    SmartThings integration - flip a virtual switch to run a command
    Instructions
    14
    38
    24.0k
    • M
      mthiel @Russ
      @russ Thanks for checking! Unfortunately, re-creating the device via the SmartApp didn't make a difference. Turns out MY problem is that I only have one trigger I'm testing on...
      I spent a few hours troubleshooting the SmartApp code and found the root cause around line 249. When a single trigger comes back from the api, the conditional looks like it assumes the type will be a Map, but it actually just returns a List with a single item at index 0. Changing the "devices?.name" and "devices?did" to "devices[0].name" and "devices[0].did" fixes the issue for me. I only realized the problem because the trigger list kept creating devices with brackets around the name, making me expect a typing problem.
      It's working great for me now, hope my digging helps!
        Russ @mthiel
        @mthiel, wow, that's interesting. I'm glad you found that. you send me the code snippet you changed? I want to test it myself, then I'll update the code. Sorry for the trouble, and thank you for finding a fix.
        EDIT:
        I was able to reproduce the problem. I tested the change and updated the code. Thanks @mthiel for the fix!
        // deviceList += ["name" : "${roomName} ${devices?.name}", "did" : "${devices?.did}", "type" : "bulb"]  <- this logic doesn't work when there's only 1 command
        // Thanks to mthiel for finding this fix.
        deviceList += ["name" : "${roomName} ${devices[0].name}", "did" : "${devices[0].did}", "type" : "bulb"]
        • P
          putefabio
          hello guys can you please give me some help
          i have triggercmd installed in my pc so i can open kodi, but i have a 32bit version so thats why (i suppose) i dont have the option to parse a cmd so the smartthings switch knows when its on or off.
          that beeing said when i press the switch it open kodi but it stays on (green), then if i close but manually it stays green forever, if i flip it again it goes off but it opens kodi, cause im not using the script.
          well what i want is, can i switch the smartthings switch to a switch that doesnt stay on, it just pushes and goes back to initial state?
          thanks in advance
            Russ @putefabio
            @putefabio, checkout this post:
            https://www.triggercmd.com/forum/topic/86/actiontiles-tile-with-triggercmd-bookmark-url/14
            It says you can make a small modification to the SmartThings code to make it so the switch goes back off after you flip it on.
            • P
              putefabio
              thanks a lot for a so quick awnser, that did the trick ๐Ÿ™‚
                @TigoleBitties, I just tried it and it's working for me. Can you verify your phone has Internet access?
                Also, you installed both the SmartApp and the Device Handler, correct?
                • George HatzisymeonG
                  George Hatzisymeon
                  I am getting an Error saving unnamed page when I click Done on last page.
                  Also I am using an account from Google, how shall I skip entering the credentials as you propose?
                    Russ @George Hatzisymeon
                    @George-Hatzisymeon, you mentioned you're using an account from Google. If you do that, then before you can log SmartThings into your TRIGGERcmd account you also need to set your password in your profile in your TRIGGERcmd account. To get to your profile, click your name in the upper-right.
                    You installed the device handler and SmartApp, correct?
                    Here's a video showing the process: https://www.youtube.com/watch?v=dq-loAiKAgo
                    If you still get that error, please post a screenshot. It might help me understand what's happening.
                    • ipaivaipI
                      ipaivaip
                      @Russ said in SmartThings integration - flip a virtual switch to run a command:
                      Handler
                      It works like a charm!
                      I have just follow the instructions, and had it immediately working. Still good at 2021
                      • R
                        rkstormer
                        This post is deleted!
                          George Hatzisymeon
                          It is a couple of days now that the Smart Things automation has stopped to function, I have visited my account in the smartthings site and the UI has completely changed, after I open the triggerCMD app I am getting an error saying:
                          ERROR: Something went wrong. Please try to install the SmartApp again.
                          I think something changed in the Samsung site and triggerCMD looks like is uncompatible, is there any way to fix this? I have tried to reinstall the app but there is no way to install a new app using their new UI.
                          Do you have any idea what is going on?
                          Thanks!
                            George Hatzisymeon @Russ
                            @Russ It turns out Smartthings has discontinued Groovy apps accrding to this post here. I was using TriggerCMD in conjuction with smart things are you willing to support the new integration mechanisms? Do you have a timeline for this?
                              @George-Hatzisymeon, I was worried this day would come. I actually created an integration while ago in anticipation of the Groovy app cutoff. It works great but Samsung won't won't approve it because I don't sell any hardware.
                              I considered selling a hardware device, but when I asked them about it, they said my users would only be able to use SmartThings to work with that hardware, so that wouldn't help.
                              I'm working on a new method that won't require SmartThings approval.
                              I'll post here again when I have it working. I'm hoping by this weekend.
                              EDIT: I just finished the new SmartThings integration. Please try it and let me know if it works for you.
                              George HatzisymeonG 1 Reply Last reply Reply Quote 0
                                @Russ I have successfully followed the instructions for the new integrations but at the final step I was not able to see my triggers as virtual switches. Instead I could only see one switch with the name "edit" and nothing else.
                                In the previous integration I was able to select the triggers that I wanted to be mapped as virtual switches, what is the situation now? why dont I see my triggers in the smart things integration?
                                Thanks!
                                  @George-Hatzisymeon thanks for trying it and letting me know it's not working. Will you please send me a screenshot of the Smart things values on your profile page and on the Smart things cloud integration page? I might be able to see the problem.
                                  Or it's possible it's working but you only have the voice field filled in for your "edit" command. That's what determines which triggers show up as devices now. It uses the same logic as the TRIGGERcmd SmartHome Alexa skill and Google Action. If that's the problem, just fill in the voice field on each command you want to show up as a device in SmartThings.
                                  If you send screenshots here that have your secrets, just change them after. Make sure you re-sync up the profile page info with the info in your SmartThings account too of course.
                                  You could also direct message me your screenshots.
                                  Thank you for your patience. I'm sure we can make this work.
                                    @Russ It works fine what I had to do was to add text to the voice node in the XML configuration file of triggercmd and resync with the app. In previous integration it would show all commands in the smart things app now it picks only those with a voice tag.
                                    That is fine! Thanks everything now works as beforeโ€ฆ
                                      @George-Hatzisymeon, awesome. Thanks for testing it.
                                      • JTJ
                                        JT
                                        @Russ thanks for coming up with a solution so quickly. I followed your instructions and I am up and running again! ๐Ÿ‘
