    Raspberry Pi setup
    raspberry pi
    40 Posts 12 Posters 36.5k Views 1 Watching
    • A Offline
      Atmosphere
      • G Offline
        gutopa
        Hi Russ..
        I think those instructions are not valid for the last raspio.
        I've got loads of errors that I am not sure how to solve.
        The following packages have unmet dependencies:
        nodejs : Conflicts: nodejs-legacy but 4.8.2~dfsg-1 is to be installed
        npm : Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
        Depends: node-ansi (>= 0.3.0-2) but it is not going to be installed
        Depends: node-ansi-color-table but it is not going to be installed
        Depends: node-archy but it is not going to be installed
        Depends: node-block-stream but it is not going to be installed
        Depends: node-fstream (>= 0.1.22) but it is not going to be installed
        Depends: node-fstream-ignore but it is not going to be installed
        Depends: node-github-url-from-git but it is not going to be installed
        Depends: node-glob (>= 3.1.21) but it is not going to be installed
        Depends: node-graceful-fs (>= 2.0.0) but it is not going to be installed
        Depends: node-inherits but it is not going to be installed
        Depends: node-ini (>= 1.1.0) but it is not going to be installed
        Depends: node-lockfile but it is not going to be installed
        Depends: node-lru-cache (>= 2.3.0) but it is not going to be installed
        Depends: node-minimatch (>= 0.2.11) but it is not going to be installed
        Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
        Depends: node-gyp (>= 0.10.9) but it is not going to be installed
        Depends: node-nopt (>= 3.0.1) but it is not going to be installed
        Depends: node-npmlog but it is not going to be installed
        Depends: node-once but it is not going to be installed
        Depends: node-osenv but it is not going to be installed
        Depends: node-read but it is not going to be installed
        Depends: node-read-package-json (>= 1.1.0) but it is not going to be installed
        Depends: node-request (>= 2.25.0) but it is not going to be installed
        Depends: node-retry but it is not going to be installed
        Depends: node-rimraf (>= 2.2.2) but it is not going to be installed
        Depends: node-semver (>= 2.1.0) but it is not going to be installed
        Depends: node-sha but it is not going to be installed
        Depends: node-slide but it is not going to be installed
        Depends: node-tar (>= 0.1.18) but it is not going to be installed
        Depends: node-underscore but it is not going to be installed
        Depends: node-which but it is not going to be installed
        E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
          Russ @gutopa
          @gutopa, I want to try to reproduce that error and fix it. Can you tell me what Raspberry Pi and what OS you're running?
          • G Offline
            gutopa
            Thanks Russ..
            I'm using a pi2 B with a fresh install from noob. So I believe it's all the last version of raspbian.
              Russ @gutopa
              Thanks @gutopa.
              My Pi2 B died. I have a Pi 3 but I'll try the latest version of NOOBS/Raspbian on my Pi Zero to hopefully reproduce the problem.
              EDIT: I was able reproduce the problem, and fortunately there's a simple solution. I updated the instructions above.
              I changed this line:
              apt-get -y install npm nodejs-legacy
              To this:
              Thank you for reporting the problem.
              • A Offline
                Atmosphere
                @russ said in Raspberry Pi setup:
                Hi, i'm curious - i use python scripts to trigger my gpio pins on my raspberry... it appears that these are "Foreground" tasks... how do i do this in the background (so that when the pi reboots - it loads automatically again)
                Any tips?
                  Russ @Atmosphere
                  @atmosphere, in your commands.json file, make the ground field background instead of foreground. That way it will run in the context of the background service.
                    "trigger": "GPIO 6 on",
                    "command": "python /root/gpio6on.py",
                    "ground": "background",
                    "voice": "6 on"
                  Run this to install the background service:
                  • G Offline
                    gutopa
                    Hi Russ..
                    Could you give me some tips about how to remove it from raspbian?
