@Russ, very good. I think applying a decode('utf-8') should solve this problem. I really hadn't tried using special characters yet.
RE: Boot on Arch
RE: Boot on Arch
@Russ I think very nice this resource of panels, I just use this. Could be intersting in cards shape (for example), would be very beatiful and pleasant. I am thinking too that you can create a dashboard, and the data of runs could be showed there in graphics shape
And if you have more ideas and features for the CLI, feels free open pull requests if possible.
RE: Boot on Arch
@Russ, strange, a friend of mine uses ubuntu and managed to install normally. I'm going to create a ubuntu virtual machine and try this. Thanks for the feedback.
[offtopic] I see here that you have a PWA, very nice!! Congratulations, I really liked it.
RE: Boot on Arch
Hi @Russ, I finish to publish a package on PyPi. Feel free to test and submit your contributions. To access click here.
RE: Boot on Arch
@Russ thank you very much for the feedback, I will publish it, it's already on my GitHub (see here). This week I will document the solution and publish it on PyPI. Your TriggerCMD is amazing, congratulations!
RE: Boot on Arch
hi, i also use arch linux (manjaro in my case) and i followed all the steps exactly as presented. Triggercmd keeps running in the background but when it's triggered, it doesn't perform the action (at least not in the foreground). I can see the logs in systemctl showing that it was triggered, but the action does not happen (open a program for example).
Entered I propose a rather simple solution. I'm using a dropdown terminal (in my case guake) to run the triggercmd in the foreground, but in a way that it's hidden.
For this solution to work completely, you need to create a script that executes this command:
guake -e "node ~/TRIGGERcmd-Agent/src/agent.js --console" -r "triggercmd" &the -r flag is just to rename the guake tab.
add a
sleep 20a line before the command to ensure that it will run with some delay and avoid any possible problems.The script looks like this:
#!/bin/bash echo "Iniciando..." sleep 20 guake -e "node ~/TRIGGERcmd-Agent/src/agent.js --console" -r "triggercmd" &then you can create a
triggercmd-agent.desktopfile in.config/autostart.inside the file inform this:
[Desktop Entry] Encoding=UTF-8 Version=0.9.4 Type=Application Name=TriggerCMD Agent Comment=initialize triggercmd agent Exec=sh -c "~/<path_to_script>/<script>.sh" OnlyShowIn=XFCE; RunHook=0 StartupNotify=true Terminal=false hidden=falsedone that, when logging in, an instance of guake will be started that executes the command to open the triggercmd, all in a hidden way.
The main reason for this solution is that, at least for me, running triggercmd in the background doesn't work.
I'm also developing a CLI to create, edit, list and remove commands in a friendlier way, since in arch linux it's not yet possible to run the triggercmd graphical interface.
triggercmd command list
triggercmd command new
