    Arch Linux install
    Linux
    1.4k
      There is no official installer for Arch Linux, but these steps will get it working.
      This assumes you're running X-Windows and logging in as a non-root user with sudo access (russ in this example).
      • Open a terminal window
      • Run: git clone https://github.com/rvmey/TRIGGERcmd-Agent.git
      • Run: ./TRIGGERcmd-Agent/src/agent.js --console
      • Copy/paste your token from the Instructions page in your triggercmd.com account to the prompt.
      • Trigger the Gnome editor to test it.
      • Press CTRL-C to exit.
      • Run: sudo su -
      • Run: nano /etc/systemd/system/triggercmdagent.service
      • Copy/paste this text into the file, replace russ with your own user, and save it:
      [Unit]
      Description=TRIGGERcmd Agent
      [Service]
      Type=simple
      ExecStart=/usr/bin/env node /home/russ/TRIGGERcmd-Agent/src/daemon.js --run /home/russ/.TRIGGERcmdData
      User=root
      Restart=always
      [Install]
      WantedBy=default.target
      • Run: systemctl daemon-reload
      • Run: systemctl enable triggercmdagent
      • Run: systemctl start triggercmdagent
      Now you should have the background agent running as root, and you can run the foreground agent as your non-root user by running this command in a terminal Window:
      node ~/TRIGGERcmd-Agent/src/agent.js --console
      Edit your TRIGGERcmd commands as your non-root user with this command:
      nano ~/.TRIGGERcmdData/commands.json
      • Tiago MártiresT
        Tiago Mártires
        Just a small tip , to run the foreground agent on the begin of the session , i put this command
        node /home/YOURUSERNAME/TRIGGERcmd-Agent/src/agent.js --console > /dev/null 2>&1 &
        on ./bashrc and then setup fot the terminal start on the begin of the session...
        if any one have more ideias how to do it , just share 🙂
        Craig OKC 1 Reply Last reply Reply Quote 1
        • Craig OKC
          Craig OK @Tiago Mártires
          @Tiago-Mártires Pretty much the same thing but I added this line to crontab:
          @reboot node /usr/share/triggercmdagent/resources/app/src/agent.js &
          • F
            fennectech