                    Thank you
                      Russ @gutopa
                      @gutopa, you could uninstall the Raspberry Pi agent using these commands:
                      apt remove triggercmdagent
                      Then you should delete the computer from your account on the website.
                      • E Offline
                        Erin Leiker
                        hello! my end goal is to launch an html file on my raspberry pi 3b+ using IFTTT (i have a small display plugged into my pi on which i'm expecting to see the file). i'm fairly sure i've gotten everything set up correctly in that i can see evidence of the command having run in IFTTT, my TRIGGERcmd dashboard, and in the CLI when i run "systemctl status triggercmdagent".
                        i have almost no native idea what i am doing, but i'm a pretty good tinkerer and an excellent copy-and-paster so the command i cobbled together is:
                        {"trigger":"myTriggerName","command":"chromium-browser file:///home/pi/myFile.html","ground":"background","voice":"myTriggerName","allowParams":"false"}
                        when i try to trigger that command via IFTTT or my TRIGGERcmd Triggers list, nothing actually happens other than the three locations i mention above showing some acknowledgement that the command was run. but when i run "chromium-browser file:///home/pi/myFile.html" via the CLI, the file opens in chromium exactly as i expect, so this all leads me to believe i have formatted the command incorrectly somehow.
                        any help here would be much appreciated!
                          Russ @Erin Leiker
                          @erin-leiker, I think the problem is you're running the triggercmd agent as a background daemon, and your command is running with "ground": "background", so you can't see the result of your command.
                          So to make it work, you'll need to:
                          1. Run the agent in the foreground by running the "triggercmdagent" command in a terminal window in X Windows.
                          2. Trigger your command in the foreground with "ground": "foreground" in your commands.json file.
                          • E Offline
                            Erin Leiker @Russ
                            @russ thank you for the tips! i did some googling on x windows, and it sounds like it's a way to access or view the pi remotely. do i still need x windows if i have the pi booting to the desktop and i have a screen on it so i can access it directly?
                            i updated the trigger to "foreground" and tried running triggercmdagent from the cli, but still i just see the log of the command having been run instead of the results of the command (opening that html file).
                              Russ @Erin Leiker
                              @erin-leiker, that's interesting. You might need to specify the full path of chromium-browser, so your command would be something like:
                              /path/to/chromium-browser file:///home/pi/myFile.html
                              To find the path, type this:
                              which chromium-browser
                              If you're booting to the GUI, that's X Windows. I'll boot up one of my Pi's and see if I can reproduce the problem you're having.
                              EDIT: I tried it on my Pi. I found that it worked with or without the full path. I tried /usr/bin/chromium-browser and just chromium-browser and both worked for me, so I don't know what's wrong in your case.
                              Can you try a simpler command, like echo Testing >> /tmp/test.txt ?
                              When I did that, it created a /tmp/test.txt file when I remotely ran the command.
                              • E Offline
                                Erin Leiker @Russ
                                @russ whew, i think i figured it out! if i'm right, it all comes down to users.
                                the instructions for installing on a raspberry pi are based on running all the commands/installations as a root user. the "chromuim-browser" command does not work when executed as the root user, only the default "pi" user. so i switched the command from "chromium-browser" to "xdg-open", which does essentially the same thing for my purposes, and it worked! well, almost.
                                i'm trying to launch an html file, and the mime type is "text/html" which opens with chromium by default for the pi user (yay!), but with the geany text editor for root (boo). i solved this by tweaking the command to run under the pi user, and it works as expected!
                                {"trigger":"myTriggerName","command":"su - pi -c 'xdg-open /home/pi/myFile.html'","ground":"foreground","voice":"myTriggerName","allowParams":"false"}
                                the only downside is that there is a noticeable delay in triggering this command. and i also have to open a terminal window, switch to the root user, and then run "triggercmdagent" before i can successfully trigger it. with this info, do you happen to know if/how i can:
                                1. auto run triggercmdagent on boot? the install instructions seem to state that it will launch in the background on boot, so i changed the command to "background" but no dice. still have to run triggercmdagent from terminal as root.
