    Freezing in Monterey
    35 Posts 3 Posters 14.1k Views 1 Watching
    • Matt PackwoodM Offline
      Matt Packwood @Matt Packwood
      @Russ I have been messing around and the issue seems to be after a reboot, if the program / app is started "automatically", it then freezes / I force quit, restart and no issues....
        Matt Packwood
        @Russ Has anyone else reported this? Are there any log files I can check?
          Russ @Matt Packwood
          @matt-packwood , no one except you has reported it yet. My Mac won't upgrade to Monterey but I'll see if AWS offers a way to run it in the cloud. It will be much easier to fix if I can reproduce it.
          • tuicemenT Offline
            tuicemen @Russ
            @russ @Matt-Packwood There is a thread developer forum that may help shed some light on this.
              Russ @Matt Packwood
              @matt-packwood,
              Can you check under the Login Items tab in System Preferences, Users and Groups? You should have a TRIGGERcmdAgent entry in there. Please delete it (or all of them if you have multiple). Then close and re-open the TRIGGERcmdAgent app. It should re-install the login item.
              I'm just thinking something might have gone wrong when it was added initially, but I admit, I'm grasping.
                Matt Packwood
                @Russ it was in Start-Up twice, I followed your instructions and am now testing...
                  @Russ It works for a few minutes then freezes....
                    @Russ TRIGGERcmdAgent Helper is running, TRIGGERcmdAgent is Not Responding.
                      Russ @Matt Packwood
                      @matt-packwood , bummer. What is TRIGGERcmdAgent Helper? Can you send a screenshot?
                      Matt PackwoodM 2 Replies Last reply Reply Quote 0
                        Matt Packwood @Russ
                          Matt Packwood @Russ
                          @russ
                          From the "Open Ports":
                          cwd
                          /Applications/TRIGGERcmdAgent.app/Contents/Resources/app/src
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/TRIGGERcmdAgent Helper.app/Contents/MacOS/TRIGGERcmdAgent Helper
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/1266f2a906e23197a1c950e781683fdf2b4437efdf0aca9f3f65029301b078bb/TRIGGERcmdAgent Helper.aot
                          txt
                          /usr/libexec/rosetta/runtime
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/en.lproj/locale.pak
                          txt
                          /Library/Apple/usr/libexec/oah/libRosettaRuntime
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Squirrel.framework/Versions/A/Squirrel
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/4e03275c3fc0c8d75e1a418fee5e751a30227a524fb8a800421cb2d314a06ea8/Squirrel.aot
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/3cf89e489b28275962cd7d61cfd61b87b9c0685ef4aa5a4a83ed97bc6b04a681/Mantle.aot
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/ReactiveCocoa
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/f0f2b98a20cfb93677d67ef1646b121cac5ff393513ff4d2322cd1325286ab6c/ReactiveCocoa.aot
                          txt
                          /Library/Preferences/Logging/.plist-cache.KJz82Mj6
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/pdf_viewer_resources.pak
                          txt
                          /private/var/db/timezone/tz/2021a.3.0/icutz/icutz44l.dat
                          txt
                          /System/Library/Extensions/AGXMetal13_3.bundle/Contents/Resources/ds.g13g
                          txt
                          /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.data
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libffmpeg.dylib
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/5b88d564e2dc20ba94d1551e71f0770ee56bec715fb2073aaa2f2f0b49e45661/libffmpeg.dylib.aot
                          txt
                          /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/062a5b64cf579bee8e0f91354af64e1dea0741cc8f9b2e1a36be3c98c9e519f3/AppleMetalOpenGLRenderer.aot
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libnode.dylib
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/deebf460331330236f369b3d9a986a59527d2487f590b920cdc96aec6677a831/libnode.dylib.aot
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
                          txt
                          /private/var/db/oah/279281326358528_279281326358528/b9ffe9a6d397aff8c374a102c4113c94a804006d5b4d7174ab293a5fe29f799b/Electron Framework.aot
                          txt
                          /usr/share/icu/icudt68l.dat
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/icudtl.dat
                          txt
                          /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/content_shell.pak
                          txt
                          /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-3027-v2.csstore
                          txt
                          /usr/lib/dyld
                          /dev/null
                          /dev/null
                          /dev/null
                          ->0xcd22e2ed4300e02b
                          8
                          /dev/urandom
                          9
                          ->0xcd22e2ed43007073
                          10
                          /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.list
                          11
                          12
                          /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/default.metallib
                          13
                          /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/PixelConverter.metallib
                          14
                          count=0, state=0xa
                          15
                          ->0xc010c1d108e52518
                          16
                          ->0x48c8e5c7172ffc8e
                          17
                          count=0, state=0xa
                          18
                          ->0x4d0e05ff13ebdf7c
                          19
                          ->0xa9eef662a90bb211
                            Russ @Matt Packwood
                            @matt-packwood, do you have any antivirus software on your Mac? You could try disabling that temporarily to see if that's killing the agent somehow. That might explain why it's happening on your mac but no one else has seen it.
                              Matt Packwood @Russ
                              @russ Ah!!!! It is Sophos Anti-Virus... Now I need to see how to stop it "killing TriggerCMD".
                              • tuicemenT Offline
                                tuicemen @Matt Packwood
                                @matt-packwood, Just an Idea (I don't run a Mac) What if you didn't allow Sophos service to auto load on startup then start the service after TRIGGERcmd had loaded? I suspect Sophos service is loading first.
                                This seems to indicate you can stop and start Sophos
                                https://community.sophos.com/on-premise-endpoint/f/sophos-endpoint-software/10616/how-do-i-temporarily-stop-sophos
                                  Matt Packwood @tuicemen
                                  @tuicemen I know that what I am about to say is different than your suggestion but I think it is relevant. I started without Sophos working then turned it on, TriggerCMd was killed...
                                    Russ @Matt Packwood
                                    @matt-packwood, thank you. That helps me to know that because I should fix that if I can. I used to use Sophos. It's good AV.
                                    I'll see if I can figure out why Sophos thinks the triggercmd agent is a virus. I hope I can get a free scanner from their site and reproduce the problem. Stay tuned.
                                    EDIT: I scanned with the free SophosScanAndClean_x64.exe tool and it did not identify my Windows TRIGGERcmd agent as a virus. I'll try the Mac version next.
                                      Matt Packwood @Russ
                                      @russ I am running on an iMac, also I am reaching out to Sophos support...
                                        Russ @Matt Packwood
                                        @matt-packwood, thank you. My Mac Sophos scan came back clean, and the agent still worked afterward, so I'm not going to be able to reproduce it unless maybe I buy a copy of Sophos. Let me know what they say please.
                                          Matt Packwood @Russ
                                          @russ I got it working, I had to add the agent to the exclusions (see picture).
                                            Russ @Matt Packwood
                                            @matt-packwood, good. Thanks for showing that to other users too.
