    Opening in a particular Window size
    1.6k
    • JRSF HomeJ
      JRSF Home
      Hi, is there something I can add to a command to launch a shorcut, webpage or .exe that gets it to open in a set way, e.g.
      1. Size: Maximised, Fullscreen, Normal windowed, Minimised or a Window of a specific size?
      2. At a particular zoom %, etc?
      3. To click a button within that window?
      I've been scratching my head for ages over this, so any help would be much appreciated!
        Russ @JRSF Home
        @JRSF-Home, I asked ChatGPT about #1 because I remembered it's possible to launch an app minimized or maximized with the start command:
        https://chatgpt.com/share/68fcce56-9d20-8004-9046-8a96869e1b9f
        I suggest looking at AutoHotKey or AutoIT to automate the clicks.
        • XanderX
          Xander @Russ
          @Russ Could you create a shortcut with that parameter and start the program by calling the shortcut?
            Russ @Xander
            @Xander, I'm finding that only some executables, like notepad.exe support starting them maximized, minimized or normal. If make a shortcut (.lnk file) that targets one of those executables, you can specify it in shortcut settings.
            • XanderX
              Xander @Russ
              @Russ The request for #1 was "launch a shorcut, webpage or .exe" so creating a shortcut this way covers it, no? The shortcut I just created opens a maximized window in Chrome to this page.
              My only point being that it might not be necessary to reinvent the wheel. OP would still need to work out the zoom (but remember that browsers remember the zoom level of a given website so that pretty much covers the second step).
                Russ @Xander
                @Xander, I thought by "shortcut" he was talking about a Windows shortcut like I screenshotted above, not a TRIGGERcmd shortcut. I think he wants to create a TRIGGERcmd command that makes sure the app (maybe Chrome?) launches maximized, starts with a particular zoom % (Chrome can be zoomed).
                Assuming it's Chrome, I have my script launch it maximized, then effectively type CTRL 0, then CTRL + once or twice to adjust the zoom.
                Here's a list of parameters Chrome takes, but none of them are the zoom level, so you'd have to simulate key presses with nircmd or an AutoIT script or similar.
                https://peter.sh/experiments/chromium-command-line-switches/
                • XanderX
                  Xander @Russ
                  @Russ My screenshot is a .lnk shortcut as well - of Chrome opening with the URL of this discussion in a maximized window.
                  Zoom level is pretty moot because, unless wants to change a commonly viewed site, pretty much all browsers remember the zoom level of all sites visited. He can go to whateversite.com, set the zoom to 175%, and when the shortcut opens the site, it will be at 175%.
                  The clicking or scrolling is another, more complicated matter.
                    Russ @Xander
                    @Xander, got it. Sorry I thought you were suggesting he use Chrome to launch a shortcut. I get your original meaning now.
                    Just so it's clear to OP, he could put start c:\path\to\shortcut.lnk in the Command field or include it in his script that TRIGGERcmd could run for him. Example:
                    start C:\Users\russe\Desktop\Claude.lnk
                    Then if he pre-configured the Run field of that .lnk shortcut, he could make it open Maximized.
                    As for OP's 3rd request - to click a button within that window, I'd ask ChatGPT. Just asked it "how to click a button on a web page with a script." here:
                    https://chatgpt.com/share/68fe7888-36f8-8004-9c72-e7c6385f927b
                    • JRSF HomeJ
                      JRSF Home
                      Lots of good stuff in the diologue above, so many thanks for that.
                      To bring the senario to life, here's a couple of examples of what I'm trying to solve
                      1. Start the morning by opening a Radio player site using Chrome in small window that shows the Channel and 'now playing' info, but leaves the bulk of the screen accessible. Current situtation - I can open the player with TriggerCMD, but then have to go to the PC to manually click on "Play", resize the window and zoom level to get the info to display correctly. As I have to go the PC anyway, this loses any benefit from automation with TriggerCMD!
                      2. Watch some streaming TV whilst prepping lunch. Current situation - a small window opens as was set for Radio, and I have to manually adjust on the PC...
                      A should add that some services perform best in Chrome, others to Edge or FireFox, and I also play media (Music, DVDs, and Recorded TV from various .exe's, hence the broad question posed.
                      I have never found that the Maximise setting in Shorcuts works beyond the first click - after that, the last used setting overrides.
                      It's a bit like shopping trolleys in the supermarket. When you arrive, you want to find them by the entrance ready to wheel straight into the store, not behind a car half way down the lot where the last person left it!
                      Thanks for the pointers on places to explore. I've found a switch to tag onto the end of a Chrome launch that helps:
                      --start-maximized
                      Limitations: Does not work with Win10, Edge, Firefox, .exe's
                      Also
                      --new-window
                      looks useful for browsers that do not allow apps to be created that open in their own space, e.g. FireFox. (Note this does not directly fix any of the above)
                      I'd like to play a bit more with Keypress Win+Up. How do I tag this onto the end of a TriggerCMD command line? I remember seeing something in one of the tutorials / examples / posts about how to put in multiple actions using a seperator, but have never been able to find it again...
                        Russ @JRSF Home
                        @JRSF-Home, I see what you're trying to do and why.
