    2. Royher Figuera
    • Posts 18
    • Best 1
    Royher Figuera
    @Royher Figuera
    Royher Figuera Unfollow Follow
    Best posts made by Royher Figuera
    • RE: need help
      @Sync-Crazy Yes you can. Search in the forum.
      Here my examples:
      Close apps
      "trigger": "Cerrar Calculadora",
      "command": "taskkill /f /im Calculator.exe",
      "ground": "foreground",
      "voice": "Cerrar Calculadora",
      "voiceReply": "Cerrando Calculadora"
      Restart
      "trigger": "Reiniciar en 10 segundos",
      "command": "shutdown /r /t 10",
      "ground": "background",
      "voice": "Reiniciar",
      "voiceReply": "Reiniciar Desktop"
      Royher FigueraR
      Royher Figuera
    Latest posts made by Royher Figuera
    • RE: TRIGGERcmd mobile app on the Google Play Store
      @Russ said in TRIGGERcmd mobile app on the Google Play Store:
      The TRIGGERcmd mobile app is now on the Google Play Store. Check it out:
      https://play.google.com/store/apps/details?id=com.vandermeyconsulting.triggercmd
      Is still working? because I downloaded it but I can´t login
      posted in Announcements
      Royher FigueraR
      Royher Figuera
    • RE: Never used parameters before...
      @Russ said in Never used parameters before...:
      @Royher-Figuera, in a .bat file, the syntax for a parameter is %1 for the first parameter, and %2 for the second parameter, etc.
      So you could make a simple batch file that google's something like this:
      start https://www.google.com/search?q=%1
      @Russ Yes, my mistake.
      I have a error in my .bat file with a "$" and "%". I compare with my google.bat and this is ok and modified the another files.
      Thank You
      Royher FigueraR
      Royher Figuera
      Hi @Russ I'm back again...
      Again when I make a searching, the results are the variables of my .bat file.
      For example
      https://www.farmatodo.com.ve/buscar?producto=$10$20$30$4&departamento=Todos&filtros=
      https://www.youtube.com/results?search_query=$10$20$30$4
      https://www.cinecalidad.is/?s=$10$20$30$4
      Before was go Well
      Can You Check, please?
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera, good question. No, that's not possible. The preguntarle a Ejecuta Comando part tells Google Assistant to use TRIGGERcmd, and the part after that tells TRIGGERcmd what to do. I know it's a lot to say. That's why I like the Smart Home version better, but I know that only allows on or off as parameters.
      Wow, 😞 It´s a lot to say...
      But is a good reason to diggin about...
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera, ok, please try it now. I made the change.
      @Russ is working now...
      But, one question. We only can say "Ok Google, preguntarle a Ejecuta Comando ejecutar búsqueda con el parámetro X" ?, the long version?
      It´s not posible only say "Ok google, ejecutar* búsqueda con parámetro X" ?
      Royher FigueraR
      Royher Figuera
      @Russ When I say this:
      "Ok Google, preguntarle a Ejecuta Comando ejecutar búsqueda con el parámetro X."
      Google Home says
      "Lo siento, no puedo ayudarte con eso"
      Thanks again, and let me know When I can try again
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera, thank you! I think I can fix this. I'll try this weekend and ask you to test it.
      EDIT:
      @Royher-Figuera, I think I see the problem.
      When you said, "ejecuta en PC búsqueda con parámetros reggaetón"
      Google sent these parameters:
      trigger = ejecuta
      command = búsqueda
      params = reggaetón
      If you had said, "ejecuta búsqueda con parámetros reggaetón" I think it would have worked.
      When I tried that, Google sent these parameters:
      trigger = búsqueda
      params = reggaetón
      "ejecuta en PC búsqueda" is not one of the valid patterns.
      Hi @Russ still having issues... I try both cases, but google home need a name pc to execute the trigger. Google Home´s listen "Busqueda" like my pc name, when I use your recommendation. It´s saying " no se ha encontrado un ordenador con ese nombre búsqueda" (a computer with that name was not found Búsqueda).
      If I have my default PC (PC) Why It´s still taken my trigger like a PCname
      Edit:
      I try first "Ok Google, hablar con ejecuta comando" and then "ejecuta Búsqueda en PC con parametro X" ... and the search in youtube was sucedeed.
      When I use "Ok Google, hablar a Ejecuta Comando ejecutar Búsqueda con parámetro X" ... is failing*
      This line error nocomputercalledprefix = "No se ha encontrado un ordenador con ese nombre."
      I will be doing tests and will comment...
      Royher FigueraR
      Royher Figuera
      @Russ I follow your instructions and this is the result:
      My native language is spanish
      Google Home mini says:
      no se ha encontrado un ordenador con ese nombre busqueda (a computer with that name was not found search)
      Google home listen my trigger (busqueda) like my computer name
      Royher FigueraR
      Royher Figuera
      @Xander, you can set your default computer in your profile. Click your name in the in the upper-right to find your profile.
      You don't have to say the "... on my computer ..." part when it's your default computer.
      @Russ I set my default pc but when I try to run a trigger with parameters google home insists in say which PC run the trigger
      Royher FigueraR
      Royher Figuera
      @Royher-Figuera said in Never used parameters before...:
      @Russ I try 2 times, with params nothing happens and without params open youtube...
      @Russ I was find my error... In GUI command editor I forgot a final quotation marks. Sorry and thank You...
      Royher FigueraR
      Royher Figuera
