    Raspberry Pi setup
    raspberry pi
    40 Posts 12 Posters 39.3k Views 1 Watching
    • K Offline
      Kalen Daniel
      This is rad -thanks Russ. I'm not sure what I did but it wouldn't let me auto-start in the foreground, but could have been a simple hiccup I made along the way, when installing it. I have my pi waking up both my laptop and desktop now and trigger can do a bunch of things with both computers from sleeping/locking/restarting them. Really cool. I'll make a better video now that I got it dialed in as it seems to be incredibly seamless with alexa and setting up a simple command in alexa UI for the virtual smartthings switches. I think stringify or smartthings or harmony needs to buy trigger off you IMO!
      • J Offline
        JackMonkey
        I have been trying to get this triggercmd to work on my Raspberry Pi all afternoon.
        I followed the guide above, but when I run "triggercmd", it just dumps me back to the command line with no other response.
        When I try and run: /usr/share/triggercmdagent/app/src/installdaemon.sh, I get:
        pi ~$ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
        Failed to issue method call: Unit name triggercmdagent is not valid.
        Failed to issue method call: Invalid argument
        I also don't have a commands.json file under /root/.TRIGGERcmdData:
        pi ~ $ sudo ls /root/.TRIGGERcmdData -larth
        total 12K
        drwx------ 5 root root 4.0K Jul 8 14:14 ..
        drwxr-xr-x 2 root root 4.0K Jul 8 14:14 .
        -rwxr-xr-x 1 root root 220 Jul 8 16:15 triggercmdagent.service
        Any ideas?
        Thanks in advance.
          Russ @JackMonkey
          @jackmonkey, you should be root when you run triggercmdagent and paste in your token, so switch to root with sudo su -. Please try that and do another ls /root/.TRIGGERcmdData -larth.
          • R Offline
            Ryan Roberts @Russ
            @russ I've got everything set up from your tutorial, but what do you do to actually add or edit triggers? I have done
            nano/root/.TRIGGERcmdData/commands.json
            But what do I actually need to do to create or edit triggers and commands?
              Russ @Ryan Roberts
              @ryan-roberts, you can add a line to that commands.json file like this, to add a command you want to be able to run:
              If you find that your changes go away as soon as you save the file, then there's likely some bad json formatting in the file you tried to save. The most common problem is you have a comma on the last line.
              • A Offline
                Atmosphere
                • G Offline
                  gutopa
                  Hi Russ..
                  I think those instructions are not valid for the last raspio.
                  I've got loads of errors that I am not sure how to solve.
                  The following packages have unmet dependencies:
                  nodejs : Conflicts: nodejs-legacy but 4.8.2~dfsg-1 is to be installed
                  npm : Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
                  Depends: node-ansi (>= 0.3.0-2) but it is not going to be installed
                  Depends: node-ansi-color-table but it is not going to be installed
                  Depends: node-archy but it is not going to be installed
                  Depends: node-block-stream but it is not going to be installed
                  Depends: node-fstream (>= 0.1.22) but it is not going to be installed
                  Depends: node-fstream-ignore but it is not going to be installed
                  Depends: node-github-url-from-git but it is not going to be installed
                  Depends: node-glob (>= 3.1.21) but it is not going to be installed
                  Depends: node-graceful-fs (>= 2.0.0) but it is not going to be installed
                  Depends: node-inherits but it is not going to be installed
                  Depends: node-ini (>= 1.1.0) but it is not going to be installed
                  Depends: node-lockfile but it is not going to be installed
                  Depends: node-lru-cache (>= 2.3.0) but it is not going to be installed
                  Depends: node-minimatch (>= 0.2.11) but it is not going to be installed
                  Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
                  Depends: node-gyp (>= 0.10.9) but it is not going to be installed
                  Depends: node-nopt (>= 3.0.1) but it is not going to be installed
                  Depends: node-npmlog but it is not going to be installed
                  Depends: node-once but it is not going to be installed
                  Depends: node-osenv but it is not going to be installed
                  Depends: node-read but it is not going to be installed
                  Depends: node-read-package-json (>= 1.1.0) but it is not going to be installed
                  Depends: node-request (>= 2.25.0) but it is not going to be installed
                  Depends: node-retry but it is not going to be installed
                  Depends: node-rimraf (>= 2.2.2) but it is not going to be installed
                  Depends: node-semver (>= 2.1.0) but it is not going to be installed
                  Depends: node-sha but it is not going to be installed
                  Depends: node-slide but it is not going to be installed
                  Depends: node-tar (>= 0.1.18) but it is not going to be installed
                  Depends: node-underscore but it is not going to be installed
                  Depends: node-which but it is not going to be installed
                  E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
                    Russ @gutopa
                    @gutopa, I want to try to reproduce that error and fix it. Can you tell me what Raspberry Pi and what OS you're running?
                    • G Offline
                      gutopa
                      Thanks Russ..
                      I'm using a pi2 B with a fresh install from noob. So I believe it's all the last version of raspbian.
                        Russ @gutopa
                        Thanks @gutopa.
                        My Pi2 B died. I have a Pi 3 but I'll try the latest version of NOOBS/Raspbian on my Pi Zero to hopefully reproduce the problem.
                        EDIT: I was able reproduce the problem, and fortunately there's a simple solution. I updated the instructions above.
                        I changed this line:
                        apt-get -y install npm nodejs-legacy
                        To this:
                        Thank you for reporting the problem.
