    Boot on Arch
    27 Posts 3 Posters 12.2k Views 1 Watching
      Russ @Tiago Mártires
      @Tiago-Mártires, I see arch linux uses systemd, so you could create a unit file with this path:
      You could create a unit file with this name:: /etc/systemd/system/triggercmdagent.service
      With these contents:
      [Unit]
      Description=TRIGGERcmd Agent
      [Service]
      Type=simple
      ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
      User=root
      Restart=always
      [Install]
      WantedBy=default.target
      Then reload the systemd config with this command:
      systemctl daemon-reload
      Then start the background service with this command:
      And check its status with this command:
      • Tiago MártiresT Offline
        Tiago Mártires
        Hi @Russ , thank for the answer, but did work 😢
        I run your instructions to install , i manager to setup some triggers and run it . but it doesn't happen anything ẃith your instructions to load on boot.
        1 - my daemon.js is not on /usr/share/triggercmdagent/app/src/. is on /home/tiago/Modelos/TRIGGERcmd-Agent/src/daemon.js
        2 - if i replace the patch fot the one where i have daemon.js when i do systemctl status triggercmdagent , is give an error :
        [tiago@Kodi ~]$ sudo systemctl status triggercmdagent
        [sudo] senha para tiago:
        Loaded: loaded (/etc/systemd/system/triggercmdagent.service; disabled; vendor preset: disabled)
        Active: active (running) since Wed 2020-02-26 03:13:53 GMT; 2min 37s ago
        Main PID: 6885 (node)
        Tasks: 11 (limit: 38415)
        Memory: 28.8M
        └─6885 node /home/tiago/Modelos/TRIGGERcmd-Agent/src/daemon.js --run /root/.TRIGGERcmdData
        fev 26 03:13:54 Kodi env[6885]: ___/ For help, see: http://bit.ly/2q0QDpf
        fev 26 03:13:54 Kodi env[6885]: (using sails.io.js node SDK @v1.2.1)
        fev 26 03:13:54 Kodi env[6885]: Connected at: Wed Feb 26 2020 03:13:54 GMT+0000 (Hora de Greenwich)
        fev 26 03:13:54 Kodi env[6885]: Initiated command removals
        fev 26 03:13:54 Kodi env[6885]: Initiated command adds
        fev 26 03:13:54 Kodi env[6885]: { message: 'Subscribed to 5e54ffba256e4d0019bbcef2!' }
        fev 26 03:13:55 Kodi env[6885]: Failed while trying add a trigger.
        [tiago@Kodi ~]$
        what is happening to fail add a trigger???
          Tiago Mártires
            @Tiago-Mártires, I think I see the problem. It's trying to write triggers to a computer with ID 5e54ffba256e4d0019bbcef2, but that computer doesn't exist anymore. I suspect you deleted it.
            I suggest you try this:
            • Login as root (sudo su -)
            • Backup your /root/.TRIGGERcmdData/commands.json file
            • Delete your /root/.TRIGGERcmdData folder
            • /home/tiago/Modelos/TRIGGERcmd-Agent/src/agent.js --console
            • Enter your token
            • Restart your triggercmdagent daemon
            • Test again
            Now you'll have a new computer in your account that will match the ID in your /root/.TRIGGERcmdData/computerid.cfg file.
              Tiago Mártires
              HI @Russ , sorry to tell you but didm t work....this was what i did.
              1- delete all the folders /.TRIGGERcmdData in root and home.
              2- login as rooter and run the command , put the token to connect. so far so good , i was able to connect and trigger some commands .
              3- create a desktop entry on systemd :
              [Unit]
              *[Service]
              Type=simple
              ExecStart=/usr/bin/env node /home/tiago/Modelos/TRIGGERcmd-Agent/src/deamon.js --run root/.TRIGGERcmdData
              User=root
              Restart=always
              [Install]
              WantedBy=default.target*
              I put the right patch to deamon.js because this /usr/share/triggercmdagent/app/src/daemon.js doesnt exist
              then i save on /etc/systemd/system
              4- sudo systemctl daemon-reload
              sudo systemctl start triggercmdagent
              and is give an error :
              Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: disabled)
              Active: failed (Result: exit-code) since Thu 2020-02-27 13:41:39 GMT; 4s ago
              Process: 2246 ExecStart=/usr/bin/env node /home/tiago/Modelos/TRIGGERcmd-Agent/src/deamon.js --run root/.TRIGGERcmdData (code=exited, status=1/FAILURE)
              Main PID: 2246 (code=exited, status=1/FAILURE)
              fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
              fev 27 13:41:39 kodi systemd[1]: Stopped TRIGGERcmd Agent.
              fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Start request repeated too quickly.
              fev 27 13:41:39 kodi systemd[1]: triggercmdagent.service: Failed with result 'exit-code'.
              fev 27 13:41:39 kodi systemd[1]: Failed to start TRIGGERcmd Agent.
              Help Please, i really like to put this working
              maybe will be easy if you do a tutorial about arch from the install to the daemon , i do not know what to do anymore 😞
              What i did wrong ? now the account that will match the ID
                @Tiago-Mártires, good idea. What specific arch Linux distro is it? I'll install it on a VM and try it myself.
