where i can get support about one payment?
ALEXA
Hi , what is the voice commands alexa recognize ? I did some commands and when o trigger by the app, works perfect, by when i try use Alexa, she don't recognize the command.. .
RE: Arch Linux install
Just a small tip , to run the foreground agent on the begin of the session , i put this command
node /home/YOURUSERNAME/TRIGGERcmd-Agent/src/agent.js --console > /dev/null 2>&1 &
on ./bashrc and then setup fot the terminal start on the begin of the session...if any one have more ideias how to do it , just share
RE: Boot on Arch
It works @Russ thank you so much , i will post a video on some groups with i am on facebook when i have this setup , and i will buy a licence later on , not because i need but to help the development
RE: Boot on Arch
@Russ i don t understand what i did wrong... I will give another try later this week...
And you could trigger the command after the boot ?
RE: Boot on Arch
@Russ , i use arch because i just have to install once as a rolling release , then is just maintain the system . is easy to use , just have what I want installed , and arch has a really good wiki , that's make your live easier .
is a pain in the ass have to install the system every time come out a new version....like debian or fedora or even ubuntu.
if you have a good backup like timeshift in place , and a package like downgrade if you have a bad update , you just need to roll back the system or downgrade the package... i am using arch and the only problem i had so far was when i format one of my drives in ntfs and i forgot to change the UUID on the fstab lol , system didn t boot i had to boot whit a pen drive and change the fstab to boot again. lol
I do not use a specific software like photoshop to use windows, and i do not like how Microsoft make us use what they want , is my pc , so i choose what i want on my machine, and virus is other nightmare.... you should know that
if you like linux , you should give a try
and this scrip , you will make a proper arch installation,like archwiki tells you to do, but save you to time write all the commands , and you can not miss a step lol is very easy miss a step .....
i am testing other linux bases on my http machine to use kodi , if you start on arch and like, is hard to get out it
RE: Boot on Arch
@Russ , if you do not want lost to mucj time install arch , use this scrip:
Archfi Script Launch
wget archfi.sf.net/archfi
sh archfi
RE: Boot on Arch
@Russ , I am using pure arch
you can download from : https://www.archlinux.org/download/I realy appreciate your help , but will not be easier if you create a AUR on the package manager do do it automatically?
i do not have a problem in work with the terminal and edit files , even if doesn t have Gui , you can creat a script for arch to do it automatically...is just a suggestion
will wait for news
thank you
RE: Boot on Arch
HI @Russ , sorry to tell you but didm t work....this was what i did.
1- delete all the folders /.TRIGGERcmdData in root and home.2- login as rooter and run the command , put the token to connect. so far so good , i was able to connect and trigger some commands .
3- create a desktop entry on systemd :
[Unit]
Description=TRIGGERcmd Agent*[Service]
Type=simple
ExecStart=/usr/bin/env node /home/tiago/Modelos/TRIGGERcmd-Agent/src/deamon.js --run root/.TRIGGERcmdData
User=root
Restart=always[Install]
WantedBy=default.target*I put the right patch to deamon.js because this /usr/share/triggercmdagent/app/src/daemon.js doesnt exist
then i save on /etc/systemd/system4- sudo systemctl daemon-reload
sudo systemctl start triggercmdagent
sudo systemctl status triggercmdagent
and is give an error :● triggercmdagent.service - TRIGGERcmd Agent
Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2020-02-27 13:41:39 GMT; 4s ago
Process: 2246 ExecStart=/usr/bin/env node /home/tiago/Modelos/TRIGGERcmd-Agent/src/deamon.js --run root/.TRIGGERcmdData (code=exited, status=1/FAILURE)
Main PID: 2246 (code=exited, status=1/FAILURE)fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
fev 27 13:41:39 kodi systemd[1]: Stopped TRIGGERcmd Agent.
fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Start request repeated too quickly.
fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Failed with result 'exit-code'.
fev 27 13:41:39 kodi systemd[1]: Failed to start TRIGGERcmd Agent.Help Please, i really like to put this working
maybe will be easy if you do a tutorial about arch from the install to the daemon , i do not know what to do anymore
What i did wrong ? now the account that will match the ID
RE: Boot on Arch
Hi @Russ , thank for the answer, but did work
I run your instructions to install , i manager to setup some triggers and run it . but it doesn't happen anything ẃith your instructions to load on boot.
1 - my daemon.js is not on /usr/share/triggercmdagent/app/src/. is on /home/tiago/Modelos/TRIGGERcmd-Agent/src/daemon.js
2 - if i replace the patch fot the one where i have daemon.js when i do systemctl status triggercmdagent , is give an error :[tiago@Kodi ~]$ sudo systemctl status triggercmdagent
[sudo] senha para tiago:
Loaded: loaded (/etc/systemd/system/triggercmdagent.service; disabled; vendor preset: disabled)
Active: active (running) since Wed 2020-02-26 03:13:53 GMT; 2min 37s ago
Main PID: 6885 (node)
Tasks: 11 (limit: 38415)
Memory: 28.8M
└─6885 node /home/tiago/Modelos/TRIGGERcmd-Agent/src/daemon.js --run /root/.TRIGGERcmdDatafev 26 03:13:54 Kodi env[6885]: ___/ For help, see: http://bit.ly/2q0QDpf
fev 26 03:13:54 Kodi env[6885]: (using sails.io.js node SDK @v1.2.1)
fev 26 03:13:54 Kodi env[6885]: Connected at: Wed Feb 26 2020 03:13:54 GMT+0000 (Hora de Greenwich)
fev 26 03:13:54 Kodi env[6885]: Initiated command removals
fev 26 03:13:54 Kodi env[6885]: Initiated command adds
fev 26 03:13:54 Kodi env[6885]: { message: 'Subscribed to 5e54ffba256e4d0019bbcef2!' }
fev 26 03:13:55 Kodi env[6885]: Failed while trying add a trigger.
[tiago@Kodi ~]$what is happening to fail add a trigger???
Boot on Arch
hi , running arch and I was able to set up my commands , but how i use to run on boot to make wakeonlan?
RE: trigger cmd on arch linux
Thank Russ for this , but on arch how I run the triggercmd on boot?
my goal is wakeonlan....thankyuo
