    2. Gustavo Soares
    • Posts 6
    • Best 1
    Gustavo Soares
    @Gustavo Soares
    Gustavo Soares Unfollow Follow
    Best posts made by Gustavo Soares
    • RE: Boot on Arch
      @Russ, very good. I think applying a decode('utf-8') should solve this problem. I really hadn't tried using special characters yet.
      Gustavo SoaresG
      Gustavo Soares
    Latest posts made by Gustavo Soares
    • RE: Boot on Arch
      Gustavo SoaresG
      Gustavo Soares
    • RE: Boot on Arch
      @Russ I think very nice this resource of panels, I just use this. Could be intersting in cards shape (for example), would be very beatiful and pleasant. I am thinking too that you can create a dashboard, and the data of runs could be showed there in graphics shape
      And if you have more ideas and features for the CLI, feels free open pull requests if possible.
      Gustavo SoaresG
      Gustavo Soares
    • RE: Boot on Arch
      @Russ, strange, a friend of mine uses ubuntu and managed to install normally. I'm going to create a ubuntu virtual machine and try this. Thanks for the feedback.
      [offtopic] I see here that you have a PWA, very nice!! Congratulations, I really liked it.
      Gustavo SoaresG
      Gustavo Soares
    • RE: Boot on Arch
      Hi @Russ, I finish to publish a package on PyPi. Feel free to test and submit your contributions. To access click here.
      Gustavo SoaresG
      Gustavo Soares
    • RE: Boot on Arch
      @Russ thank you very much for the feedback, I will publish it, it's already on my GitHub (see here). This week I will document the solution and publish it on PyPI. Your TriggerCMD is amazing, congratulations!
      Gustavo SoaresG
      Gustavo Soares
    • RE: Boot on Arch
      hi, i also use arch linux (manjaro in my case) and i followed all the steps exactly as presented. Triggercmd keeps running in the background but when it's triggered, it doesn't perform the action (at least not in the foreground). I can see the logs in systemctl showing that it was triggered, but the action does not happen (open a program for example).
      Entered I propose a rather simple solution. I'm using a dropdown terminal (in my case guake) to run the triggercmd in the foreground, but in a way that it's hidden.
      For this solution to work completely, you need to create a script that executes this command:
      guake -e "node ~/TRIGGERcmd-Agent/src/agent.js --console" -r "triggercmd" &
      the -r flag is just to rename the guake tab.
      add a sleep 20 a line before the command to ensure that it will run with some delay and avoid any possible problems.
      The script looks like this:
      #!/bin/bash
      echo "Iniciando..."
      sleep 20
      then you can create a triggercmd-agent.desktop file in .config/autostart.
      inside the file inform this:
      [Desktop Entry]
      Encoding=UTF-8
      Version=0.9.4
      Type=Application
      Name=TriggerCMD Agent
      Comment=initialize triggercmd agent
      Exec=sh -c "~/<path_to_script>/<script>.sh"
      OnlyShowIn=XFCE;
      RunHook=0
      StartupNotify=true
      Terminal=false
      hidden=false
      done that, when logging in, an instance of guake will be started that executes the command to open the triggercmd, all in a hidden way.
      The main reason for this solution is that, at least for me, running triggercmd in the background doesn't work.
      I'm also developing a CLI to create, edit, list and remove commands in a friendlier way, since in arch linux it's not yet possible to run the triggercmd graphical interface.
      triggercmd command list
      triggercmd command new
      Gustavo SoaresG
      Gustavo Soares