                Tiago MártiresT 2 Replies Last reply Reply Quote 0
                  Tiago Mártires @Russ
                  @Russ , I am using pure arch
                  you can download from : https://www.archlinux.org/download/
                  I realy appreciate your help , but will not be easier if you create a AUR on the package manager do do it automatically?
                  i do not have a problem in work with the terminal and edit files , even if doesn t have Gui , you can creat a script for arch to do it automatically...
                  is just a suggestion 🙂
                  will wait for news
                  thank you
                    @Russ , if you do not want lost to mucj time install arch , use this scrip:
                    Archfi Script Launch
                    wget archfi.sf.net/archfi
                    sh archfi
                      @Tiago-Mártires, thanks for the script - it helps a lot. It's quite a process to get arch installed. I'm curious, why do you use it?
                        Tiago Mártires
                        @Russ , i use arch because i just have to install once as a rolling release , then is just maintain the system . is easy to use , just have what I want installed , and arch has a really good wiki , that's make your live easier .
                        is a pain in the ass have to install the system every time come out a new version....like debian or fedora or even ubuntu.
                        if you have a good backup like timeshift in place , and a package like downgrade if you have a bad update , you just need to roll back the system or downgrade the package... i am using arch and the only problem i had so far was when i format one of my drives in ntfs and i forgot to change the UUID on the fstab lol , system didn t boot i had to boot whit a pen drive and change the fstab to boot again. lol
                        I do not use a specific software like photoshop to use windows, and i do not like how Microsoft make us use what they want , is my pc , so i choose what i want on my machine, and virus is other nightmare.... you should know that 🙂
                        if you like linux , you should give a try 🙂
                        and this scrip , you will make a proper arch installation,like archwiki tells you to do, but save you to time write all the commands , and you can not miss a step lol is very easy miss a step .....
                        i am testing other linux bases on my http machine to use kodi , if you start on arch and like, is hard to get out it
                          @Tiago-Mártires, I got it working. Here's an article with the step-by-step instructions:
                          https://www.triggercmd.com/forum/topic/627/arch-linux-install
                          Tiago MártiresT 1 Reply Last reply Reply Quote 0
                            @Russ i don t understand what i did wrong... I will give another try later this week...
                            And you could trigger the command after the boot ?
                              @Tiago-Mártires, actually no, I forgot this command:
                              I added that to the instructions, so now the triggercmdagent background service is enabled to startup during boot.
                              I changed the reboot background command to reboot (the correct command on Arch Linux), and when I triggered that command it rebooted.
                              FYI, it didn't work for me at first because I had a path wrong, so one thing that helped me troubleshoot is this command:
                              sudo journalctl -u triggercmdagent
                              Then press SHIFT-G to jump to the bottom, and you can see any errors the background agent is producing.
                              Also, fyi, I noticed I got an email saying my command didn't run even though it rebooted. Apparently it started the reboot process before it got a chance to reply back to the server that it ran the command.
                                Tiago Mártires
                                It works @Russ thank you so much , i will post a video on some groups with i am on facebook when i have this setup , and i will buy a licence later on , not because i need but to help the development 🙂
                                  @Tiago-Mártires, awesome, thank you!
                                  • Gustavo SoaresG Offline
                                    Gustavo Soares
                                    hi, i also use arch linux (manjaro in my case) and i followed all the steps exactly as presented. Triggercmd keeps running in the background but when it's triggered, it doesn't perform the action (at least not in the foreground). I can see the logs in systemctl showing that it was triggered, but the action does not happen (open a program for example).
                                    Entered I propose a rather simple solution. I'm using a dropdown terminal (in my case guake) to run the triggercmd in the foreground, but in a way that it's hidden.
                                    For this solution to work completely, you need to create a script that executes this command:
                                    guake -e "node ~/TRIGGERcmd-Agent/src/agent.js --console" -r "triggercmd" &
                                    the -r flag is just to rename the guake tab.
                                    add a sleep 20 a line before the command to ensure that it will run with some delay and avoid any possible problems.
                                    The script looks like this:
                                    #!/bin/bash
                                    echo "Iniciando..."
                                    sleep 20
                                    then you can create a triggercmd-agent.desktop file in .config/autostart.
                                    inside the file inform this:
                                    [Desktop Entry]
                                    Encoding=UTF-8
                                    Version=0.9.4
                                    Type=Application
                                    Name=TriggerCMD Agent
                                    Comment=initialize triggercmd agent
                                    Exec=sh -c "~/<path_to_script>/<script>.sh"
                                    OnlyShowIn=XFCE;
                                    RunHook=0
                                    StartupNotify=true
                                    Terminal=false
                                    hidden=false
                                    done that, when logging in, an instance of guake will be started that executes the command to open the triggercmd, all in a hidden way.
                                    The main reason for this solution is that, at least for me, running triggercmd in the background doesn't work.
                                    I'm also developing a CLI to create, edit, list and remove commands in a friendlier way, since in arch linux it's not yet possible to run the triggercmd graphical interface.
                                    triggercmd command list
                                    triggercmd command new
                                      Russ @Gustavo Soares
                                      @Gustavo-Soares, your solution makes sense. Also that TUI (text user interface) is really cool. I hope you publish that.
                                      Gustavo SoaresG 1 Reply Last reply Reply Quote 0
                                        Gustavo Soares @Russ
                                        @Russ thank you very much for the feedback, I will publish it, it's already on my GitHub (see here). This week I will document the solution and publish it on PyPI. Your TriggerCMD is amazing, congratulations!
                                          Thank you @Gustavo-Soares
                                            Gustavo Soares
                                            Hi @Russ, I finish to publish a package on PyPi. Feel free to test and submit your contributions. To access click here.
