    Raspberry Pi setup
    raspberry pi
    40 Posts 12 Posters 37.3k Views 1 Watching
      Russ @Atmosphere
      @atmosphere, in your commands.json file, make the ground field background instead of foreground. That way it will run in the context of the background service.
        "trigger": "GPIO 6 on",
        "command": "python /root/gpio6on.py",
        "ground": "background",
        "voice": "6 on"
      Run this to install the background service:
      • G Offline
        gutopa
        Hi Russ..
        Could you give me some tips about how to remove it from raspbian?
        Thank you
          Russ @gutopa
          @gutopa, you could uninstall the Raspberry Pi agent using these commands:
          apt remove triggercmdagent
          Then you should delete the computer from your account on the website.
          • E Offline
            Erin Leiker
            hello! my end goal is to launch an html file on my raspberry pi 3b+ using IFTTT (i have a small display plugged into my pi on which i'm expecting to see the file). i'm fairly sure i've gotten everything set up correctly in that i can see evidence of the command having run in IFTTT, my TRIGGERcmd dashboard, and in the CLI when i run "systemctl status triggercmdagent".
            i have almost no native idea what i am doing, but i'm a pretty good tinkerer and an excellent copy-and-paster so the command i cobbled together is:
            {"trigger":"myTriggerName","command":"chromium-browser file:///home/pi/myFile.html","ground":"background","voice":"myTriggerName","allowParams":"false"}
            when i try to trigger that command via IFTTT or my TRIGGERcmd Triggers list, nothing actually happens other than the three locations i mention above showing some acknowledgement that the command was run. but when i run "chromium-browser file:///home/pi/myFile.html" via the CLI, the file opens in chromium exactly as i expect, so this all leads me to believe i have formatted the command incorrectly somehow.
            any help here would be much appreciated!
              Russ @Erin Leiker
              @erin-leiker, I think the problem is you're running the triggercmd agent as a background daemon, and your command is running with "ground": "background", so you can't see the result of your command.
              So to make it work, you'll need to:
              1. Run the agent in the foreground by running the "triggercmdagent" command in a terminal window in X Windows.
              2. Trigger your command in the foreground with "ground": "foreground" in your commands.json file.
              • E Offline
                Erin Leiker @Russ
                @russ thank you for the tips! i did some googling on x windows, and it sounds like it's a way to access or view the pi remotely. do i still need x windows if i have the pi booting to the desktop and i have a screen on it so i can access it directly?
                i updated the trigger to "foreground" and tried running triggercmdagent from the cli, but still i just see the log of the command having been run instead of the results of the command (opening that html file).
                  Russ @Erin Leiker
                  @erin-leiker, that's interesting. You might need to specify the full path of chromium-browser, so your command would be something like:
                  /path/to/chromium-browser file:///home/pi/myFile.html
                  To find the path, type this:
                  which chromium-browser
                  If you're booting to the GUI, that's X Windows. I'll boot up one of my Pi's and see if I can reproduce the problem you're having.
                  EDIT: I tried it on my Pi. I found that it worked with or without the full path. I tried /usr/bin/chromium-browser and just chromium-browser and both worked for me, so I don't know what's wrong in your case.
                  Can you try a simpler command, like echo Testing >> /tmp/test.txt ?
                  When I did that, it created a /tmp/test.txt file when I remotely ran the command.
                  • E Offline
                    Erin Leiker @Russ
                    @russ whew, i think i figured it out! if i'm right, it all comes down to users.
                    the instructions for installing on a raspberry pi are based on running all the commands/installations as a root user. the "chromuim-browser" command does not work when executed as the root user, only the default "pi" user. so i switched the command from "chromium-browser" to "xdg-open", which does essentially the same thing for my purposes, and it worked! well, almost.
                    i'm trying to launch an html file, and the mime type is "text/html" which opens with chromium by default for the pi user (yay!), but with the geany text editor for root (boo). i solved this by tweaking the command to run under the pi user, and it works as expected!
                    {"trigger":"myTriggerName","command":"su - pi -c 'xdg-open /home/pi/myFile.html'","ground":"foreground","voice":"myTriggerName","allowParams":"false"}
                    the only downside is that there is a noticeable delay in triggering this command. and i also have to open a terminal window, switch to the root user, and then run "triggercmdagent" before i can successfully trigger it. with this info, do you happen to know if/how i can:
                    1. auto run triggercmdagent on boot? the install instructions seem to state that it will launch in the background on boot, so i changed the command to "background" but no dice. still have to run triggercmdagent from terminal as root.
                    2. run/install triggercmdagent under the pi user instead of root? i think that would help speed up the execution of the command significantly.
                    thank you so much!
                      Russ @Erin Leiker
                      @erin-leiker, please give this a try:
                      1. Run this as your pi user to allow root to send stuff to your pi user's Xwindows:
                      xhost si:localuser:root
                      1. Install the background service as root with:
                      1. Make sure this variable is set when your command runs as root in the context of your triggercmdagent:
                      export DISPLAY=:0.0
                      Your agent will be running in background mode, so the commands need "ground": "background" to run that way.
