    Google home and TriggerCMD stop working when Google home is set to French
    39 Posts 7 Posters 26.2k Views 2 Watching
      @alain-coderre, I've only setup the Google Assistant integration for English so far, but I just checked and I see that I could add French. I'll start working on it. Would you mind helping me out? Can you give me a few French words people might use for computer names and trigger names?
      Also, will you please translate the basic command format for me? Google Translate doesn't always get it right.
      Google translated this sentence:
      Hey Google, ask TRIGGER command to run calculator on downstairs.
      .. to this:
      Hey Google, demandez à la commande TRIGGER d'exécuter la calculatrice en bas.
      .. and I don't know if that's correct.
      Also, can you translate this to french?
      Say something like, run Calculator on Office PC.
      ? 2 Replies Last reply Reply Quote 0
      • D Offline
        Dominik Pellkofer
        Hey,
        Can you also do a German integration, at least with the basic command?
        That'd be: Hey Google, bitte TRIGGER cmd <PROGRAM> auf <DEVICE> auszuführen.
        Would really appreciate it, thx!
        Dominik
          Russ @Dominik Pellkofer
          @dominik-pellkofer, yes, I'll work on that too.
          Can you confirm this is correct for the form with a parameter?
          Hey Google, bitte TRIGGER cmd lauf @trigger auf @computer mit parameter @params
          I have a bunch of info from the Alexa skill that I can use:
          https://www.triggercmd.com/forum/topic/64/are-there-plans-to-release-a-alexa-skill-for-amazon-de/18
            @russ Here are the translated words...
            ask = demandez à
            to run = d'exécuter
            on = sur
            Say something like, run Calculator on Office PC. = Dites quelque chose comme, exécutez la calculatrice sur le PC du bureau.
              [[global:former-user]] @Guest
              @alain-coderre said in Google home and TriggerCMD stop working when Google home is set to French:
              ask = demandez à
              to run = d'exécuter
              on = sur
              English:
              Hey Google, ask TRIGGERCMD to run calculator on office PC.
              French
              OK Google, demandez à TRIGGERCMD d'exécuter calculatrice sur PC du bureau.
                @russ
                English:
                French
                • D Offline
                  Dominik Pellkofer @Russ
                  @russ said in Google home and TriggerCMD stop working when Google home is set to French:
                  Almost correct:
                  Hey Google, bitte TRIGGER cmd @trigger auf @computer mit parameter @params auszuführen
                  RussR ? 2 Replies Last reply Reply Quote 0
                    Thanks @dominik-pellkofer .
                      [[global:former-user]] @Dominik Pellkofer
                      @dominik-pellkofer That's German... and not French! 😉
                        @alain-coderre, oops, I wasn't paying attention. I actually did the German Alexa skill already so I should have known that.
                          Did someone managed to make this work in french ?
                            @fast-load, I actually wrote the code for french and german for Google Assistant, but I'm having trouble publishing it. There seems to be a glitch in the Google Assistant system and I've opened a support case about it. Stay tuned.
                                Update: I submitted the TRIGGERcmd version of the Google Action today with French and German support. When that passes their review process I'll submit the Trigger Command version.
                                  @russ Any news???
                                    @alain-coderre, I got through one problem and now I have another. I'm not getting much help from Google techsupport on it. I posted this question to Stack Overflow. You can read that to see what I'm up against.
                                    https://stackoverflow.com/questions/49079322/google-action-language-to-dialogflow-language-mapping
                                      @alain-coderre, I'm still working on this.
                                      For the TRIGGER command equivalent, is this ok as an invocation phrase or do you recommend something else?
                                      Déclencheur commandment
                                        @russ The real translation is: "déclencheur de commande"
                                        But if you need only two words : "déclencheur commandement" would also make sense.
                                          @Russ Any updates???
                                            @russ Any news???
