    Error
    9 Posts 5 Posters 2.6k Views
    • L Offline
      Lexar's
      Re: Open Specific Netflix Movie with Alexa
      @Russ can you help me error? usb_device_handle_win.cc:1050 Failed to read descriptor from node connection: A opera o de E/S foi anulada devido a uma sa da de thread ou a uma requisi o de aplicativo. (0x3E3)
        Russ @Lexar's
        @lexar-s, how are you getting that error? Are you using selenium?
        Google translated that as, "The I/O operation was aborted due to a thread exit or an application request. (0x3E3)"
        • L Offline
          Lexar's @Russ
          @russ said in Error:
          @Russ Yes, I am but when I put the PATH path "C:\Users\Lexar's\Documents\ChromeDriver\ChromeDriver.exe" it doesn't work and when I leave it (PATH) driver = webdriver.Chrome(PATH) it works, but with USB error The I/O operation was aborted due to a thread exit or an application request. (0x3E3
          [7688:10380:0128/113046.882:ERROR:chrome_browser_main_extra_parts_metrics.cc(227)] START: ReportBluetoothAvailability(). If you don't see the END: message, this is crbug.com/1216328.
          [7688:10380:0128/113046.882:ERROR:chrome_browser_main_extra_parts_metrics.cc(230)] END: ReportBluetoothAvailability()
          [7688:10380:0128/113046.885:ERROR:chrome_browser_main_extra_parts_metrics.cc(235)] START: GetDefaultBrowser(). If you don't see the END: message, this is crbug.com/1216328.
          [7688:5364:0128/113046.886:ERROR:device_event_log_impl.cc(214)] [11:30:46.886] USB: usb_device_handle_win.cc:1050 Failed to read descriptor from node connection: Um dispositivo conectado ao sistema nÒo estß funcionando. (0x1F)
          [7688:5364:0128/113046.887:ERROR:device_event_log_impl.cc(214)] [11:30:46.887] USB: usb_device_handle_win.cc:1050 Failed to read descriptor from node connection: Um dispositivo conectado ao sistema nÒo estß funcionando. (0x1F)
          [7688:10380:0128/113046.895:ERROR:chrome_browser_main_extra_parts_metrics.cc(239)] END: GetDefaultBrowser()
          What is wrong with my python script?
          • tuicemenT Offline
            tuicemen @Lexar's
            @lexar-s the USB error suggest a driver issue.
            Windows installs what it thinks is the best driver for devices and these are not always the ones that work.
            What USB devices do you have plugged into your PC?
            Perhaps if you posted your full python script it would help @russ or others figure out what else may be a issue.
            • L Offline
              Lexar's @tuicemen
              @tuicemen said in Error:
              Ok'
              from selenium import webdriver
              from selenium.webdriver.common.keys import Keys
              from selenium.webdriver.common.by import By
              from selenium.webdriver.support.ui import WebDriverWait
              from selenium.webdriver.support import expected_conditions as EC
              import time
              import sys
              if len(sys.argv) == 2:
                  movie = sys.argv[1]
              else:
                  movie = ' '.join(sys.argv[1:])
              PATH = r"C:\Users\Lexar's\Documents\ChromeDriver\ChromeDriver.exe"
              driver.get("https://www.netflix.com/br/login")
              element = driver.find_element_by_name("userLoginId")
              element.send_keys("netflix@gmail.com")
              time.sleep(0.2)
              element2 = driver.find_element_by_name("password")
              element2.send_keys("netflix")
              time.sleep(0.3)
              element2.send_keys(Keys.RETURN)
              time.sleep(2)
              profile = driver.find_element_by_link_text("TELA02")
              profile.click()
              time.sleep(3)
              search = driver.find_element_by_class_name("searchBox")
              search.click()
              time.sleep(1)
              searchbox = driver.find_element_by_name("searchInput")
              searchbox.send_keys(movie)
              time.sleep(0.5)
              searchbox.send_keys(Keys.RETURN)
              time.sleep(2)
              scene = driver.find_element_by_xpath("/html/body/div[1]/div/div/div[1]/div/div[2]/div/div/div/div[2]/div/div/div[1]/div/div/div/div/div/div[1]")
              scene.click()
              time.sleep(0.5)
              submit = driver.find_element_by_xpath("//button[@class='color-primary hasLabel hasIcon ltr-1jnopvq']")
              submit.click()
              time.sleep(5)
              move = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerBack tooltip-button tooltip-button-pos-center tooltip-button-align-right']")
              move.send_keys(Keys.TAB)
              time.sleep(0.5)
              fullscreen = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerFullscreen']")
              fullscreen.click()
              Another detail, she doesn't search for the movie or series through the script I made
              L tuicemenT 2 Replies Last reply Reply Quote 0
              • L Offline
                Lexar's @Lexar's
                @tuicemen or @Russ can you tell me if there's something wrong with my python script?
                • tuicemenT Offline
                  tuicemen @Lexar's
                  @lexar-s I don't use Selenium, Chrome or Netflix on my PC.
                  However since your getting errors I'd suggest you start by running some tests with Selenium and Chrome to make sure you have that part setup correctly.
                  https://www.browserstack.com/guide/run-selenium-tests-using-selenium-chromedriver
                  • tuicemenT Offline
                    tuicemen @Lexar's
                    @lexar-s you can also refer to this thread for help: https://www.triggercmd.com/forum/topic/115/open-specific-netflix-movie-with-alexa compare your script with the python script posted there.
                    • F Offline
                      fostercarly @tuicemen
                      You can test if it actually is in the Python PATH, if you open a cmd and type in chromedriver and hit Enter. If Starting ChromeDriver 2.15.322448 is appearing, the PATH is set appropriately and there is something else going wrong. Then try the following:
                      Download ChromeDriver
                      Then you have multiple options:
                      • Add it to your system path
                      • Put it in the same directory as your python script
                      • Specify the location directly via executable_path
                      driver = webdriver.Chrome(executable_path='C:/path/to/chromedriver.exe')
                      Before you add the chromedriver to your path, make sure it's the same version as your browser.
                      If not, you will need to match versions: either update/downgrade you chrome, and upgrade/downgrade your webdriver.
