    OAuth support for MCP server
    Scheduled Pinned Locked Moved MCP
    4 Posts 2 Posters 747 Views 1 Watching
    • Kevin 0K Offline
      Kevin 0
      Any plans on supporting OAuth for the MCP server? The reason I ask is that ChatGPT requires OAuth if you use an MCP server as an "app".
      Thanks. Also your app is awesome!
      Kevin
        Russ @Kevin 0
        Thanks @Kevin-0. Now that you asked, I'll definitely look into it.
          Russ @Russ
          EDIT: The TRIGGERcmd ChatGPT app is now live - you'll find it in the official directory here.
          Original post follows:
          @Kevin-0, it should work now, but only if you have a paid ChatGPT "plus" subscription or greater.
          To add the TRIGGERcmd MCP server (https://www.triggercmd.com/mcp) to your ChatGPT account:
          1. Enable development mode here: https://chatgpt.com/#settings/Connectors/Advanced
          2. Go here: https://chatgpt.com/#settings/Connectors
          3. Click "Create app" and set it up like this:
          I paid for the ChatGPT plus upgrade and tested it:
          EDIT: I submitted the MCP server to OpenAI to be included in their app store. That should solve the issue I've seen where ChatGPT runs the command twice. If they reject the app I'll do something to debounce it.
          Kevin 0K 1 Reply Last reply Reply Quote 0
          • Kevin 0K Offline
            Kevin 0 @Russ
            @Russ Awesome! Thank you so much. Hopefully OpenAI will support your submitted app!
