    2. André Ricardo da Costa
    • Following 2
    • Posts 20
    • Best 3
    @André Ricardo da Costa
    André Ricardo da Costa Unfollow Follow
    Best posts made by André Ricardo da Costa
    • RE: Cant Install Triggercmd Notebook - Squirrelsetup
      @Russ I used the commands using your suggestions and the Zoom Mettings application worked fine on Windows 10 32 bits. I made a configuration so that every time the computer turns on, it will automatically open the CDM Trigger so that I can do the commands. Thank you very much for your help. I put a comment on the video https://www.youtube.com/watch?v=FTxIabp8CRg&t=9s indicating the forum for those who want to install the TriggerCMD program on a 32-bit PC. I will now try to install TriggerCMD on RaspberryPI.
      {"trigger":"Reboot in 10 seconds","command":"shutdown /r /t 10","ground":"background","voice":"reboot"},
      {"trigger":"Calculator","command":"calc","ground":"foreground","voice":"calculator"},
      {"trigger":"Notepad","command":"notepad","ground":"foreground","voice":"notepad"},
      {"trigger":"Zoom","command":"%userprofile%\AppData\Roaming\Zoom\bin\Zoom.exe", "ground": "foreground", "voice": "zoom","ground":"foreground","voice":"zoom"},
      {"trigger":"Chrome","command":"start chrome","ground":"foreground","voice":"chrome"},
      {"trigger":"Explorer","command":"explorer","ground":"foreground","voice":"explorer"},
      {"trigger":"Wmplayer","command":"wmplayer","ground":"foreground","voice":"wmplayer"},
      {"trigger":"Mspaint","command":"mspaint","ground":"foreground","voice":"mspaint"},
      {"trigger":"Microsoftedge","command":"start microsoftedge","ground":"foreground","voice":"microsoftedge"},
      {"trigger":"Vlc","command":"start vlc","ground":"foreground","voice":"vlc"}
      André Ricardo da CostaA
    • RE: Need a command to open apps on my pc, like games, Spotify or Netflix! Its URGENT
      @Russ Nice! I used the same method and managed to make the WhatsApp Desktop application downloaded from the Windows Store open by Alexa's voice command. And this is helpful, as I use whatsapp a lot on the web. I will continue testing other functions of the Trigger CMD ! Thank you!
    • RE: Start Whatsapp on PC
      @juank-rojas Press [Windows]+R, type shell:AppsFolder in the Open text box and you will find all shortcuts of installed applications. Then you copy the whatsapp shortcut to the desktop of your computer. Then click with the right mouse button and copy the "Local" which will look something like this: “C:\Users\replace as your username\Desktop\WhatsApp.lnk”. Then with this path you create it in Trigger and it works. In my case it worked! See the post: Need a command to open apps on my pc, like games, Spotify or Netflix! Its URGENT | TRIGGERcmd Forum
    Latest posts made by André Ricardo da Costa
    • RE: Ligar PC
      @FantasmaJF Veja esse tutorial: https://www.youtube.com/watch?v=2ybc7ObLosI Eu fiz no meu e deu certo. Geralmente, funciona melhor em Desktop. Tomara que seja de ajuda. Vlw!
    • RE: Alexa doesn't find the commands
      @gtrento No meu deu certo de ligar o PC por meio da WAKE ON LAN, seguindo o passo a passo do vídeo https://www.youtube.com/watch?v=UCyC-LjA9p8 e além disso, precisei fazer um passo a mais para funcionar, foi fazer o seguinte: Painel de Controle-> Hardware e Sons->Opções de Energia -> Escolher a função dos botões de energia -> configuração de desligamento -> desmarcar a primeira opção "ligar inicialização rápida". Outra coisa a se fazer é atualizar a placa de rede. Espero que dê certo. vlw.
