    Freezing in Monterey
    35 Posts 3 Posters 14.1k Views 1 Watching
    • Matt PackwoodM Offline
      Matt Packwood @Russ
        Matt Packwood @Russ
        @russ
        From the "Open Ports":
        cwd
        /Applications/TRIGGERcmdAgent.app/Contents/Resources/app/src
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/TRIGGERcmdAgent Helper.app/Contents/MacOS/TRIGGERcmdAgent Helper
        txt
        /private/var/db/oah/279281326358528_279281326358528/1266f2a906e23197a1c950e781683fdf2b4437efdf0aca9f3f65029301b078bb/TRIGGERcmdAgent Helper.aot
        txt
        /usr/libexec/rosetta/runtime
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/en.lproj/locale.pak
        txt
        /Library/Apple/usr/libexec/oah/libRosettaRuntime
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Squirrel.framework/Versions/A/Squirrel
        txt
        /private/var/db/oah/279281326358528_279281326358528/4e03275c3fc0c8d75e1a418fee5e751a30227a524fb8a800421cb2d314a06ea8/Squirrel.aot
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
        txt
        /private/var/db/oah/279281326358528_279281326358528/3cf89e489b28275962cd7d61cfd61b87b9c0685ef4aa5a4a83ed97bc6b04a681/Mantle.aot
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/ReactiveCocoa
        txt
        /private/var/db/oah/279281326358528_279281326358528/f0f2b98a20cfb93677d67ef1646b121cac5ff393513ff4d2322cd1325286ab6c/ReactiveCocoa.aot
        txt
        /Library/Preferences/Logging/.plist-cache.KJz82Mj6
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/pdf_viewer_resources.pak
        txt
        /private/var/db/timezone/tz/2021a.3.0/icutz/icutz44l.dat
        txt
        /System/Library/Extensions/AGXMetal13_3.bundle/Contents/Resources/ds.g13g
        txt
        /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.data
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libffmpeg.dylib
        txt
        /private/var/db/oah/279281326358528_279281326358528/5b88d564e2dc20ba94d1551e71f0770ee56bec715fb2073aaa2f2f0b49e45661/libffmpeg.dylib.aot
        txt
        /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
        txt
        /private/var/db/oah/279281326358528_279281326358528/062a5b64cf579bee8e0f91354af64e1dea0741cc8f9b2e1a36be3c98c9e519f3/AppleMetalOpenGLRenderer.aot
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libnode.dylib
        txt
        /private/var/db/oah/279281326358528_279281326358528/deebf460331330236f369b3d9a986a59527d2487f590b920cdc96aec6677a831/libnode.dylib.aot
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
        txt
        /private/var/db/oah/279281326358528_279281326358528/b9ffe9a6d397aff8c374a102c4113c94a804006d5b4d7174ab293a5fe29f799b/Electron Framework.aot
        txt
        /usr/share/icu/icudt68l.dat
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/icudtl.dat
        txt
        /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/content_shell.pak
        txt
        /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-3027-v2.csstore
        txt
        /usr/lib/dyld
        /dev/null
        /dev/null
        /dev/null
        ->0xcd22e2ed4300e02b
        8
        /dev/urandom
        9
        ->0xcd22e2ed43007073
        10
        /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.list
        11
        12
        /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/default.metallib
        13
        /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/PixelConverter.metallib
        14
        count=0, state=0xa
        15
        ->0xc010c1d108e52518
        16
        ->0x48c8e5c7172ffc8e
        17
        count=0, state=0xa
        18
        ->0x4d0e05ff13ebdf7c
        19
        ->0xa9eef662a90bb211
          Russ @Matt Packwood
          @matt-packwood, do you have any antivirus software on your Mac? You could try disabling that temporarily to see if that's killing the agent somehow. That might explain why it's happening on your mac but no one else has seen it.
            Matt Packwood @Russ
            @russ Ah!!!! It is Sophos Anti-Virus... Now I need to see how to stop it "killing TriggerCMD".
            • tuicemenT Offline
              tuicemen @Matt Packwood
              @matt-packwood, Just an Idea (I don't run a Mac) What if you didn't allow Sophos service to auto load on startup then start the service after TRIGGERcmd had loaded? I suspect Sophos service is loading first.
              This seems to indicate you can stop and start Sophos
              https://community.sophos.com/on-premise-endpoint/f/sophos-endpoint-software/10616/how-do-i-temporarily-stop-sophos
                Matt Packwood @tuicemen
                @tuicemen I know that what I am about to say is different than your suggestion but I think it is relevant. I started without Sophos working then turned it on, TriggerCMd was killed...
                  Russ @Matt Packwood
                  @matt-packwood, thank you. That helps me to know that because I should fix that if I can. I used to use Sophos. It's good AV.
                  I'll see if I can figure out why Sophos thinks the triggercmd agent is a virus. I hope I can get a free scanner from their site and reproduce the problem. Stay tuned.
                  EDIT: I scanned with the free SophosScanAndClean_x64.exe tool and it did not identify my Windows TRIGGERcmd agent as a virus. I'll try the Mac version next.
                    Matt Packwood @Russ
                    @russ I am running on an iMac, also I am reaching out to Sophos support...
                      Russ @Matt Packwood
                      @matt-packwood, thank you. My Mac Sophos scan came back clean, and the agent still worked afterward, so I'm not going to be able to reproduce it unless maybe I buy a copy of Sophos. Let me know what they say please.
                        Matt Packwood @Russ
                        @russ I got it working, I had to add the agent to the exclusions (see picture).
                          Russ @Matt Packwood
                          @matt-packwood, good. Thanks for showing that to other users too.
                            Matt Packwood @Russ
                            @russ No worries, I am having an issue with the iOS app as I have to log in every time, is this the expected behavior?
                            • tuicemenT Offline
                              @matt-packwood , I have the same issue with Windows
                              not my Android phone. It is probably a issue with the OS set not to remember passwords (log in info)
                                • tuicemenT Offline
                                  @matt-packwood, sorry I don't have a mac to test. Was this after a reboot or just if you close then reopen?
                                  I just double checked and see I actually don't have the app on my PC.
                                  I shut down my phone then restarted and the app never asked for a password.
                                  I suspect it is a security thing that must be set on your mac. Has it always behaved this way? @russ may have some suggestions
                                    Russ @Matt Packwood
                                    @matt-packwood, no that's not expected behavior. You should only have to login once. I'll test that and fix it if I can reproduce it. Thank you for reporting it.
                                    In the meantime you could use the PWA at https://app.triggercmd.com It's very similar. In fact it's better because it also gives you access to your panels. You should be able to save the PWA app to your iphone as an icon too.
                                      Matt Packwood @Russ
                                      @russ The PWA works fine, thanks.
                                        Russ @Matt Packwood
                                        @matt-packwood, fyi, the iOS app remembers your login now. Thanks for reporting that problem.
                                          Matt Packwood @Russ
                                          @russ I saw that, many thanks!
