    Freezing in Monterey
    35 Posts 3 Posters 13.3k Views 1 Watching
    • Matt PackwoodM Offline
      Matt Packwood
      Anyone????
        Russ @Matt Packwood
        @Matt-Packwood, sorry I'm on the road. I'll upgrade my mac when I get home and try it.
        Does it work at all? Does it freezes then continue or does it stay frozen? How do you fix it when it freezes? Sorry for 20 questions, but it might help.
        If anyone else reading this has Monterey, is the TRIGGERcmd Agent giving you any trouble?
          Matt Packwood
          I have "CleanMyMac" so I get a pop-up about frozen apps, the app appears to be frozen so I kill it. If I restart it then it runs for a while (lets say a couple of hours) then freezes again.
            Russ @Matt Packwood
            @Matt-Packwood, I tried to upgrade my mac and it said Monterey is not available.
            When it freezes, what happens? Do you click the icon and it does nothing?
              Matt Packwood
              It seems like the app freezes if it is started during start-up, if I then kill it and restart it is "good"...
                Matt Packwood
                Yep, that is the pattern....
                  Matt Packwood @Matt Packwood
                  @Russ I have been messing around and the issue seems to be after a reboot, if the program / app is started "automatically", it then freezes / I force quit, restart and no issues....
                    Matt Packwood
                    @Russ Has anyone else reported this? Are there any log files I can check?
                      Russ @Matt Packwood
                      @matt-packwood , no one except you has reported it yet. My Mac won't upgrade to Monterey but I'll see if AWS offers a way to run it in the cloud. It will be much easier to fix if I can reproduce it.
                      • tuicemenT Offline
                        tuicemen @Russ
                        @russ @Matt-Packwood There is a thread developer forum that may help shed some light on this.
                          Russ @Matt Packwood
                          @matt-packwood,
                          Can you check under the Login Items tab in System Preferences, Users and Groups? You should have a TRIGGERcmdAgent entry in there. Please delete it (or all of them if you have multiple). Then close and re-open the TRIGGERcmdAgent app. It should re-install the login item.
                          I'm just thinking something might have gone wrong when it was added initially, but I admit, I'm grasping.
                            Matt Packwood
                            @Russ it was in Start-Up twice, I followed your instructions and am now testing...
                              @Russ It works for a few minutes then freezes....
                                @Russ TRIGGERcmdAgent Helper is running, TRIGGERcmdAgent is Not Responding.
                                  Russ @Matt Packwood
                                  @matt-packwood , bummer. What is TRIGGERcmdAgent Helper? Can you send a screenshot?
                                  Matt PackwoodM 2 Replies Last reply Reply Quote 0
                                    Matt Packwood @Russ
                                      Matt Packwood @Russ
                                      @russ
                                      From the "Open Ports":
                                      cwd
                                      /Applications/TRIGGERcmdAgent.app/Contents/Resources/app/src
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/TRIGGERcmdAgent Helper.app/Contents/MacOS/TRIGGERcmdAgent Helper
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/1266f2a906e23197a1c950e781683fdf2b4437efdf0aca9f3f65029301b078bb/TRIGGERcmdAgent Helper.aot
                                      txt
                                      /usr/libexec/rosetta/runtime
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/en.lproj/locale.pak
                                      txt
                                      /Library/Apple/usr/libexec/oah/libRosettaRuntime
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Squirrel.framework/Versions/A/Squirrel
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/4e03275c3fc0c8d75e1a418fee5e751a30227a524fb8a800421cb2d314a06ea8/Squirrel.aot
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Mantle.framework/Versions/A/Mantle
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/3cf89e489b28275962cd7d61cfd61b87b9c0685ef4aa5a4a83ed97bc6b04a681/Mantle.aot
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/ReactiveCocoa
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/f0f2b98a20cfb93677d67ef1646b121cac5ff393513ff4d2322cd1325286ab6c/ReactiveCocoa.aot
                                      txt
                                      /Library/Preferences/Logging/.plist-cache.KJz82Mj6
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/pdf_viewer_resources.pak
                                      txt
                                      /private/var/db/timezone/tz/2021a.3.0/icutz/icutz44l.dat
                                      txt
                                      /System/Library/Extensions/AGXMetal13_3.bundle/Contents/Resources/ds.g13g
                                      txt
                                      /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.data
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libffmpeg.dylib
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/5b88d564e2dc20ba94d1551e71f0770ee56bec715fb2073aaa2f2f0b49e45661/libffmpeg.dylib.aot
                                      txt
                                      /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/062a5b64cf579bee8e0f91354af64e1dea0741cc8f9b2e1a36be3c98c9e519f3/AppleMetalOpenGLRenderer.aot
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libnode.dylib
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/deebf460331330236f369b3d9a986a59527d2487f590b920cdc96aec6677a831/libnode.dylib.aot
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework
                                      txt
                                      /private/var/db/oah/279281326358528_279281326358528/b9ffe9a6d397aff8c374a102c4113c94a804006d5b4d7174ab293a5fe29f799b/Electron Framework.aot
                                      txt
                                      /usr/share/icu/icudt68l.dat
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/icudtl.dat
                                      txt
                                      /Applications/TRIGGERcmdAgent.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Resources/content_shell.pak
                                      txt
                                      /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-3027-v2.csstore
                                      txt
                                      /usr/lib/dyld
                                      /dev/null
                                      /dev/null
                                      /dev/null
                                      ->0xcd22e2ed4300e02b
                                      8
                                      /dev/urandom
                                      9
                                      ->0xcd22e2ed43007073
                                      10
                                      /private/var/folders/g3/8by1rzh91zb851tk6dj06wj40000gn/C/com.vandermeyconsulting.triggercmdagent.helper/com.apple.metal/16777235_322/functions.list
                                      11
                                      12
                                      /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/default.metallib
                                      13
                                      /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/Resources/PixelConverter.metallib
                                      14
                                      count=0, state=0xa
                                      15
                                      ->0xc010c1d108e52518
                                      16
                                      ->0x48c8e5c7172ffc8e
                                      17
                                      count=0, state=0xa
                                      18
                                      ->0x4d0e05ff13ebdf7c
                                      19
                                      ->0xa9eef662a90bb211
                                        Russ @Matt Packwood
                                        @matt-packwood, do you have any antivirus software on your Mac? You could try disabling that temporarily to see if that's killing the agent somehow. That might explain why it's happening on your mac but no one else has seen it.
                                          Matt Packwood @Russ
                                          @russ Ah!!!! It is Sophos Anti-Virus... Now I need to see how to stop it "killing TriggerCMD".
                                          • tuicemenT Offline
                                            tuicemen @Matt Packwood
                                            @matt-packwood, Just an Idea (I don't run a Mac) What if you didn't allow Sophos service to auto load on startup then start the service after TRIGGERcmd had loaded? I suspect Sophos service is loading first.
                                            This seems to indicate you can stop and start Sophos
                                            https://community.sophos.com/on-premise-endpoint/f/sophos-endpoint-software/10616/how-do-i-temporarily-stop-sophos
