    Open Specific Netflix Movie with Alexa
    40 Posts 8 Posters 21.9k Views 1 Watching
      Russ @Felipe Guedes
      @Felipe-Guedes, does this site work in Brazil or is this just the english or US version of Alexa web?
      https://alexa.amazon.com/spa/index.html#cards
      I was hoping you could use that site because it's helpful to know what Alexa is hearing.
      Also, if this is too much to ask, no problem, but would you mind sending me a recording of yourself saying, this?
      Alexa, pergunte Execute Comando executar automação com o parâmetro bos baby.
      I might be able to use the recording to "train" Alexa to hear it correctly.
      Thank you for your patience.
      Felipe GuedesF 1 Reply Last reply Reply Quote 0
      • Felipe GuedesF Offline
        Felipe Guedes
        its that !
          Felipe Guedes @Russ
          @Russ How i send you my voice record?
            Russ @Felipe Guedes
            @Felipe-Guedes, you could use one device, like your computer to play it using that play button: 1f596754-56ea-4a76-a7f5-92de54da7f62-image.png ... and use another device, like your phone to record it.
            AdalbertoA 1 Reply Last reply Reply Quote 0
            • AdalbertoA Offline
              Adalberto @Russ
              @Russ Hello, Russ. I didn't get lucky with this javascript here and I have created my own using Python + Selenium. It actually does the same thing. Opens the browser, inserts the credentials, searchs for the movie (parameter), plays it and puts it on fullscreen. If someone is interested, I can share the code.
              But actually, my reply is about the way we talk to Alexa to run the script. I'm from Brazil as well... When I'm using "Execute comando" it doesn't feel natural. Most of it is because the "pergunte" in the beginning. Something more like "Alexa, Execute Comando YYYY com parâmetro XXXX" would feel better.
              The "execute comando" needs to be part of the phrase and not the name of the service to feel more natural.
                André Ricardo da Costa @Adalberto
                @Adalberto eu tenho interesse em testar esse código de puder compartilhar amigo. Muito obrigado.
                  Adalberto @André Ricardo da Costa
                  @André-Ricardo-da-Costa
                  • You will need to install Python and Selenium
                  • Video for reference (PT-BR):
                    • Python: https://www.youtube.com/watch?v=FcfalMf9bRY
                    • Selenium: https://www.youtube.com/watch?v=Ot10qzrb13c (choose the version compatible with your browser)
                  • Remember to put Python on windows PATH (during installation)
                  from selenium import webdriver
                  from selenium.webdriver.common.keys import Keys
                  from selenium.webdriver.common.by import By
                  from selenium.webdriver.support.ui import WebDriverWait
                  from selenium.webdriver.support import expected_conditions as EC
                  import time
                  import sys
                  if len(sys.argv) == 2:
                      movie = sys.argv[1]
                  else:
                      movie = ' '.join(sys.argv[1:])
                  # You can put the chromedriver wherever you want - you can download it from http://seleniumhq.github.io/selenium/docs/api/javascript/
                  PATH = r"C:\chromedriver.exe"
                  # You can select any browser available for Selenium
                  driver = webdriver.Chrome(PATH)
                  #Netflix login initial page
                  driver.get("https://www.netflix.com/br/login")
                  element = driver.find_element_by_name("userLoginId")
                  #Insert your email
                  element.send_keys("netflixacc@gmail.com")
                  time.sleep(0.2)
                  #Insert your password
                  element2 = driver.find_element_by_name("password")
                  element2.send_keys("netflixpassword")
                  time.sleep(0.3)
                  element2.send_keys(Keys.RETURN)
                  time.sleep(2)
                  #Insert your profile name as seen after you log in
                  profile = driver.find_element_by_link_text("netflixprofilename")
                  profile.click()
                  time.sleep(3)
                  search = driver.find_element_by_class_name("searchBox")
                  search.click()
                  time.sleep(1)
                  searchbox = driver.find_element_by_name("searchInput")
                  searchbox.send_keys(movie)
                  time.sleep(0.5)
                  searchbox.send_keys(Keys.RETURN)
                  time.sleep(2)
                  scene = driver.find_element_by_xpath("/html/body/div[1]/div/div/div[1]/div/div[2]/div/div/div/div[2]/div/div/div[1]/div/div/div/div/div/div[1]")
                  scene.click()
                  time.sleep(0.5)
                  submit = driver.find_element_by_xpath("//button[@class='color-primary hasLabel hasIcon ltr-1jnopvq']")
                  submit.click()
                  time.sleep(5)
                  move = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerBack tooltip-button tooltip-button-pos-center tooltip-button-align-right']")
                  move.send_keys(Keys.TAB)
                  time.sleep(0.5)
                  fullscreen = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerFullscreen']")
                  fullscreen.click()
                  On TRIGGERcmd:
                  Trigger: Search on Netflix
                  (EXAMPLE) Command: start C:\PycharmProjects\netflix\netflix.py
                  (You need to put your py file directory)
                  Ground: foreground
                  Voice: netflix
                  Allow parameters: true
                  Portuguese:
                  Activate Execute Comando skill on Alexa app
                  To Alexa: "Alexa, pergunte Execute Comando executar netflix com parâmetro the alienist"
                  English:
                  Activate TRIGGERcmd skill on Alexa app
                  To Alexa: "Alexa, ask TRIGGERcmd to run netflix on the alienist"
                  Any updates I will edit the post. There are things that I want to improve (like the sleep time)
                  ? 1 Reply Last reply Reply Quote 3
                  • DevilsirD Offline
                    Devilsir
                    plz, everything worked fine, but seach bar isnt working :(, what can i do?
                    DevilsirD 1 Reply Last reply Reply Quote 0
                    • DevilsirD Offline
                      Devilsir @Devilsir
                      @Devilsir alexa cnt recognize "parametro" commands, if i tell her turn on "netflix" it works, but without parameters
                        [[global:former-user]] @Adalberto
                        @AdalbertUma pergunta, eu uso python, quando procuro que o argumento está vazio, você poderia me ajudar com qual seria o problema, por favor
                          @Nico-Ramirez, Google Translate translated what you said to this:
                          Question, I use python, when I make sure that the argument is empty, could you help me with what serious or problem, please
                          I'm not sure what the problem is. Please clarify.
