    Google home and TriggerCMD stop working when Google home is set to French
    39 Posts 7 Posters 27.9k Views 2 Watching
      Russ @Dominik Pellkofer
      Thanks @dominik-pellkofer .
        [[global:former-user]] @Dominik Pellkofer
        @dominik-pellkofer That's German... and not French! 😉
          @alain-coderre, oops, I wasn't paying attention. I actually did the German Alexa skill already so I should have known that.
            Did someone managed to make this work in french ?
              @fast-load, I actually wrote the code for french and german for Google Assistant, but I'm having trouble publishing it. There seems to be a glitch in the Google Assistant system and I've opened a support case about it. Stay tuned.
                  Update: I submitted the TRIGGERcmd version of the Google Action today with French and German support. When that passes their review process I'll submit the Trigger Command version.
                    @russ Any news???
                      @alain-coderre, I got through one problem and now I have another. I'm not getting much help from Google techsupport on it. I posted this question to Stack Overflow. You can read that to see what I'm up against.
                      https://stackoverflow.com/questions/49079322/google-action-language-to-dialogflow-language-mapping
                        @alain-coderre, I'm still working on this.
                        For the TRIGGER command equivalent, is this ok as an invocation phrase or do you recommend something else?
                        Déclencheur commandment
                          @russ The real translation is: "déclencheur de commande"
                          But if you need only two words : "déclencheur commandement" would also make sense.
                            [[global:former-user]] @Guest
                            @Russ Any updates???
                              @russ Any news???
                                @alain-coderre, I just submitted the French and German language versions. I should get feedback in a couple days. It probably won't pass their review the first time, but at least now I'm making progress.
                                  @russ OK! Thanks! 🙂
                                    @alain-coderre, bad news. That problem where a person using French language gets an English response. I was hoping Google fixed it. I'm researching it again now.
                                    • D Offline
                                      Dominik Pellkofer
                                      @Russ, does the same hold true for German? Still following the progress with my fingers crossed...
                                      Thx!
                                        @dominik-pellkofer, yes, same issue with German. I was able to reproduce it even with a brand new project, so I open a ticket with Google with screnshots. Hopefully that will prove something is wrong, and give them ideas on how to fix it.
                                          FYI - I'm still working on this. I've been emailing back and forth with Google tech support every day. For some reason the German and French versions are returning the English version's text.
                                          EDIT 6/8/18: I got this from Google support 3 days ago, so I think we're making progress:
                                          Actions on Google Support
                                          Jun 5 (3 days ago)
                                          to me
                                          Our apologies for the inconvenience this has caused. I already have coordinated this with our internal team and it seems this is a bug from our side. They are actively working on this and will keep you posted once I get an update from them. We thank you for your patience and understanding.
                                          • M Offline
                                            Marcelo García
                                            Hi Russ,
                                            Recently it was launched google home in Spanish and "TRIGGERCMD" is what I need to run scripts on my raspberry with Google Home.
                                            If it's possible you can add "Spanish" to the integration list 😉 ?
                                            Form: "OK Google, ejecuta TRIGGERCMD @trigger en @computer con parametro @params"
                                            Tell me if you need to translate something else?
                                            Thanks,
