      @Antonio-Francisco-S-Santos, you still haven't told me if you're getting something in the /tmp/Me-Siga.log file or not.
      Before we troubleshoot the script I need to know whether the command is running. If you get something in /tmp/Me-Siga.log then we'll know it is running.
      Please run this command and show me the result:
      cat /tmp/Me-Siga.log
        Quando executo esse comando aparece essa resposta:
        cat: /tmp/Me-Siga.log: Arquivo ou diret▒rio inexistente
        Executei o comando no terminal shell
          @Antonio-Francisco-S-Santos, interresting. It doesn't seem to be running because you aren't getting anything in the log file.
          Will you please try running the script as root manually? I'm curious if that works.
          sudo su -
          /home/pi/TonyPi/Functions/Me-Siga.sh
          Also, please try adding this line to your Me-Siga.sh script:
          echo "Me-Siga.sh script ran." >> /tmp/Me-Siga.log
          Also, please confirm:
          You ran xhost + as pi.
          In your /root/.TRIGGERcmdData/commands.json file, ground = background.
            já executei esse comando como root mas não funcionou: /home/pi/TonyPi/Functions/Me-Siga.sh
            também já tentei como comando echo mas não funcionou o Script não responde
              /root/.TRIGGERcmdData/commands.json, ground = background.
              não da permissão quando executo esse comando:
                Também quando executo esse comando: cat /tmp/Me-Siga.log recebo isso: Me-Siga.sh script ran.
                  @Antonio-Francisco-S-Santos, good, so this line that you added to your script
                  Must have writen this to your /tmp/Me-Siga.log file:
                  Did it add that line when your ran the script manually as root? Or when you ran it via TRIGGERcmd? If you don't know, can you test that? Just cat the log before and after you run it.
                  I just want to establish whether TRIGGERcmd is running your script or not before troubleshooting the content of your script.
                    @Russ Bom dia Professor, Ainda não conseguir resolver o Script com esse arquivo0 (Follow.py) Se os outros funcionam perfeitamente. Quando pego o Script que criei (Me-siga.sh) e modifico para outro arquivo no Trigger deixando assim: (/home/pi/TonyPi/Functions/Buzeer.py) ele funciona mas quando deixo assim: (/home/pi/TonyPi/Functions/Follow.py) não responde.
                    esse é o Arquivo Follow.py:
                      @Antonio-Francisco-S-Santos, I don't know why that particular python script won't work. I would have to see the output to troubleshoot it.
                      For some reason sending the output to a log didn't work, but if you run it manually, do you get any output you could send me?
                      Or is it the same error you got with the KickBall.py script?
                      Can't initialize GTK backend in function 'cvInitSystem'
                        @Russ Bom dia, O Script KickBall.py tinha um erro na visualização do vídeo e esse script não da nenhum retorno ao clicar no gatilho.
                        Me mostre como faço o script para ter um retorno de log?. Acho que o arquivo Follow deve ter algum comando na sua composição que impede que o Trigger funcione.
                          @Antonio-Francisco-S-Santos, to get the output, run this from a terminal window:
                          python3 /home/pi/TonyPi/Functions/Follow.py
                          Or to capture the output to a log, run this command instead:
                          python3 /home/pi/TonyPi/Functions/Follow.py > /tmp/follow.log 2>&1
                            Entçao, quando executo esse Script (python3 /home/pi/TonyPi/Functions/Follow.py )
                            ele funciona, e quando executo esse ( python3 /home/pi/TonyPi/Functions/Follow.py > /tmp/follow.log 2>&1 ) recebo esse Arquivo TMP: Follow-log.jpg
                              @Antonio-Francisco-S-Santos Também quando executo o Script pelo Trigger ( #!/bin/bash
                              export DISPLAY=:0.0
                              /usr/bin/python3 src/main.py --debug
                              python3 /home/pi/TonyPi/Functions/Follow.py > /tmp/follow.log 2>&1 ) no arquivo Bash recebo esse arquivo TMP:
                                @Antonio-Francisco-S-Santos No caso o erro que esta acontecendo é esse aqui:
                                ( Traceback (most recent call last):
                                File "/home/pi/TonyPi/Functions/Follow.py", line 10, in <module>
                                import pandas as pd
                                ModuleNotFoundError: No module named 'pandas' )
                                  @Antonio-Francisco-S-Santos, you need to install the pandas module with one of these commands. I'd try the first one first.
                                  sudo pip3 install pandas
                                  sudo apt-get install python3-pandas
                                    @Russ Olá Professor, você é fera mesmo viu, deu certo funcionou o Script ( Follow ) Instalei o Pandas e deu certo muito obrigado você é o mestre mesmo.
                                      Awesome @Antonio-Francisco-S-Santos. I'm glad it's working now.
                                        @Russ Olá Professor, Como faço um script para fechar os script quando executado, Ex:
                                        {"trigger":"Sonar_barrier.py","command":"/home/pi/TonyPi/Extend/Caminhar.sh","ground":"background","voice":"Caminhar","allowParams": "false"}
                                        para fechar esse comando ( Sonar_barrier.py) quando estiver rodando?
                                          @Antonio-Francisco-S-Santos, if you don't mind killing all instances of python3, you could use this command:
                                          killall python3
                                          You could make that your "Off Command" so when you turn the virtual device off, it runs the killall command.
                                          {"trigger":"Sonar_barrier.py","command":"/home/pi/TonyPi/Extend/Caminhar.sh","offCommand":"killall python3","ground":"background","voice":"Caminhar","allowParams": "false"}
                                            @Russ Muito obrigado meu Amigo, ele funciona mas desliga o Robô após fechar o Script. kkkkk
                                            Na realidade estou querendo fechar só o Script que estar rodando no momento. No caso um outro Script que fecha os outros quando estiver rodando.
