    2. George Hatzisymeon
    George HatzisymeonG Offline
    • Posts 8
    George Hatzisymeon
    @George Hatzisymeon
    George Hatzisymeon Unfollow Follow
    • Server is down
      Yesterday I noticed singificant lag and now the service is not responding. I can not even login. I am a subscriber is there a QoS for this sevice can we rely on it?
      George HatzisymeonG
      George Hatzisymeon
    • RE: SmartThings integration - flip a virtual switch to run a command
      @Russ It works fine what I had to do was to add text to the voice node in the XML configuration file of triggercmd and resync with the app. In previous integration it would show all commands in the smart things app now it picks only those with a voice tag.
      That is fine! Thanks everything now works as before…
      George HatzisymeonG
      George Hatzisymeon
      George HatzisymeonG
      George Hatzisymeon
      @Russ I have successfully followed the instructions for the new integrations but at the final step I was not able to see my triggers as virtual switches. Instead I could only see one switch with the name "edit" and nothing else.
      In the previous integration I was able to select the triggers that I wanted to be mapped as virtual switches, what is the situation now? why dont I see my triggers in the smart things integration?
      Thanks!
      George HatzisymeonG
      George Hatzisymeon
      @Russ It turns out Smartthings has discontinued Groovy apps accrding to this post here. I was using TriggerCMD in conjuction with smart things are you willing to support the new integration mechanisms? Do you have a timeline for this?
      George HatzisymeonG
      George Hatzisymeon
      It is a couple of days now that the Smart Things automation has stopped to function, I have visited my account in the smartthings site and the UI has completely changed, after I open the triggerCMD app I am getting an error saying:
      ERROR: Something went wrong. Please try to install the SmartApp again.
      I think something changed in the Samsung site and triggerCMD looks like is uncompatible, is there any way to fix this? I have tried to reinstall the app but there is no way to install a new app using their new UI.
      Do you have any idea what is going on?
      Thanks!
      George HatzisymeonG
      George Hatzisymeon
    • Server is down
      George HatzisymeonG
      George Hatzisymeon
    • RE: How to use Off Command
      Not working on Pi/Debian, do you have an update link?
      George HatzisymeonG
      George Hatzisymeon
    • RE: Raspberry Pi setup
      It looks like offCommand is never called using this PI/Debian distribution, do you have an update? Did you forget to include this functionality for Linux, it works fine on Windows.
      George HatzisymeonG
      George Hatzisymeon
      I am getting an Error saving unnamed page when I click Done on last page.
      Also I am using an account from Google, how shall I skip entering the credentials as you propose?
      George HatzisymeonG
      George Hatzisymeon
