    Open Specific Netflix Movie with Alexa
    40 Posts 8 Posters 22.1k Views 1 Watching
    • Felipe GuedesF Offline
      Felipe Guedes
      Yes, i know that.
      Thats my configuration:
      "trigger": "abrir google",
      "command": "node C:\Users\Artista\Documents\node_modules\selenium-webdriver\exemple\google.js",
      "ground": "foreground",
      "voice": "abrir google",
      "voiceReply": "",
      "allowParams": "true"
      And the full path:
      When i run directly in cmd, runs very well like i said, but in trggercmd no.
        Russ @Felipe Guedes
        @Felipe-Guedes, thanks for that info. That helps.
        I'm still thinking it's a problem with the working directory. Node knows how to find module dependencies based on the working directory. Would you mind trying this?
        Create a script called c:\scripts\google.bat with these contents:
        cd /d C:\Users\Artista\Documents\node_modules\selenium-webdriver\exemple
        node google.js
        Then make this your triggercmd command: c:\scripts\google.bat
          Felipe Guedes
          Perfect, now i can execute the command in trigger cmd and i have other problem hhahahahah.
          When i say - "Alexa, Execute comando" -> "Execute automacao com parametro boss baby" -> She don't recognize my command. Isn't an exemple with parameters in portuguese.
          Help me, we almost there !
            Felipe Guedes @Felipe Guedes
            @Felipe-Guedes Otherwise, is this configuration set maximized chrome.
            var chrome = require("selenium-webdriver/chrome");
             * Set chrome command line options/switches
            var chromeOptions = new chrome.Options();
            chromeOptions.addArguments("test-type");
            chromeOptions.addArguments("start-maximized");
            chromeOptions.addArguments("--js-flags=--expose-gc");
            chromeOptions.addArguments("--enable-precise-memory-info");
            chromeOptions.addArguments("--disable-popup-blocking");
            chromeOptions.addArguments("--disable-default-apps");
            chromeOptions.addArguments("--disable-infobars");
            var driver = new Builder()
                .forBrowser('chrome')
                .setChromeOptions(chromeOptions)
                .build();
            I'm still searching how to set full screen in video, and how to stop and play.
            i'll post here when i find
              Russ @Felipe Guedes
              @Felipe-Guedes, does this work?
              Alexa, pergunte Execute Comando execute automacao com o parâmetro boss baby.
              I think I need to fix the portuguese text on the voice command cheat sheet page.
              EDIT: I updated that voice command cheat sheet page. I hope that works better.
              Felipe GuedesF 1 Reply Last reply Reply Quote 0
                Felipe Guedes @Russ
                @Russ it's doesn't work.
                No problem
                  Russ @Felipe Guedes
                  @Felipe-Guedes, what does Alexa say back to you?
                    Felipe Guedes @Russ
                    @Russ I try to say in this order:
                    Alexa, Abrir Execute Comando
                    Alexa, Execute automação com parâmetro boss baby
                    Alexa says: Diga algo como execute a calculadora no laptop, você também pode dizer para se já estiver terminado.
                    Other way:
                    Alexa, pergunte Execute Comando executar automação com o parâmetro X.
                      Russ @Felipe Guedes
                      Thank you @Felipe-Guedes! That helps. I found and fixed one problem so far:
                      I said, "Alexa, pergunte Execute Comando executar calculadora." and Alexa sent this to my server, which is wrong. The value should have been calculadora, not comando calculadora.
                        "name": "Trigger",
                        "value": "comando calculadora",
                      I've had this problem before. Alexa sends extra words in the trigger field. I fixed that, but I'm not sure that's the problem you were having.
                      After that it worked for me. I said, "Alexa, pergunte Execute Comando executar automação com o parâmetro boss baby" and it ran my command and passed "bos baby" as the parameter.
                      This is my test command:
                      Will you please test again and tell me if that helped?
                        Felipe Guedes
                        i need to update something?
                          Russ @Felipe Guedes
                          @Felipe-Guedes, no, I updated the code on the server to handle the problem when Alexa sends comando with the trigger word. I'm hoping that solves the problem you're having.
                            Felipe Guedes
                            When i said the command like you said, alexa anwser me a helper to execute the command.
                              Russ @Felipe Guedes
                              @Felipe-Guedes, are you saying Alexa answered this way again?
                              Also, if you go to https://alexa.amazon.com/ you can see the words Alexa thinks you said. Can you copy/paste that here?
                              This is what mine showed:
                                Felipe Guedes
                                Sorry, i don't see this msg.
                                Yes, Alexa answer exactly this.
                                  Russ @Felipe Guedes
                                  @Felipe-Guedes, does this site work in Brazil or is this just the english or US version of Alexa web?
                                  https://alexa.amazon.com/spa/index.html#cards
                                  I was hoping you could use that site because it's helpful to know what Alexa is hearing.
                                  Also, if this is too much to ask, no problem, but would you mind sending me a recording of yourself saying, this?
                                  Alexa, pergunte Execute Comando executar automação com o parâmetro bos baby.
                                  I might be able to use the recording to "train" Alexa to hear it correctly.
                                  Thank you for your patience.
                                    Felipe Guedes
                                    its that !
                                      Felipe Guedes @Russ
                                      @Russ How i send you my voice record?
                                        Russ @Felipe Guedes
                                        @Felipe-Guedes, you could use one device, like your computer to play it using that play button: 1f596754-56ea-4a76-a7f5-92de54da7f62-image.png ... and use another device, like your phone to record it.
                                        AdalbertoA 1 Reply Last reply Reply Quote 0
                                        • AdalbertoA Offline
                                          Adalberto @Russ
                                          @Russ Hello, Russ. I didn't get lucky with this javascript here and I have created my own using Python + Selenium. It actually does the same thing. Opens the browser, inserts the credentials, searchs for the movie (parameter), plays it and puts it on fullscreen. If someone is interested, I can share the code.
                                          But actually, my reply is about the way we talk to Alexa to run the script. I'm from Brazil as well... When I'm using "Execute comando" it doesn't feel natural. Most of it is because the "pergunte" in the beginning. Something more like "Alexa, Execute Comando YYYY com parâmetro XXXX" would feel better.
                                          The "execute comando" needs to be part of the phrase and not the name of the service to feel more natural.
                                            André Ricardo da Costa @Adalberto
                                            @Adalberto eu tenho interesse em testar esse código de puder compartilhar amigo. Muito obrigado.
