    2. Royher Figuera
    Royher FigueraR Offline
    • Posts 18
    • RE: TRIGGERcmd mobile app on the Google Play Store
      @Russ said in TRIGGERcmd mobile app on the Google Play Store:
      The TRIGGERcmd mobile app is now on the Google Play Store. Check it out:
      https://play.google.com/store/apps/details?id=com.vandermeyconsulting.triggercmd
      Is still working? because I downloaded it but I can麓t login
      posted in Announcements
      Royher FigueraR
      Royher Figuera
    • RE: Never used parameters before...
      @Russ said in Never used parameters before...:
      @Royher-Figuera, in a .bat file, the syntax for a parameter is %1 for the first parameter, and %2 for the second parameter, etc.
      So you could make a simple batch file that google's something like this:
      start https://www.google.com/search?q=%1
      @Russ Yes, my mistake.
      I have a error in my .bat file with a "$" and "%". I compare with my google.bat and this is ok and modified the another files.
      Thank You
      Royher FigueraR
      Royher Figuera
      Hi @Russ I'm back again...
      Again when I make a searching, the results are the variables of my .bat file.
      For example
      https://www.farmatodo.com.ve/buscar?producto=**$10$20$30$4**&departamento=Todos&filtros=
      https://www.youtube.com/results?search_query=**$10$20$30$4**
      https://www.cinecalidad.is/?s=**$10$20$30$4**
      Before was go Well
      Can You Check, please?
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera, good question. No, that's not possible. The preguntarle a Ejecuta Comando part tells Google Assistant to use TRIGGERcmd, and the part after that tells TRIGGERcmd what to do. I know it's a lot to say. That's why I like the Smart Home version better, but I know that only allows on or off as parameters.
      Wow, 馃槥 It麓s a lot to say...
      But is a good reason to diggin about...
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera, ok, please try it now. I made the change.
      @Russ is working now...
      But, one question. We only can say "Ok Google, preguntarle a Ejecuta Comando ejecutar b煤squeda con el par谩metro X" ?, the long version?
      It麓s not posible only say "Ok google, ejecutar* b煤squeda con par谩metro X" ?
      Royher FigueraR
      Royher Figuera
      @Russ When I say this:
      "Ok Google, preguntarle a Ejecuta Comando ejecutar b煤squeda con el par谩metro X."
      Google Home says
      "Lo siento, no puedo ayudarte con eso"
      Thanks again, and let me know When I can try again
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera, thank you! I think I can fix this. I'll try this weekend and ask you to test it.
      EDIT:
      @Royher-Figuera, I think I see the problem.
      When you said, "ejecuta en PC b煤squeda con par谩metros reggaet贸n"
      Google sent these parameters:
      trigger = ejecuta
      command = b煤squeda
      params = reggaet贸n
      If you had said, "ejecuta b煤squeda con par谩metros reggaet贸n" I think it would have worked.
      When I tried that, Google sent these parameters:
      trigger = b煤squeda
      params = reggaet贸n
      "ejecuta en PC b煤squeda" is not one of the valid patterns.
      Hi @Russ still having issues... I try both cases, but google home need a name pc to execute the trigger. Google Home麓s listen "Busqueda" like my pc name, when I use your recommendation. It麓s saying " no se ha encontrado un ordenador con ese nombre b煤squeda" (a computer with that name was not found B煤squeda).
      If I have my default PC (PC) Why It麓s still taken my trigger like a PCname
      Edit:
      I try first "Ok Google, hablar con ejecuta comando" and then "ejecuta B煤squeda en PC con parametro X" ... and the search in youtube was sucedeed.
      When I use "Ok Google, hablar a Ejecuta Comando ejecutar B煤squeda con par谩metro X" ... is failing*
      This line error nocomputercalledprefix = "No se ha encontrado un ordenador con ese nombre."
      I will be doing tests and will comment...
      Royher FigueraR
      Royher Figuera
      @Russ I follow your instructions and this is the result:
      My native language is spanish
      Google Home mini says:
      no se ha encontrado un ordenador con ese nombre busqueda (a computer with that name was not found search)
      Google home listen my trigger (busqueda) like my computer name
      Royher FigueraR
      Royher Figuera
      @Xander, you can set your default computer in your profile. Click your name in the in the upper-right to find your profile.
