    2. Antonio Francisco S.Santos
    Antonio Francisco S.SantosA Offline
    • Posts 53
    @Antonio Francisco S.Santos
    Antonio Francisco S.Santos Unfollow Follow
    • Script.sh não executa a função completa
      Olá Professor tudo bem?
      executando o Código.py, ele funciona normal, Mas ao executar no Script.sh só funciona o Giroscópio, mas os Servos não faz nada. Aparece esse erro:
      Fall_and_Stand Start
      'latin-1' codec can't encode character '\uff01' in position 12: ordinal not in range(256)
    • RE: Tentando Executar um Script python no terminal LX com o TriggerCMD mas não estou conseguindo
      @Antonio-Francisco-S-Santos Desculpe, O Código que me refiro é esse aqui:
      #!/usr/bin/python3
      coding=utf8
      import sys
      import time
      import math
      import hiwonder.Mpu6050 as Mpu6050
      import hiwonder.ActionGroupControl as AGC
      import hiwonder.Board as Board
      mpu = Mpu6050.mpu6050(0x68)#启动Mpu6050
      mpu.set_gyro_range(mpu.GYRO_RANGE_2000DEG)#设置Mpu6050的陀螺仪的工作范围
      mpu.set_accel_range(mpu.ACCEL_RANGE_2G)#设置Mpu6050的加速度计的工作范围
      count1 = 0
      count2 = 0
      def standup():
      global count1, count2
      try:
          accel_date = mpu.get_accel_data(g=True) #获取传感器值
          angle_y = int(math.degrees(math.atan2(accel_date['y'], accel_date['z']))) #将获得的数据转化为角度值
          if abs(angle_y) > 105: #y轴角度大于160,count1加1,否则清零
              count1 += 1
          else:
              count1 = 0
          if abs(angle_y) < 85: #y轴角度小于10,count2加1,否则清零
              count2 += 1
          else:
              count2 = 0
          time.sleep(0.1)
          if count1 >= 1: #往前倒了一定时间后起来
              count1 = 0
              print("equilibrio_1!")#打印执行的动作名
              AGC.runActionGroup('equilibrio_1')#执行动作
              Board.setPWMServoPulse(1, 1300, 700)
              Board.setPWMServoPulse(2, 1500, 700)
              time.sleep(0.8)
              AGC.runActionGroup('stand')
          elif count2 >= 1: #往后倒了一定时间后起来
              count2 = 0
              print("equilibrio_2!")#打印执行的动作名
              AGC.runActionGroup('equilibrio_2')#执行动作
              Board.setPWMServoPulse(1, 1500, 700)
              time.sleep(0.8)
      except BaseException as e:
          print(e)
      if name == 'main':
      print("Fall_and_Stand Init")
      print("Fall_and_Stand Start")
      while True : #循环检测机器人的状态
      standup()
      key = time.sleep(0.1)
      if key == 27:
      break
      Professor, Tenho outra dúvida, esse código .py abrindo ele na IDE Thoony Python ele funciona normal mas se criar um Script .sh ele reconhece o Giroscópio e o Acelerómetro mas não faz nenhuma ação. aparece esse erro:
      Aqui estar o Código:
      import time
      print('''
      功能:幻尔科技TonyPi扩展板,PWM舵机控制例程
      Official website:http://www.hiwonder.com
      Online mall:https://huaner.tmall.com/
      以下指令均需在LX终端使用,LX终端可通过ctrl+alt+t打开,或点
      击上栏的黑色LX终端图标。
      Usage:
      python3 BusServoMove.py
      Version: --V1.2 2021/07/03
      Tips:
      • 按下Ctrl+C可关闭此次程序运行,若失败请多次尝试!
      while True:
      # 参数:参数1:舵机接口编号; 参数2:位置; 参数3:运行时间
      Board.setPWMServoPulse(2, 1500, 500) # 2号舵机转到1500位置,用时500ms
      time.sleep(0.5) # 延时时间和运行时间相同
      Board.setPWMServoPulse(2, 1800, 800) #舵机的转动范围0-180度,对应的脉宽为500-2500,即参数2的范围为500-2500
      time.sleep(0.5)
      Board.setPWMServoPulse(2, 1500, 300)
      time.sleep(0.2)
      Board.setPWMServoPulse(1, 1800, 800)
      time.sleep(0.5)
      Board.setPWMServoPulse(2, 1500, 800)
      Board.setPWMServoPulse(1, 1500, 800)
      time.sleep(0.5)
      @Antonio-Francisco-S-Santos Professor Você é um gênio os Comandos agora funcionaram perfeitamente, com o sudo no inicio como você mencionou. Obrigado meu irmão.
      Agora uma outra dúvida:
      Como saber o nível da bateria que alimenta o Raspberry pi pelo Trigger CMD? Seria isso mais ou menos:
      battery_monitor
      @Antonio-Francisco-S-Santos Testei esse comando no TriggerCMD, funcionou perfeitamente só um Script que ficou dando esse erro:
      @Russ said in Tentando Executar um Script python no terminal LX com o TriggerCMD mas não estou conseguindo:
      kill -9 $(pgrep -f Pegar_Objeto.sh)
      Agora colando dessa forma no terminal ele consegue fechar:
      kill -9 $(pgrep -f ApriltagTrack.py)
      Ainda não testei esse comando la no TriggerCMD
      Executei esse comando manualmente mas não reve efeito:
      kill -9 $(pgrep -f "/bin/bash /home/pi/TonyPi/Extend/Pegar_Objeto.sh")
      Coloquei tambem o endereço do código principal:
      kill -9 $(pgrep -f "/bin/bash /home/pi/TonyPi/Extend/ApriltagTrack.py")
      Mesmo assim não fechou o Script
      @Russ Olá Professor não consegue fechar os Script quando executado pelo TriggerCMD, se executar dentro do Debian no Terminal e abrir outro terminal com o comando Kill consegue fechar. o que pode ser professor?
      @Russ Esse comando executa a função perfeitamente mas quando executo o comando de fechar nada acontece:
      {"trigger":"Pegar_Objeto.sh","command":"/home/pi/TonyPi/Extend/Pegar_Objeto.sh","ground":"background","voice":"Pegar Objeto","allowParams": "false"},
