    Freezing in Monterey
    35 Posts 3 Posters 13.3k Views 1 Watching
      Russ @Matt Packwood
      @matt-packwood, thank you. My Mac Sophos scan came back clean, and the agent still worked afterward, so I'm not going to be able to reproduce it unless maybe I buy a copy of Sophos. Let me know what they say please.
      • Matt PackwoodM Offline
        Matt Packwood @Russ
        @russ I got it working, I had to add the agent to the exclusions (see picture).
          Russ @Matt Packwood
          @matt-packwood, good. Thanks for showing that to other users too.
            Matt Packwood @Russ
            @russ No worries, I am having an issue with the iOS app as I have to log in every time, is this the expected behavior?
            • tuicemenT Offline
              tuicemen @Matt Packwood
              @matt-packwood , I have the same issue with Windows
              not my Android phone. It is probably a issue with the OS set not to remember passwords (log in info)
                Matt Packwood @tuicemen
                • tuicemenT Offline
                  @matt-packwood, sorry I don't have a mac to test. Was this after a reboot or just if you close then reopen?
                  I just double checked and see I actually don't have the app on my PC.
                  I shut down my phone then restarted and the app never asked for a password.
                  I suspect it is a security thing that must be set on your mac. Has it always behaved this way? @russ may have some suggestions
                    Russ @Matt Packwood
                    @matt-packwood, no that's not expected behavior. You should only have to login once. I'll test that and fix it if I can reproduce it. Thank you for reporting it.
                    In the meantime you could use the PWA at https://app.triggercmd.com It's very similar. In fact it's better because it also gives you access to your panels. You should be able to save the PWA app to your iphone as an icon too.
                      Matt Packwood @Russ
                      @russ The PWA works fine, thanks.
                        Russ @Matt Packwood
                        @matt-packwood, fyi, the iOS app remembers your login now. Thanks for reporting that problem.
                          Matt Packwood @Russ
                          @russ I saw that, many thanks!
