    Open Specific Netflix Movie with Alexa
    40 Posts 8 Posters 22.7k Views 1 Watching
      Russ @Felipe Guedes
      @Felipe-Guedes, does this work?
      Alexa, pergunte Execute Comando execute automacao com o parâmetro boss baby.
      I think I need to fix the portuguese text on the voice command cheat sheet page.
      EDIT: I updated that voice command cheat sheet page. I hope that works better.
      Felipe GuedesF 1 Reply Last reply Reply Quote 0
      • Felipe GuedesF Offline
        Felipe Guedes @Russ
        @Russ it's doesn't work.
        No problem
          Russ @Felipe Guedes
          @Felipe-Guedes, what does Alexa say back to you?
            Felipe Guedes @Russ
            @Russ I try to say in this order:
            Alexa, Abrir Execute Comando
            Alexa, Execute automação com parâmetro boss baby
            Alexa says: Diga algo como execute a calculadora no laptop, você também pode dizer para se já estiver terminado.
            Other way:
            Alexa, pergunte Execute Comando executar automação com o parâmetro X.
              Russ @Felipe Guedes
              Thank you @Felipe-Guedes! That helps. I found and fixed one problem so far:
              I said, "Alexa, pergunte Execute Comando executar calculadora." and Alexa sent this to my server, which is wrong. The value should have been calculadora, not comando calculadora.
                "name": "Trigger",
                "value": "comando calculadora",
              I've had this problem before. Alexa sends extra words in the trigger field. I fixed that, but I'm not sure that's the problem you were having.
              After that it worked for me. I said, "Alexa, pergunte Execute Comando executar automação com o parâmetro boss baby" and it ran my command and passed "bos baby" as the parameter.
              This is my test command:
              Will you please test again and tell me if that helped?
                Felipe Guedes
                i need to update something?
                  Russ @Felipe Guedes
                  @Felipe-Guedes, no, I updated the code on the server to handle the problem when Alexa sends comando with the trigger word. I'm hoping that solves the problem you're having.
                    Felipe Guedes
                    When i said the command like you said, alexa anwser me a helper to execute the command.
                      Russ @Felipe Guedes
                      @Felipe-Guedes, are you saying Alexa answered this way again?
                      Also, if you go to https://alexa.amazon.com/ you can see the words Alexa thinks you said. Can you copy/paste that here?
                      This is what mine showed:
                        Felipe Guedes
                        Sorry, i don't see this msg.
                        Yes, Alexa answer exactly this.
                          Russ @Felipe Guedes
                          @Felipe-Guedes, does this site work in Brazil or is this just the english or US version of Alexa web?
                          https://alexa.amazon.com/spa/index.html#cards
                          I was hoping you could use that site because it's helpful to know what Alexa is hearing.
                          Also, if this is too much to ask, no problem, but would you mind sending me a recording of yourself saying, this?
                          Alexa, pergunte Execute Comando executar automação com o parâmetro bos baby.
                          I might be able to use the recording to "train" Alexa to hear it correctly.
                          Thank you for your patience.
                            Felipe Guedes
                            its that !
                              Felipe Guedes @Russ
                              @Russ How i send you my voice record?
                                Russ @Felipe Guedes
                                @Felipe-Guedes, you could use one device, like your computer to play it using that play button: 1f596754-56ea-4a76-a7f5-92de54da7f62-image.png ... and use another device, like your phone to record it.
                                AdalbertoA 1 Reply Last reply Reply Quote 0
                                • AdalbertoA Offline
                                  Adalberto @Russ
                                  @Russ Hello, Russ. I didn't get lucky with this javascript here and I have created my own using Python + Selenium. It actually does the same thing. Opens the browser, inserts the credentials, searchs for the movie (parameter), plays it and puts it on fullscreen. If someone is interested, I can share the code.
                                  But actually, my reply is about the way we talk to Alexa to run the script. I'm from Brazil as well... When I'm using "Execute comando" it doesn't feel natural. Most of it is because the "pergunte" in the beginning. Something more like "Alexa, Execute Comando YYYY com parâmetro XXXX" would feel better.
                                  The "execute comando" needs to be part of the phrase and not the name of the service to feel more natural.
                                    André Ricardo da Costa @Adalberto
                                    @Adalberto eu tenho interesse em testar esse código de puder compartilhar amigo. Muito obrigado.