      You don't have to say the "... on my computer ..." part when it's your default computer.
      @Russ I set my default pc but when I try to run a trigger with parameters google home insists in say which PC run the trigger
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera said in Never used parameters before...:
      @Russ I try 2 times, with params nothing happens and without params open youtube...
      @Russ I was find my error... In GUI command editor I forgot a final quotation marks. Sorry and thank You...
      Royher FigueraR
      Royher Figuera
      Royher FigueraR
      Royher Figuera
      @Russ I made the changes to search videos on youtube following your instructions but my params (%1) can麓t connect with my browser. I'm missing something?
      "C:\Users\xxx.TRIGGERcmdData\Youtube.bat
      .BAT
      start https://www.youtube.com/results?search_query=%1
      "trigger": "Youtube2",
      "command": ""C:\Users\xxx\.TRIGGERcmdData\Youtube.bat",
      "ground": "foreground",
      "voice": "busqueda",
      "voiceReply": "Abriendo Youtube PC",
      "allowParams": "true"
      Royher FigueraR
      Royher Figuera
    • RE: need help
      @Sync-Crazy Yes you can. Search in the forum.
      Here my examples:
      Close apps
      "trigger": "Cerrar Calculadora",
      "command": "taskkill /f /im Calculator.exe",
      "voice": "Cerrar Calculadora",
      "voiceReply": "Cerrando Calculadora"
      Restart
      "trigger": "Reiniciar en 10 segundos",
      "command": "shutdown /r /t 10",
      "ground": "background",
      "voice": "Reiniciar",
      "voiceReply": "Reiniciar Desktop"
      Royher FigueraR
      Royher Figuera
    • RE: Open YouTube In Chrome, Search and Play Result Fullscreen
      @A-McF / @russ I'm interest in this script but I don't know how start. I made a file .vbs with your code but won麓t run and I don麓t know how configure triggercmd with that. I supose the trigger is the file and the param is "the search". I麓m correct?
      Royher FigueraR
      Royher Figuera
    • RE: My wife always says Thank You to Alexa :)
      @Russ Jajajaja, that's happens... my father says thank you Alexa too and thank you google.
      Royher FigueraR
      Royher Figuera
    • RE: Windows 10 32 bits cant Install
      @Russ Hi Russ, I made all the steps but I can麓t run any triggers from website or alexa.
      This is the triggercmdagent.bat running:
      C:\Users\Royher.TRIGGERcmdData>node "C:\Users\Royher.TRIGGERcmdData\agent" --console
      Daemon install: false
      Logging in with saved token.
      Checking if the null computer exists.
      This computer was deleted from your account. Login to recreate it.
      prompt: token:
      I paste my token and says that is saved for the next time. And close it.
      I'm using Win 32 bits in spanish by the way.
      Thank you in advance.
      Royher FigueraR
      Royher Figuera
      @Russ Thank you for supporting me. I'll try the procedure and will write you.
      Royher FigueraR
      Royher Figuera
    • Windows 10 32 bits cant Install
      Hi, I can't install triggercmd in my laptop dell with windows 32 bits. It says Installation has failed. There was an error while installing the application.
      Here is the log file:
      2020-07-16 00:27:49> Program: Starting Squirrel Updater: --install .
      2020-07-16 00:27:49> Program: Starting install, writing to C:\Users\Royher\AppData\Local\SquirrelTemp
      2020-07-16 00:27:49> Program: About to install to: C:\Users\Royher\AppData\Local\TRIGGERcmdAgent
      2020-07-16 00:27:50> CheckForUpdateImpl: Couldn't write out staging user ID, this user probably shouldn't get beta anything: System.IO.DirectoryNotFoundException: No se puede encontrar una parte de la ruta de acceso 'C:\Users\Royher\AppData\Local\TRIGGERcmdAgent\packages.betaId'.
