output(TRANSMIT_PIN, 0)
      				time.sleep(long_delay)
      			elif i == '0':
      			else:
      				continue
      		time.sleep(extended_delay)
      	GPIO.cleanup()
      def main():
      	while True:
      		tmp=50#read_temp(50)
      		print(tmp,end='')
      		if tmp>=40:
      			exec('transmit_code(r_on)')
      			print (' on',end='')
      		time.sleep(5)
      		if tmp> 41:
      			exec('transmit_code(r_off)')
      			print (' off',end='')
      		print (':')
      		time.sleep(5)
      if __name__=='__main__':
      	main()
      Sébastien PineauS
      Sébastien Pineau
      And node -v gave me v16.5.0
      Sébastien PineauS
      Sébastien Pineau
      Hi Russ,
      Thank you for your fast reply.
      Actually, it now work fine, I tried several of your proposals and other about nvm, but I'm unfortunately unable to say which one finally solved the issue. I made further testing with commands from my ok google to control my house appliances and cheap 443Mhz plugs and it look great. Thank you.
      Sébastien PineauS
      Sébastien Pineau
    • Installation error on Raspberry PI 3
      I receive an error when installing triggercmd. Something related to node_modules.
      I tried several hints provided, removed, put back, changed npm, still operation not allowed.
      root@raspberrypi:~# dpkg -i triggercmdagent_1.0.1_all.deb
      (Lecture de la base de données... 146201 fichiers et répertoires déjà installés.)
      Préparation du dépaquetage de triggercmdagent_1.0.1_all.deb ...
      Dépaquetage de triggercmdagent (1.0.1) sur (1.0.1) ...
      Paramétrage de triggercmdagent (1.0.1) ...
      Directory 'node_modules' exists. Running 'npm rebuild'
      /var/lib/dpkg/info/triggercmdagent.postinst : ligne 71 : 4776 Instruction non permise npm rebuild --production
      dpkg: erreur de traitement du paquet triggercmdagent (--install) :
      le sous-processus script post-installation installé a retourné une erreur de sortie d'état 132
      Des erreurs ont été rencontrées pendant l'exécution :
      triggercmdagent
      Sorry for the french installation, hope this is not the problem.
      The system has a lot of running modules used to control home automation, so i cannot go from scratch.
      Sébastien PineauS
      Sébastien Pineau
