    Never used parameters before...
    25 Posts 4 Posters 9.6k Views 1 Watching
    • Royher FigueraR Offline
      Royher Figuera
      @Russ I follow your instructions and this is the result:
      My native language is spanish
      Google Home mini says:
      no se ha encontrado un ordenador con ese nombre busqueda (a computer with that name was not found search)
      Google home listen my trigger (busqueda) like my computer name
        Russ @Royher Figuera
        @Royher-Figuera, thank you! I think I can fix this. I'll try this weekend and ask you to test it.
        EDIT:
        @Royher-Figuera, I think I see the problem.
        When you said, "ejecuta en PC búsqueda con parámetros reggaetón"
        Google sent these parameters:
        trigger = ejecuta
        command = búsqueda
        params = reggaetón
        If you had said, "ejecuta búsqueda con parámetros reggaetón" I think it would have worked.
        When I tried that, Google sent these parameters:
        trigger = búsqueda
        params = reggaetón
        "ejecuta en PC búsqueda" is not one of the valid patterns.
        Royher FigueraR 1 Reply Last reply Reply Quote 0
          Royher Figuera @Russ
          @Russ said in Never used parameters before...:
          EDIT:
          trigger = ejecuta
          command = búsqueda
          params = reggaetón
          trigger = búsqueda
          params = reggaetón
          Hi @Russ still having issues... I try both cases, but google home need a name pc to execute the trigger. Google Home´s listen "Busqueda" like my pc name, when I use your recommendation. It´s saying " no se ha encontrado un ordenador con ese nombre búsqueda" (a computer with that name was not found Búsqueda).
          If I have my default PC (PC) Why It´s still taken my trigger like a PCname
          Edit:
          I try first "Ok Google, hablar con ejecuta comando" and then "ejecuta Búsqueda en PC con parametro X" ... and the search in youtube was sucedeed.
          When I use "Ok Google, hablar a Ejecuta Comando ejecutar Búsqueda con parámetro X" ... is failing*
          This line error nocomputercalledprefix = "No se ha encontrado un ordenador con ese nombre."
          I will be doing tests and will comment...
            @Royher-Figuera, what happens when you do this?
            "Ok Google, preguntarle a Ejecuta Comando ejecutar búsqueda con el parámetro X."
            I found your phrases in the history Google gives me to help train it.
            For this one: ejecutar búsqueda con parámetro USB
            It identified búsqueda as a computer instead of the trigger. I changed that in the training. I did the same for a few of your other phrases too. I hope that helps. The change will take effect after Google approves it in a couple days (hopefully). I submitted for approval just now.
            I also found that google sent trigger = undefined. I can work around that and change the logic so if computer is something but trigger is undefined, it will use the computer value as the trigger. I'm working on that now.
            EDIT: I didn't finish today, but I'll try to finish tomorrow. It's a simple change but I'm running into a deployment problem now.
              @Russ When I say this:
              Google Home says
              "Lo siento, no puedo ayudarte con eso"
              Thanks again, and let me know When I can try again
                @Royher-Figuera, ok, please try it now. I made the change.
                  @Russ is working now...
                  But, one question. We only can say "Ok Google, preguntarle a Ejecuta Comando ejecutar búsqueda con el parámetro X" ?, the long version?
                  It´s not posible only say "Ok google, ejecutar* búsqueda con parámetro X" ?
                    @Royher-Figuera, good question. No, that's not possible. The preguntarle a Ejecuta Comando part tells Google Assistant to use TRIGGERcmd, and the part after that tells TRIGGERcmd what to do. I know it's a lot to say. That's why I like the Smart Home version better, but I know that only allows on or off as parameters.
                      Wow, 😞 It´s a lot to say...
                      But is a good reason to diggin about...
                        Royher Figuera
                        Hi @Russ I'm back again...
                        Again when I make a searching, the results are the variables of my .bat file.
                        For example
                        https://www.farmatodo.com.ve/buscar?producto=**$10$20$30$4**&departamento=Todos&filtros=
                        https://www.youtube.com/results?search_query=**$10$20$30$4**
                        https://www.cinecalidad.is/?s=**$10$20$30$4**
                        Before was go Well
                        Can You Check, please?
                          @Royher-Figuera, in a .bat file, the syntax for a parameter is %1 for the first parameter, and %2 for the second parameter, etc.
                          So you could make a simple batch file that google's something like this:
                          start https://www.google.com/search?q=%1
                            @Russ Yes, my mistake.
                            I have a error in my .bat file with a "$" and "%". I compare with my google.bat and this is ok and modified the another files.
                            Thank You
                            • Ivan KulerI Offline
                              Ivan Kuler