                                2. run/install triggercmdagent under the pi user instead of root? i think that would help speed up the execution of the command significantly.
                                thank you so much!
                                  Russ @Erin Leiker
                                  @erin-leiker, please give this a try:
                                  1. Run this as your pi user to allow root to send stuff to your pi user's Xwindows:
                                  xhost si:localuser:root
                                  1. Install the background service as root with:
                                  1. Make sure this variable is set when your command runs as root in the context of your triggercmdagent:
                                  export DISPLAY=:0.0
                                  Your agent will be running in background mode, so the commands need "ground": "background" to run that way.
                                  I suggest testing with galculator. It's an xwindows calculator app.
                                    I created a script to make it easier to install the Raspbian OS and the agent on a new Pi:
                                    https://www.triggercmd.com/forum/topic/606/windows-script-to-prep-sd-card-for-raspberry-pi-with-triggercmd-agent
                                    • A Offline
                                      avs2020
                                      @Russ said in Raspberry Pi setup:
                                      I followed the steps here, but the list of commands is empty right after install. The command output is:
                                      pi@raspberrypi:~ $ sudo triggercmdagent
                                      Daemon install: false
                                      prompt: token: ey.........
                                      Token saved for next time.
                                      Computer ID 5eb384a2ee82630019c61bac saved for next time.
                                      Write backup completed.
                                      Initiated command removals
                                      Initiated command adds
                                      (using sails.io.js node SDK @v1.1.13)
                                      Connected at: Wed May 06 2020 20:46:43 GMT-0700 (PDT)
                                      { message: 'Subscribed to 5eb384a2ee82630019c61bac!' }
                                      Added Gnome Editor
                                      ^C
                                      pi@raspberrypi:~ $ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
                                      Daemon install: true
                                      Logging in with saved token.
                                      Checking if the 5eb384a2ee82630019c61bac computer exists.
                                      Active: active (running) since Wed 2020-05-06 20:35:25 PDT; 12min ago
                                      Main PID: 864 (node)
                                      └─864 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
                                      May 06 20:35:33 raspberrypi env[864]: (using sails.io.js node SDK @v1.1.13)
                                      May 06 20:35:33 raspberrypi env[864]: Connected at: Wed May 06 2020 20:35:33 GMT-0700 (PDT)
                                      May 06 20:35:33 raspberrypi env[864]: Initiated command removals
                                      May 06 20:35:33 raspberrypi env[864]: { message: 'Subscribed to null!' }
                                      May 06 20:35:33 raspberrypi env[864]: Initiated command adds
                                      May 06 20:35:33 raspberrypi env[864]: Failed while trying add a trigger.
                                      I have not edited any standard files.
                                        Russ @avs2020
                                        @avs2020, it looks like you figured it out because I see commands associated with your raspberrypi computer now. Please confirm.
                                        • George HatzisymeonG Offline
                                          George Hatzisymeon
                                          It looks like offCommand is never called using this PI/Debian distribution, do you have an update? Did you forget to include this functionality for Linux, it works fine on Windows.
                                            Russ @George Hatzisymeon
                                            @George-Hatzisymeon, sorry I never responded to this. I just noticed it because someone upvoted it.
                                            I just verified that the offCommand commands.json value is supported in the current version of the Raspberry Pi agent. If you were using that version and it didn't work, then maybe you were missing this part:
                                            "allowParams":"true"
                                            Here's an example entry I just tested. It turns my led strip off if the parameter was off, and if the parameter was on, it turns the strip on and makes the leds green.
                                                   "trigger":"Green",
                                                   "command":"\/root\/killrun.sh leds.py green",
                                                   "offCommand": "\/root\/killrun.sh leds.py off",
                                                   "voice":"green",
                                            • Dean McNaughtonD Dean McNaughton referenced this topic on