                        • A Offline
                          Atmosphere
                          @russ said in Raspberry Pi setup:
                          Hi, i'm curious - i use python scripts to trigger my gpio pins on my raspberry... it appears that these are "Foreground" tasks... how do i do this in the background (so that when the pi reboots - it loads automatically again)
                          Any tips?
                            Russ @Atmosphere
                            @atmosphere, in your commands.json file, make the ground field background instead of foreground. That way it will run in the context of the background service.
                              "trigger": "GPIO 6 on",
                              "command": "python /root/gpio6on.py",
                              "ground": "background",
                              "voice": "6 on"
                            Run this to install the background service:
                            • G Offline
                              gutopa
                              Hi Russ..
                              Could you give me some tips about how to remove it from raspbian?
                              Thank you
                                Russ @gutopa
                                @gutopa, you could uninstall the Raspberry Pi agent using these commands:
                                apt remove triggercmdagent
                                Then you should delete the computer from your account on the website.
                                • E Offline
                                  Erin Leiker
                                  hello! my end goal is to launch an html file on my raspberry pi 3b+ using IFTTT (i have a small display plugged into my pi on which i'm expecting to see the file). i'm fairly sure i've gotten everything set up correctly in that i can see evidence of the command having run in IFTTT, my TRIGGERcmd dashboard, and in the CLI when i run "systemctl status triggercmdagent".
                                  i have almost no native idea what i am doing, but i'm a pretty good tinkerer and an excellent copy-and-paster so the command i cobbled together is:
                                  {"trigger":"myTriggerName","command":"chromium-browser file:///home/pi/myFile.html","ground":"background","voice":"myTriggerName","allowParams":"false"}
                                  when i try to trigger that command via IFTTT or my TRIGGERcmd Triggers list, nothing actually happens other than the three locations i mention above showing some acknowledgement that the command was run. but when i run "chromium-browser file:///home/pi/myFile.html" via the CLI, the file opens in chromium exactly as i expect, so this all leads me to believe i have formatted the command incorrectly somehow.
                                  any help here would be much appreciated!
                                    Russ @Erin Leiker
                                    @erin-leiker, I think the problem is you're running the triggercmd agent as a background daemon, and your command is running with "ground": "background", so you can't see the result of your command.
                                    So to make it work, you'll need to:
                                    1. Run the agent in the foreground by running the "triggercmdagent" command in a terminal window in X Windows.
                                    2. Trigger your command in the foreground with "ground": "foreground" in your commands.json file.
                                    • E Offline
                                      Erin Leiker @Russ
                                      @russ thank you for the tips! i did some googling on x windows, and it sounds like it's a way to access or view the pi remotely. do i still need x windows if i have the pi booting to the desktop and i have a screen on it so i can access it directly?
                                      i updated the trigger to "foreground" and tried running triggercmdagent from the cli, but still i just see the log of the command having been run instead of the results of the command (opening that html file).
                                        Russ @Erin Leiker
                                        @erin-leiker, that's interesting. You might need to specify the full path of chromium-browser, so your command would be something like:
                                        /path/to/chromium-browser file:///home/pi/myFile.html
                                        To find the path, type this:
                                        which chromium-browser
                                        If you're booting to the GUI, that's X Windows. I'll boot up one of my Pi's and see if I can reproduce the problem you're having.
                                        EDIT: I tried it on my Pi. I found that it worked with or without the full path. I tried /usr/bin/chromium-browser and just chromium-browser and both worked for me, so I don't know what's wrong in your case.
                                        Can you try a simpler command, like echo Testing >> /tmp/test.txt ?
                                        When I did that, it created a /tmp/test.txt file when I remotely ran the command.
                                        • E Offline
                                          Erin Leiker @Russ
                                          @russ whew, i think i figured it out! if i'm right, it all comes down to users.
                                          the instructions for installing on a raspberry pi are based on running all the commands/installations as a root user. the "chromuim-browser" command does not work when executed as the root user, only the default "pi" user. so i switched the command from "chromium-browser" to "xdg-open", which does essentially the same thing for my purposes, and it worked! well, almost.
                                          i'm trying to launch an html file, and the mime type is "text/html" which opens with chromium by default for the pi user (yay!), but with the geany text editor for root (boo). i solved this by tweaking the command to run under the pi user, and it works as expected!
                                          {"trigger":"myTriggerName","command":"su - pi -c 'xdg-open /home/pi/myFile.html'","ground":"foreground","voice":"myTriggerName","allowParams":"false"}
                                          the only downside is that there is a noticeable delay in triggering this command. and i also have to open a terminal window, switch to the root user, and then run "triggercmdagent" before i can successfully trigger it. with this info, do you happen to know if/how i can:
                                          1. auto run triggercmdagent on boot? the install instructions seem to state that it will launch in the background on boot, so i changed the command to "background" but no dice. still have to run triggercmdagent from terminal as root.
                                          2. run/install triggercmdagent under the pi user instead of root? i think that would help speed up the execution of the command significantly.
                                          thank you so much!
                                            Russ @Erin Leiker
                                            @erin-leiker, please give this a try:
                                            1. Run this as your pi user to allow root to send stuff to your pi user's Xwindows:
                                            xhost si:localuser:root
                                            1. Install the background service as root with:
                                            1. Make sure this variable is set when your command runs as root in the context of your triggercmdagent:
                                            export DISPLAY=:0.0
                                            Your agent will be running in background mode, so the commands need "ground": "background" to run that way.
                                            I suggest testing with galculator. It's an xwindows calculator app.
