    2. Tiago Mártires
    Tiago MártiresT Offline
    • Posts 13
    Tiago Mártires
    @Tiago Mártires
    Tiago Mártires Unfollow Follow
    • RE: Arch Linux install
      Just a small tip , to run the foreground agent on the begin of the session , i put this command
      node /home/YOURUSERNAME/TRIGGERcmd-Agent/src/agent.js --console > /dev/null 2>&1 &
      on ./bashrc and then setup fot the terminal start on the begin of the session...
      if any one have more ideias how to do it , just share 🙂
      posted in Linux
      Tiago MártiresT
      Tiago Mártires
    • support
      where i can get support about one payment?
      Tiago MártiresT
      Tiago Mártires
    • ALEXA
      Hi , what is the voice commands alexa recognize ? I did some commands and when o trigger by the app, works perfect, by when i try use Alexa, she don't recognize the command.. .
      posted in Alexa
      Tiago MártiresT
      Tiago Mártires
      posted in Linux
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      It works @Russ thank you so much , i will post a video on some groups with i am on facebook when i have this setup , and i will buy a licence later on , not because i need but to help the development 🙂
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      @Russ i don t understand what i did wrong... I will give another try later this week...
      And you could trigger the command after the boot ?
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      @Russ , i use arch because i just have to install once as a rolling release , then is just maintain the system . is easy to use , just have what I want installed , and arch has a really good wiki , that's make your live easier .
      is a pain in the ass have to install the system every time come out a new version....like debian or fedora or even ubuntu.
      if you have a good backup like timeshift in place , and a package like downgrade if you have a bad update , you just need to roll back the system or downgrade the package... i am using arch and the only problem i had so far was when i format one of my drives in ntfs and i forgot to change the UUID on the fstab lol , system didn t boot i had to boot whit a pen drive and change the fstab to boot again. lol
      I do not use a specific software like photoshop to use windows, and i do not like how Microsoft make us use what they want , is my pc , so i choose what i want on my machine, and virus is other nightmare.... you should know that 🙂
      if you like linux , you should give a try 🙂
      and this scrip , you will make a proper arch installation,like archwiki tells you to do, but save you to time write all the commands , and you can not miss a step lol is very easy miss a step .....
      i am testing other linux bases on my http machine to use kodi , if you start on arch and like, is hard to get out it
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      @Russ , if you do not want lost to mucj time install arch , use this scrip:
      Archfi Script Launch
      wget archfi.sf.net/archfi
      sh archfi
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      @Russ , I am using pure arch
      you can download from : https://www.archlinux.org/download/
      I realy appreciate your help , but will not be easier if you create a AUR on the package manager do do it automatically?
      i do not have a problem in work with the terminal and edit files , even if doesn t have Gui , you can creat a script for arch to do it automatically...
      is just a suggestion 🙂
      will wait for news
      thank you
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      HI @Russ , sorry to tell you but didm t work....this was what i did.
      1- delete all the folders /.TRIGGERcmdData in root and home.
      2- login as rooter and run the command , put the token to connect. so far so good , i was able to connect and trigger some commands .
      3- create a desktop entry on systemd :
      [Unit]
      Description=TRIGGERcmd Agent
      *[Service]
      Type=simple
      ExecStart=/usr/bin/env node /home/tiago/Modelos/TRIGGERcmd-Agent/src/deamon.js --run root/.TRIGGERcmdData
      User=root
      Restart=always
      [Install]
      WantedBy=default.target*
      I put the right patch to deamon.js because this /usr/share/triggercmdagent/app/src/daemon.js doesnt exist
      then i save on /etc/systemd/system
      4- sudo systemctl daemon-reload
      sudo systemctl start triggercmdagent
      sudo systemctl status triggercmdagent
      and is give an error :
      Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: disabled)
      Active: failed (Result: exit-code) since Thu 2020-02-27 13:41:39 GMT; 4s ago
      Process: 2246 ExecStart=/usr/bin/env node /home/tiago/Modelos/TRIGGERcmd-Agent/src/deamon.js --run root/.TRIGGERcmdData (code=exited, status=1/FAILURE)
      Main PID: 2246 (code=exited, status=1/FAILURE)
      fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
      fev 27 13:41:39 kodi systemd[1]: Stopped TRIGGERcmd Agent.
      fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Start request repeated too quickly.
      fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Failed with result 'exit-code'.
      fev 27 13:41:39 kodi systemd[1]: Failed to start TRIGGERcmd Agent.
      Help Please, i really like to put this working
      maybe will be easy if you do a tutorial about arch from the install to the daemon , i do not know what to do anymore 😞
      What i did wrong ? now the account that will match the ID
      Tiago MártiresT
      Tiago Mártires
    • RE: Boot on Arch
      Hi @Russ , thank for the answer, but did work 😢
      I run your instructions to install , i manager to setup some triggers and run it . but it doesn't happen anything ẃith your instructions to load on boot.
      1 - my daemon.js is not on /usr/share/triggercmdagent/app/src/. is on /home/tiago/Modelos/TRIGGERcmd-Agent/src/daemon.js
      2 - if i replace the patch fot the one where i have daemon.js when i do systemctl status triggercmdagent , is give an error :
      [tiago@Kodi ~]$ sudo systemctl status triggercmdagent
      [sudo] senha para tiago:
      Loaded: loaded (/etc/systemd/system/triggercmdagent.service; disabled; vendor preset: disabled)
      Active: active (running) since Wed 2020-02-26 03:13:53 GMT; 2min 37s ago
      Main PID: 6885 (node)
      Tasks: 11 (limit: 38415)
      Memory: 28.8M
      └─6885 node /home/tiago/Modelos/TRIGGERcmd-Agent/src/daemon.js --run /root/.TRIGGERcmdData
      fev 26 03:13:54 Kodi env[6885]: ___/ For help, see: http://bit.ly/2q0QDpf
      fev 26 03:13:54 Kodi env[6885]: (using sails.io.js node SDK @v1.2.1)
      fev 26 03:13:54 Kodi env[6885]: Connected at: Wed Feb 26 2020 03:13:54 GMT+0000 (Hora de Greenwich)
      fev 26 03:13:54 Kodi env[6885]: Initiated command removals
      fev 26 03:13:54 Kodi env[6885]: Initiated command adds
      fev 26 03:13:54 Kodi env[6885]: { message: 'Subscribed to 5e54ffba256e4d0019bbcef2!' }
      fev 26 03:13:55 Kodi env[6885]: Failed while trying add a trigger.
      [tiago@Kodi ~]$
      what is happening to fail add a trigger???
      Tiago MártiresT
      Tiago Mártires