                                      Adalberto @André Ricardo da Costa
                                      @André-Ricardo-da-Costa
                                      • You will need to install Python and Selenium
                                      • Video for reference (PT-BR):
                                        • Python: https://www.youtube.com/watch?v=FcfalMf9bRY
                                        • Selenium: https://www.youtube.com/watch?v=Ot10qzrb13c (choose the version compatible with your browser)
                                      • Remember to put Python on windows PATH (during installation)
                                      from selenium import webdriver
                                      from selenium.webdriver.common.keys import Keys
                                      from selenium.webdriver.common.by import By
                                      from selenium.webdriver.support.ui import WebDriverWait
                                      from selenium.webdriver.support import expected_conditions as EC
                                      import time
                                      import sys
                                      if len(sys.argv) == 2:
                                          movie = sys.argv[1]
                                      else:
                                          movie = ' '.join(sys.argv[1:])
                                      # You can put the chromedriver wherever you want - you can download it from http://seleniumhq.github.io/selenium/docs/api/javascript/
                                      PATH = r"C:\chromedriver.exe"
                                      # You can select any browser available for Selenium
                                      driver = webdriver.Chrome(PATH)
                                      #Netflix login initial page
                                      driver.get("https://www.netflix.com/br/login")
                                      element = driver.find_element_by_name("userLoginId")
                                      #Insert your email
                                      element.send_keys("netflixacc@gmail.com")
                                      time.sleep(0.2)
                                      #Insert your password
                                      element2 = driver.find_element_by_name("password")
                                      element2.send_keys("netflixpassword")
                                      time.sleep(0.3)
                                      element2.send_keys(Keys.RETURN)
                                      time.sleep(2)
                                      #Insert your profile name as seen after you log in
                                      profile = driver.find_element_by_link_text("netflixprofilename")
                                      profile.click()
                                      time.sleep(3)
                                      search = driver.find_element_by_class_name("searchBox")
                                      search.click()
                                      time.sleep(1)
                                      searchbox = driver.find_element_by_name("searchInput")
                                      searchbox.send_keys(movie)
                                      time.sleep(0.5)
                                      searchbox.send_keys(Keys.RETURN)
                                      time.sleep(2)
                                      scene = driver.find_element_by_xpath("/html/body/div[1]/div/div/div[1]/div/div[2]/div/div/div/div[2]/div/div/div[1]/div/div/div/div/div/div[1]")
                                      scene.click()
                                      time.sleep(0.5)
                                      submit = driver.find_element_by_xpath("//button[@class='color-primary hasLabel hasIcon ltr-1jnopvq']")
                                      submit.click()
                                      time.sleep(5)
                                      move = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerBack tooltip-button tooltip-button-pos-center tooltip-button-align-right']")
                                      move.send_keys(Keys.TAB)
                                      time.sleep(0.5)
                                      fullscreen = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerFullscreen']")
                                      fullscreen.click()
                                      On TRIGGERcmd:
                                      Trigger: Search on Netflix
                                      (EXAMPLE) Command: start C:\PycharmProjects\netflix\netflix.py
                                      (You need to put your py file directory)
                                      Ground: foreground
                                      Voice: netflix
                                      Allow parameters: true
                                      Portuguese:
                                      Activate Execute Comando skill on Alexa app
                                      To Alexa: "Alexa, pergunte Execute Comando executar netflix com parâmetro the alienist"
                                      English:
                                      Activate TRIGGERcmd skill on Alexa app
                                      To Alexa: "Alexa, ask TRIGGERcmd to run netflix on the alienist"
                                      Any updates I will edit the post. There are things that I want to improve (like the sleep time)
                                      ? 1 Reply Last reply Reply Quote 3
                                      • DevilsirD Offline
                                        Devilsir
                                        plz, everything worked fine, but seach bar isnt working :(, what can i do?
                                        DevilsirD 1 Reply Last reply Reply Quote 0
                                        • DevilsirD Offline
                                          Devilsir @Devilsir
                                          @Devilsir alexa cnt recognize "parametro" commands, if i tell her turn on "netflix" it works, but without parameters
                                            [[global:former-user]] @Adalberto
                                            @AdalbertUma pergunta, eu uso python, quando procuro que o argumento está vazio, você poderia me ajudar com qual seria o problema, por favor