                        Here's a long command line that uses && to combine multiple commands into one:
                        "C:\Program Files\Google\Chrome\Application\chrome.exe" --new-window https://triggercmd.com && timeout 5 && nircmd win activate stitle "TRIGGERcmd: Remotely run" && nircmd win setsize stitle "TRIGGERcmd: Remotely run" 800 100 500 500
                        It opens triggercmd.com in a new Chrome window, waits 5 seconds, then resizes and positions the window.
                        Personally, instead of that super long command line I would create a .bat file like this and have TRIGGERcmd run the .bat file.
                        timeout 5
                        The nircmd win command parameters aren't super intuitive, but you can see how I had it find the Chrome window by the "TRIGGERcmd: Remotely run" text that the Chrome window's title starts with.
                        https://nircmd.nirsoft.net/win.html
                        I know you also want to click a button on the page. I'm looking into how to run a command like this in the Chrome console using the keyboard so you could have nircmd do that part too:
                        document.querySelector('#yourButtonId').click();
                        Please try the script or command though. It worked for me.
                        This shows how I simulated clicking the Sign In button on the triggercmd.com login page using this method. Now I just need to figure out the series of keystrokes to automate it with nircmd.
                        RussR JRSF HomeJ 2 Replies Last reply Reply Quote 0
                          Russ @Russ
                          @JRSF-Home
                          Think script worked pretty well for me. It does something similar to your use-case. It opens a Youtube video in a new Chrome window in a specific location on the screen, with specific dimensions, and presses the Like button.
                          It uses a Chrome dev tools console command to find the like button and click it.
                          "C:\Program Files\Google\Chrome\Application\chrome.exe" --new-window https://www.youtube.com/watch?v=1I9qC0Zo_PM
                          timeout 4
                          REM x y width height
                          nircmd win setsize stitle "Allow friends to control Spotify" 200 100 800 1000
                          nircmd win activate stitle "Allow friends to control Spotify"
                          REM open dev tools
                          nircmd sendkeypress F12
                          timeout 3
                          REM type document.querySelector('like-button-view-model button[aria-label*="like"]').click()
                          nircmd sendkeypress d o c u m e n t 0xBE q u e r y Shift+s e l e c t o r Shift+0x39 0xDE l i k e 0xBD b u t t o n 0xBD v i e w 0xBD m o d e l spc b u t t o n 0xDB
                          nircmd sendkeypress a r i a 0xBD l a b e l Shift+0x38 0xBB Shift+0xDE l i k e Shift+0xDE 0xDD 0xDE Shift+0x30 0xBE c l i c k Shift+0x39 Shift+0x30
                          REM press enter
                          nircmd sendkeypress 0x0D
                          timeout 1
                          REM close dev tools
                          It's a little low-tech because it simulates a lot of key presses. There's probably a better way using puppeteer or selenium but this works if you don't care.
                          • JRSF HomeJ
                            JRSF Home @Russ
                            @Russ This is great - there's some really good stuff in there that I have been exploring since your post!
                            I've managed to get this to run as a batch file via the Command Prompt, but not as yet from within TriggerCMD. In the latter it only gets as far as opening the Chome window. Two things come to mind:
                            1. Is there a special way of using "Timeout" - I've tried inserting && Timeout 4 && in directly in TriggerCMD actions but it seems to ignore it? Also, if I run an isolated Timeout at the Comand Prompt it becomes cancelled by any subsequent input.
                            2. I've read elsewhere that in some circumstances launching an application in a script causes the rest of the script to pause until that application is closed...
                            Other Notes:
                            a) The Chrome Dev 'like click' only seems to work if the "Console" tab is selected. The default is "Elements" and it seems to like to return to that after a PC restart or other event
                            b) Some of the hex Keypress codes are specific to keyboard layout / country. They can be found via the usual search engines and replaced 🙂
                            c) I'm getting occasions where windows open in the background rather than visible and 'selected' ready for input. Not just for this, it seems it can happen when launch any shortcut, exe, url etc. Any ideas on this?
                            Other developments:
                            Try this for opening an app in a maximised window:
                            start "" /max "File path\name.exe"
                              Russ @JRSF Home
                              @JRSF-Home, sorry, I forgot (again) that timeout command doesn't wait if the script is running in a context that doesn't have a console, like when the TRIGGERcmd agent runs it. It just moves on immediately.
                              This chatgpt session explains it: https://chatgpt.com/share/691cf13c-2f64-8004-8b12-78dd516285a9
                              You can see here that another user had the same problem.
                              My suggestion is to use the ping command like this:
                              ping 127.0.0.1 -n 3
                              Adjust that 3 number depending on how long you want to wait.
                              Here's my improved script that uses ping to wait, and it uses CTRL-SHIFT-J to go directly to the Console tab:
                              ping 127.0.0.1 -n 5
                              REM open dev tools to the Console tab
                              nircmd sendkeypress ctrl+shift+j
                              ping 127.0.0.1 -n 3
                              REM press enter
                              ping 127.0.0.1 -n 2
                              REM close dev tools
                              Here's a video of it working on my laptop: https://youtu.be/p-uJ8j1__zw
