    Set Windows volume to X
    937
    • Diogo MenegonD
      Diogo Menegon
      Hi, i used the high volume command that has in the examples with the smarthome alexa skill, but i'd like to say a specific volume, something like "Alexa, set the volume of computer to X".
      I read the sending params topic, but i dont want to have to say "ask triggercmd to set te volume with the parameter 80".
      Is there a way? Thanks a lot.
      • XanderX
        Xander
        Create a command using Nirsoft.net's NIRCMD. (Instructions on its page or search these forums). It supports a ton of little commands like that.
        Diogo MenegonD 1 Reply Last reply Reply Quote 0
        • Diogo MenegonD
          Diogo Menegon
          This post is deleted!
          • Diogo MenegonD
            Diogo Menegon @Xander
            @Xander The problem isn't about how to do the command to change the volume, but if there's a way to pass the parameter someway so I don't have to say "Alexa, ask TriggerCMD to set computer's volume with parameter 80" but just "Alexa, set computer's volume to 80"
            I setted up the command with the NirCMD, and using the command line in windows i can change the volume with the %1 and putting the param after the command, but i tried with alexa, saying "Alexa, turn computer's volume with parameter 80" and she reply something like "Computer's volume isn't compatible with this"
            PS: computer's volume is the voice option in the triggercmd command
            PS2: i'm using alexa in pt-br, maybe the params with alexa in portuguese isnt avaible?
            • XanderX
              Xander
              @Russ is the author and knows how parameters work.
              As a backup plan, you could set up multiple Triggercmd/nircmd commands for Vol 20, Vol 40, etc.
              • Diogo MenegonD
                @Xander ok, so, after doing some more research and trying other things, this was what I was doing wrong:
                I discovered that the SmartHome skill isn't capable of parsing params like numbers, only on and off. So I have to use the Execute Command skill, right?
                And probably, when parsing numbers to Alexa, she sends it written (maybe?!) to the triggercmd, so I added in my batch script, some lines to transform the written numbers into numerical ones.
                And now it's working, but it is still a lot of work having to say "Alexa, ask Execute Command to open computer's volume with parameter X" or in pt-br that is my native language "Alexa, abra execute comando e execute volume do computador com parâmetro X"
                Is there a plan to implement others params in SmartHome skill? Or is there a way to use IFTTT to make this sentece shorter?
                Thanks.
                  Russ @Diogo Menegon
                  @Diogo-Menegon, I'm glad you figured that out.
                  The non-Smart Home skills like "Execute Command", "TRIGGERcmd", and "TRIGGER command" skills allow other parameters besides on and off, but there are two problems with them:
                  1. The sentence structure, "Alexa, abra execute comando e execute volume do computador com parâmetro X" is alot to say.
                  2. Alexa doesn't recognize your words as well as it does when you use the Smart Home skills.
                  So I think @Xander's suggestion to make commands for volume 20, 40 etc, and use the Smart Home skill makes sense.
                  • Diogo MenegonD
                    Diogo Menegon @Russ
                    @Russ yeah, I think it is what I'm going to do.
                    Thanks for all the support both of you.
                    @Xander
                    • HS Tattoo ContatoH
                      HS Tattoo Contato
                      Olá a todos, Eu sou novo e estava tentando definir o volume do computador para um valor específico, como 30%, 40%, 50%......
                      Não sou da área e foi difícil para mim entender como usar o NIRCMD do Nirsoft.net. Resolvi explorar as opções de uma forma lógica (para mim) e que fosse simples, mesmo que isso gere vários comandos., Eu consegui fazer com sucesso. Criei linhas de comando novas, baixando o volume a zero e aumentando ao número desejado, com base no script do Russ ♥. (A propósito, que trabalho incrível amigo)
                      (Hello everyone, I am new and I was trying to set the computer volume to a specific value like 30%, 40%, 50%......
                      I'm not from the area and it was difficult for me to understand how to use NIRCMD from Nirsoft.net. I decided to explore the options in a logical way (for me) and in a simple way, even if it generates several commands., I managed to do it successfully. I created new command lines, lowering the volume to zero and increasing it to the desired number, based on Russ ♥'s script. (By the way, what an amazing job my friend))
                      -Script do media.ahk:
                      ........voldown:
                      Send {Volume_Down 50}
                      return
                      mute:
                      Send {Volume_Mute}
                      return
                      20:
                      Send {Volume_Up 10}
                      return
                      30:
                      Send {Volume_Up 15}
                      return
                      40:
                      Send {Volume_Up 20}
                      return
                      50:
                      Send {Volume_Up 25}
                      return
                      60:
                      Send {Volume_Up 30}
                      return
                      70:
                      Send {Volume_Up 35}
                      return
                      80:
                      Send {Volume_Up 40}
                      return
                      90:
                      Send {Volume_Up 45}
                      return
                      100:
                      Send {Volume_Up 50}
                      return
                      Fiquem em paz