                      I suggest testing with galculator. It's an xwindows calculator app.
                        I created a script to make it easier to install the Raspbian OS and the agent on a new Pi:
                        https://www.triggercmd.com/forum/topic/606/windows-script-to-prep-sd-card-for-raspberry-pi-with-triggercmd-agent
                        • A Offline
                          avs2020
                          @Russ said in Raspberry Pi setup:
                          I followed the steps here, but the list of commands is empty right after install. The command output is:
                          pi@raspberrypi:~ $ sudo triggercmdagent
                          Daemon install: false
                          prompt: token: ey.........
                          Token saved for next time.
                          Computer ID 5eb384a2ee82630019c61bac saved for next time.
                          Write backup completed.
                          Initiated command removals
                          Initiated command adds
                          (using sails.io.js node SDK @v1.1.13)
                          Connected at: Wed May 06 2020 20:46:43 GMT-0700 (PDT)
                          { message: 'Subscribed to 5eb384a2ee82630019c61bac!' }
                          Added Gnome Editor
                          ^C
                          pi@raspberrypi:~ $ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
                          Daemon install: true
                          Logging in with saved token.
                          Checking if the 5eb384a2ee82630019c61bac computer exists.
                          Active: active (running) since Wed 2020-05-06 20:35:25 PDT; 12min ago
                          Main PID: 864 (node)
                          └─864 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
                          May 06 20:35:33 raspberrypi env[864]: (using sails.io.js node SDK @v1.1.13)
                          May 06 20:35:33 raspberrypi env[864]: Connected at: Wed May 06 2020 20:35:33 GMT-0700 (PDT)
                          May 06 20:35:33 raspberrypi env[864]: Initiated command removals
                          May 06 20:35:33 raspberrypi env[864]: { message: 'Subscribed to null!' }
                          May 06 20:35:33 raspberrypi env[864]: Initiated command adds
                          May 06 20:35:33 raspberrypi env[864]: Failed while trying add a trigger.
                          I have not edited any standard files.
                            Russ @avs2020
                            @avs2020, it looks like you figured it out because I see commands associated with your raspberrypi computer now. Please confirm.
                            • George HatzisymeonG Offline
                              George Hatzisymeon
                              It looks like offCommand is never called using this PI/Debian distribution, do you have an update? Did you forget to include this functionality for Linux, it works fine on Windows.
                                Russ @George Hatzisymeon
                                @George-Hatzisymeon, sorry I never responded to this. I just noticed it because someone upvoted it.
                                I just verified that the offCommand commands.json value is supported in the current version of the Raspberry Pi agent. If you were using that version and it didn't work, then maybe you were missing this part:
                                "allowParams":"true"
                                Here's an example entry I just tested. It turns my led strip off if the parameter was off, and if the parameter was on, it turns the strip on and makes the leds green.
                                       "trigger":"Green",
                                       "command":"\/root\/killrun.sh leds.py green",
                                       "offCommand": "\/root\/killrun.sh leds.py off",
                                       "voice":"green",
                                • Dean McNaughtonD Dean McNaughton referenced this topic on
                                • A Offline
                                  Ar7hur
                                  What I did wrong? It appears:
                                  E: Unable to locate package https://agents.triggercmd.com
                                  E: Couldn't find any packageb by glob 'https://agents.triggercmd.com'
                                  E: Couldn't find any packageb by regex 'https://agents.triggercmd.com'
                                  I'm a noob, and sorry for my english.
                                    Russ @Ar7hur
                                    @Ar7hur, the URL to download the Raspberry Pi installer is this:
                                    https://agents.triggercmd.com/triggercmdagent_1.0.1_all.deb
                                    Does that answer your question?
                                    • A Offline
                                      Ar7hur @Russ
                                      @Russ I wrote this, but appears what I mentioned
                                        Russ @Ar7hur
                                        @Ar7hur, how do you get those errors? Can you please give me the command you typed, or paste a screenshot?
                                        • A Offline
                                          Ar7hur @Russ
                                          @Russ It was my mistake. I discovered where was wrong😅 Sorry
                                          How to create a trigger to turn off? and is there how to turn on the pi by voice command?
                                            Russ @Ar7hur
                                            @Ar7hur, no problem. I'm glad you got it working.
                                            You could create a trigger that runs shutdown --poweroff but it won't actually power the Raspberry Pi off. Raspberry Pi's also do not support wake-on-lan, so you couldn't power it on from another computer on your network like you could with a PC.
                                            The only thing I can think of is you could power the Pi on/off with a relay by connecting/disconnecting the vbus on the 5volt power input with an adapter you could build with something like this, or you could use a smart plug to power it off/on. You could run a command that runs an Alexa routine that powers the smart plug on or off.