      @gtrento Amigo: Eu sou brasileiro também e posso te dar alguma ajuda. Faça assim, crie uma rotina no app Alexa e coloque desligar Pc ou algo de sua preferência. Na ação adicione o dispositivo "shut down" e clique em salvar. Para achar qualquer comando do Trigger CMD procure por dispositivo de casa inteligente em "todos os dispositivos" O meu ficou assim nesse caso. Se você criar o comando no Trigger em português a Alexa vai reconhecer e não necessariamente vai precisar criar uma rotina para cada comando do Trigger. E mais para os comandos em inglês que o Trigger já tem pré-configuradoScreenshot_2020-12-06-16-49-26-270_com.amazon.dee.app.jpg
    • RE: Problem updating programTrigger CMD
      @Russ I did what you recommended and it worked. I managed to reinstall the program. But, I'm still having problems when I'm going to update and even turning off the anti-virus software. I'm going to try it again today and if I can't, I'll send a printout of the error message that appears. Thank you
    • Problem updating programTrigger CMD
      @Russ I have been trying to update the Trigger CMD program for two weeks and I have not been able to, as an error message appears. I have it again today and the problem continued to the point of "uninstalling the program" or it seems to have disappeared with the shortcut on my desktop. I managed to save a copy of the settings and then I tried to download the program again from the Trigger CMD website and even then the problem persists and I can't reinstall the program. See the error message that appears. Can you help me? Thank you.problem.PNG
    • RE: Open Specific Netflix Movie with Alexa
      @Adalberto eu tenho interesse em testar esse código de puder compartilhar amigo. Muito obrigado.
    • How can use the ZOOM Meetings app meetings with the Trigger CMD?
      Because of the pandemic (COVID-19), the Zoom Meetings app (https://zoom.us/) has been used a lot to hold meetings, courses, training. I use the Zoom app every week, at least twice. Since we have regular meetings, we use the same link every week to hold those meetings. As I use Trigger CDM to connect other programs on my computer, I found a way to connect ZOOM already in the meeting scheduled through the Trigger CMD and Echo Dot (Alexia) In my case I just say: “Alexa, start the meeting ”That Deskop then starts (I use WAKE ON LAN) and then the monitor and the HDMI 2 input (I use the Broadlink RM4 Pro) and with the help of the CMD Trigger program it opens the ZOOM at the scheduled meeting of the day.
      1. Create a shortcut to your zoom exe. It should be in %APPDATA%\Zoom\bin\Zoom.exe
      2. Open the shortcut properties and edit the "Target" field.
      3. Go down after the EXE and add (with the quotes) "--url=zoommtg://zoom.us/join?action=join&confno=<your_conference_number>"
        If you have a password, it is hashed so you will need to launch the meeting once in the browser and copy it out. Once you have your hashed password, add &pwd=<hashed_password> after your conference number (with no spaces).
      Just an example of what it would look like for you to configure and of course using your computer's settings. In example 1 you can open the meeting directly in the zoom application and using the link with the password embedded in it. For this you will have to make a command using your computer and meeting settings similar to example 1 below and put in “Command” inside the Trigger CMD program.
      1. "C:\Users\User\AppData\Roaming\Zoom\bin\Zoom.exe" "--url = zoommtg://zoom.us/join?Action=join&confno=5283605748?Pwd=cjJpeVYxYlVwbXJHU0JIKzZHNXRsZz09”
        (These codes you get when you generate a meeting in ZOOM when you include the password in the link)
      Or if you want to configure ZOOM using the Chrome browser it will open in the Chrome browser or it will direct you directly to the application and that if the meeting has a password you will have to enter it manually.
      1. "C:\Program Files (x86)\Google\Chrome\chrome.exe" (After the exe quotes leave a space and then the corresponding address of your meeting) https://jworg.zoom.us/j/91521687498
        (These numbers represent your meeting ID)
      I hope I can help. Thank you.
      @Russ I followed the instructions you sent and managed to get the JW Library app to open with Alexa. At first I had some difficulty creating the shortcut because it didn't work to click on the CTRL and then drag. (Microsoft store application shortcuts are "hidden") But I was able to find the JW Library application shortcut by opening the Run command and then typing "shell: AppsFolder" (without the quotes) into the "Open" field. Then, click on the "OK" button; and with that I managed to find all the shortcuts. Two open a folder and paste the shortcut in that folder as you gave the suggestion and it worked! Thank you very much. Now I have a 64-bit computer and able to test the CMD Trigger in different ways!!