      en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
      en System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
      en System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
      en System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
      en System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
      en System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
      en System.IO.File.WriteAllText(String path, String contents, Encoding encoding)
      en Squirrel.UpdateManager.CheckForUpdateImpl.getOrCreateStagedUserId()
      2020-07-16 00:27:50> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: No se puede encontrar una parte de la ruta de acceso 'C:\Users\Royher\AppData\Local\TRIGGERcmdAgent\packages\RELEASES'.
      en System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
      en Squirrel.Utility.LoadLocalReleases(String localReleaseFile)
      en Squirrel.UpdateManager.CheckForUpdateImpl.<CheckForUpdate>d__2.MoveNext()
      2020-07-16 00:27:50> CheckForUpdateImpl: Reading RELEASES file from C:\Users\Royher\AppData\Local\SquirrelTemp
      2020-07-16 00:27:50> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
      2020-07-16 00:27:52> ApplyReleasesImpl: Writing files to app directory: C:\Users\Royher\AppData\Local\TRIGGERcmdAgent\app-1.0.22
      2020-07-16 00:30:07> LogHost: Rigging execution stub for TRIGGERcmdAgent_ExecutionStub.exe to C:\Users\Royher\AppData\Local\TRIGGERcmdAgent\TRIGGERcmdAgent.exe
      2020-07-16 00:30:11> ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\Royher\AppData\Local\TRIGGERcmdAgent\app-1.0.22\TRIGGERcmdAgent.exe]
      2020-07-16 00:30:11> ApplyReleasesImpl: Couldn't run Squirrel hook, continuing: C:\Users\Royher\AppData\Local\TRIGGERcmdAgent\app-1.0.22\TRIGGERcmdAgent.exe: System.ComponentModel.Win32Exception (0x80004005): El ejecutable especificado no es una aplicaci贸n v谩lida para esta plataforma de sistema operativo.
      en System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
      en System.Diagnostics.Process.Start()
      en System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
      en Squirrel.Utility.<InvokeProcessAsync>d__11.MoveNext()
      --- Fin del seguimiento de la pila de la ubicaci贸n anterior donde se produjo la excepci贸n ---
      en System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
      en System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
      en Squirrel.UpdateManager.ApplyReleasesImpl.<>c__DisplayClass10_0.<<invokePostInstall>b__0>d.MoveNext()
      2020-07-16 00:30:11> IEnableLogger: Failed to invoke post-install: System.ComponentModel.Win32Exception (0x80004005): El ejecutable especificado no es una aplicaci贸n v谩lida para esta plataforma de sistema operativo.
      en System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
      en Squirrel.UpdateManager.ApplyReleasesImpl.<>c.<invokePostInstall>b__10_6(ProcessStartInfo info)
      en Squirrel.EnumerableExtensions.ForEach[TSource](IEnumerable1 source, Action1 onNext)
      en Squirrel.UpdateManager.ApplyReleasesImpl.<invokePostInstall>d__10.MoveNext()
      en Squirrel.Utility.<LogIfThrows>d__42.MoveNext()
      2020-07-16 00:30:12> Unhandled exception: System.AggregateException: Se han producido uno o varios errores. ---> System.ComponentModel.Win32Exception: El ejecutable especificado no es una aplicaci贸n v谩lida para esta plataforma de sistema operativo.
      en System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
      en Squirrel.UpdateManager.ApplyReleasesImpl.<ApplyReleases>d__2.MoveNext()
      en Squirrel.UpdateManager.<FullInstall>d__10.MoveNext()
      en Squirrel.Update.Program.<Install>d__4.MoveNext()
      --- Fin del seguimiento de la pila de la excepci贸n interna ---
      en System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
      en System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
      en System.Threading.Tasks.Task.Wait()
      en Squirrel.Update.Program.executeCommandLine(String[] args)
      en Squirrel.Update.Program.main(String[] args)
      ---> (N潞 de excepci贸n interna 0) System.ComponentModel.Win32Exception (0x80004005): El ejecutable especificado no es una aplicaci贸n v谩lida para esta plataforma de sistema operativo.
      en Squirrel.Update.Program.<Install>d__4.MoveNext()<---
      Royher FigueraR
      Royher Figuera
