    Freezing in Monterey
    Mac
    4.1k
    • Matt PackwoodM
      Matt Packwood
      is anyone having issues with the app/software freezing / locking up in macOS Monterey? I have removed and reinstalled but "no joy".
      Matt
      • Matt PackwoodM
        Matt Packwood
        Anyone????
          Russ @Matt Packwood
          @Matt-Packwood, sorry I'm on the road. I'll upgrade my mac when I get home and try it.
          Does it work at all? Does it freezes then continue or does it stay frozen? How do you fix it when it freezes? Sorry for 20 questions, but it might help.
          If anyone else reading this has Monterey, is the TRIGGERcmd Agent giving you any trouble?
          • Matt PackwoodM
            Matt Packwood
            I have "CleanMyMac" so I get a pop-up about frozen apps, the app appears to be frozen so I kill it. If I restart it then it runs for a while (lets say a couple of hours) then freezes again.
              Russ @Matt Packwood
              @Matt-Packwood, I tried to upgrade my mac and it said Monterey is not available.
              When it freezes, what happens? Do you click the icon and it does nothing?
              • Matt PackwoodM
                Matt Packwood
                It seems like the app freezes if it is started during start-up, if I then kill it and restart it is "good"...
                • Matt PackwoodM
                  Matt Packwood
                  Yep, that is the pattern....
                  Matt PackwoodM 1 Reply Last reply Reply Quote 0
                  • Matt PackwoodM
                    Matt Packwood @Matt Packwood
                    @Russ I have been messing around and the issue seems to be after a reboot, if the program / app is started "automatically", it then freezes / I force quit, restart and no issues....
                    • Matt PackwoodM
                      Matt Packwood
                      @Russ Has anyone else reported this? Are there any log files I can check?
                        Russ @Matt Packwood
                        @matt-packwood , no one except you has reported it yet. My Mac won't upgrade to Monterey but I'll see if AWS offers a way to run it in the cloud. It will be much easier to fix if I can reproduce it.
                        • tuicemenT
                          tuicemen @Russ
                          @russ @Matt-Packwood There is a thread developer forum that may help shed some light on this.
                            Russ @Matt Packwood
                            @matt-packwood,
                            Can you check under the Login Items tab in System Preferences, Users and Groups? You should have a TRIGGERcmdAgent entry in there. Please delete it (or all of them if you have multiple). Then close and re-open the TRIGGERcmdAgent app. It should re-install the login item.
                            I'm just thinking something might have gone wrong when it was added initially, but I admit, I'm grasping.
                            • Matt PackwoodM
                              Matt Packwood
                              @Russ it was in Start-Up twice, I followed your instructions and am now testing...
                              • Matt PackwoodM
                                @Russ It works for a few minutes then freezes....
                                • Matt PackwoodM
                                  @Russ TRIGGERcmdAgent Helper is running, TRIGGERcmdAgent is Not Responding.
                                    Russ @Matt Packwood
                                    @matt-packwood , bummer. What is TRIGGERcmdAgent Helper? Can you send a screenshot?
                                    Matt PackwoodM 2 Replies Last reply Reply Quote 0
                                    • Matt PackwoodM
                                      Matt Packwood @Russ
                                      • Matt PackwoodM
                                        Matt Packwood @Russ
                                        @russ
                                        From the "Open Ports":
                                        cwd
                                        /Applications/TRIGGERcmdAgent.app/Contents/Resources/app/src
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/TRIGGERcmdAgent Helper.app/Contents/MacOS/TRIGGERcmdAgent Helper
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/1266f2a906e23197a1c950e781683fdf2b4437efdf0aca9f3f65029301b078bb/TRIGGERcmdAgent Helper.aot
                                        txt
                                        /usr/libexec/rosetta/runtime
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/en.lproj/locale.pak
                                        txt
                                        /Library/Apple/usr/libexec/oah/libRosettaRuntime
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Squirrel.framework/Versions/A/Squirrel
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/4e03275c3fc0c8d75e1a418fee5e751a30227a524fb8a800421cb2d314a06ea8/Squirrel.aot
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/3cf89e489b28275962cd7d61cfd61b87b9c0685ef4aa5a4a83ed97bc6b04a681/Mantle.aot
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/ReactiveCocoa
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/f0f2b98a20cfb93677d67ef1646b121cac5ff393513ff4d2322cd1325286ab6c/ReactiveCocoa.aot
                                        txt
                                        /Library/Preferences/Logging/.plist-cache.KJz82Mj6
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/pdf_viewer_resources.pak
                                        txt
                                        /private/var/db/timezone/tz/2021a.3.0/icutz/icutz44l.dat
                                        txt
                                        /System/Library/Extensions/AGXMetal13_3.bundle/Contents/Resources/ds.g13g
                                        txt
                                        /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.data
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libffmpeg.dylib
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/5b88d564e2dc20ba94d1551e71f0770ee56bec715fb2073aaa2f2f0b49e45661/libffmpeg.dylib.aot
                                        txt
                                        /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/062a5b64cf579bee8e0f91354af64e1dea0741cc8f9b2e1a36be3c98c9e519f3/AppleMetalOpenGLRenderer.aot
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libnode.dylib
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/deebf460331330236f369b3d9a986a59527d2487f590b920cdc96aec6677a831/libnode.dylib.aot
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
                                        txt
                                        /private/var/db/oah/279281326358528_279281326358528/b9ffe9a6d397aff8c374a102c4113c94a804006d5b4d7174ab293a5fe29f799b/Electron Framework.aot
                                        txt
                                        /usr/share/icu/icudt68l.dat
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/icudtl.dat
                                        txt
                                        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/content_shell.pak
                                        txt
                                        /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-3027-v2.csstore
                                        txt
                                        /usr/lib/dyld
                                        /dev/null
                                        /dev/null
                                        /dev/null
                                        ->0xcd22e2ed4300e02b
                                        8
                                        /dev/urandom
                                        9
                                        ->0xcd22e2ed43007073
                                        10
                                        /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.list
                                        11
                                        12
                                        /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/default.metallib
                                        13
                                        /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/PixelConverter.metallib
                                        14
                                        count=0, state=0xa
                                        15
                                        ->0xc010c1d108e52518
                                        16
                                        ->0x48c8e5c7172ffc8e
                                        17
                                        count=0, state=0xa
                                        18
                                        ->0x4d0e05ff13ebdf7c
                                        19
                                        ->0xa9eef662a90bb211
                                          Russ @Matt Packwood
                                          @matt-packwood, do you have any antivirus software on your Mac? You could try disabling that temporarily to see if that's killing the agent somehow. That might explain why it's happening on your mac but no one else has seen it.
                                          • Matt PackwoodM
                                            Matt Packwood @Russ
                                            @russ Ah!!!! It is Sophos Anti-Virus... Now I need to see how to stop it "killing TriggerCMD".
