    SmartThings integration - flip a virtual switch to run a command
    38 Posts 14 Posters 31.1k Views 1 Watching
      Russ @George Hatzisymeon
      @George-Hatzisymeon, you mentioned you're using an account from Google. If you do that, then before you can log SmartThings into your TRIGGERcmd account you also need to set your password in your profile in your TRIGGERcmd account. To get to your profile, click your name in the upper-right.
      You installed the device handler and SmartApp, correct?
      Here's a video showing the process: https://www.youtube.com/watch?v=dq-loAiKAgo
      If you still get that error, please post a screenshot. It might help me understand what's happening.
      • ipaivaipI Offline
        ipaivaip
        @Russ said in SmartThings integration - flip a virtual switch to run a command:
        Handler
        It works like a charm!
        I have just follow the instructions, and had it immediately working. Still good at 2021
        • R Offline
          rkstormer
          • George HatzisymeonG Offline
            George Hatzisymeon
            It is a couple of days now that the Smart Things automation has stopped to function, I have visited my account in the smartthings site and the UI has completely changed, after I open the triggerCMD app I am getting an error saying:
            ERROR: Something went wrong. Please try to install the SmartApp again.
            I think something changed in the Samsung site and triggerCMD looks like is uncompatible, is there any way to fix this? I have tried to reinstall the app but there is no way to install a new app using their new UI.
            Do you have any idea what is going on?
            Thanks!
              George Hatzisymeon @Russ
              @Russ It turns out Smartthings has discontinued Groovy apps accrding to this post here. I was using TriggerCMD in conjuction with smart things are you willing to support the new integration mechanisms? Do you have a timeline for this?
                @George-Hatzisymeon, I was worried this day would come. I actually created an integration while ago in anticipation of the Groovy app cutoff. It works great but Samsung won't won't approve it because I don't sell any hardware.
                I considered selling a hardware device, but when I asked them about it, they said my users would only be able to use SmartThings to work with that hardware, so that wouldn't help.
                I'm working on a new method that won't require SmartThings approval.
                I'll post here again when I have it working. I'm hoping by this weekend.
                EDIT: I just finished the new SmartThings integration. Please try it and let me know if it works for you.
                George HatzisymeonG 1 Reply Last reply Reply Quote 0
                  @Russ I have successfully followed the instructions for the new integrations but at the final step I was not able to see my triggers as virtual switches. Instead I could only see one switch with the name "edit" and nothing else.
                  In the previous integration I was able to select the triggers that I wanted to be mapped as virtual switches, what is the situation now? why dont I see my triggers in the smart things integration?
                  Thanks!
                    @George-Hatzisymeon thanks for trying it and letting me know it's not working. Will you please send me a screenshot of the Smart things values on your profile page and on the Smart things cloud integration page? I might be able to see the problem.
                    Or it's possible it's working but you only have the voice field filled in for your "edit" command. That's what determines which triggers show up as devices now. It uses the same logic as the TRIGGERcmd SmartHome Alexa skill and Google Action. If that's the problem, just fill in the voice field on each command you want to show up as a device in SmartThings.
                    If you send screenshots here that have your secrets, just change them after. Make sure you re-sync up the profile page info with the info in your SmartThings account too of course.
                    You could also direct message me your screenshots.
                    Thank you for your patience. I'm sure we can make this work.
                      @Russ It works fine what I had to do was to add text to the voice node in the XML configuration file of triggercmd and resync with the app. In previous integration it would show all commands in the smart things app now it picks only those with a voice tag.
                      That is fine! Thanks everything now works as before…
                        @George-Hatzisymeon, awesome. Thanks for testing it.
                        • JTJ Offline
                          JT
                          @Russ thanks for coming up with a solution so quickly. I followed your instructions and I am up and running again! 👍
