    Google home and TriggerCMD stop working when Google home is set to French
    39 Posts 7 Posters 26.2k Views 2 Watching
      @alain-coderre, I got through one problem and now I have another. I'm not getting much help from Google techsupport on it. I posted this question to Stack Overflow. You can read that to see what I'm up against.
      https://stackoverflow.com/questions/49079322/google-action-language-to-dialogflow-language-mapping
        @alain-coderre, I'm still working on this.
        For the TRIGGER command equivalent, is this ok as an invocation phrase or do you recommend something else?
        Déclencheur commandment
          @russ The real translation is: "déclencheur de commande"
          But if you need only two words : "déclencheur commandement" would also make sense.
            [[global:former-user]] @Guest
            @Russ Any updates???
              @russ Any news???
                @alain-coderre, I just submitted the French and German language versions. I should get feedback in a couple days. It probably won't pass their review the first time, but at least now I'm making progress.
                  @russ OK! Thanks! 🙂
                    @alain-coderre, bad news. That problem where a person using French language gets an English response. I was hoping Google fixed it. I'm researching it again now.
                    • D Offline
                      Dominik Pellkofer
                      @Russ, does the same hold true for German? Still following the progress with my fingers crossed...
                      Thx!
                        Russ @Dominik Pellkofer
                        @dominik-pellkofer, yes, same issue with German. I was able to reproduce it even with a brand new project, so I open a ticket with Google with screnshots. Hopefully that will prove something is wrong, and give them ideas on how to fix it.
                          FYI - I'm still working on this. I've been emailing back and forth with Google tech support every day. For some reason the German and French versions are returning the English version's text.
                          EDIT 6/8/18: I got this from Google support 3 days ago, so I think we're making progress:
                          Actions on Google Support
                          Jun 5 (3 days ago)
                          to me
                          Our apologies for the inconvenience this has caused. I already have coordinated this with our internal team and it seems this is a bug from our side. They are actively working on this and will keep you posted once I get an update from them. We thank you for your patience and understanding.
                          • M Offline
                            Marcelo García
                            Hi Russ,
                            Recently it was launched google home in Spanish and "TRIGGERCMD" is what I need to run scripts on my raspberry with Google Home.
                            If it's possible you can add "Spanish" to the integration list 😉 ?
                            Form: "OK Google, ejecuta TRIGGERCMD @trigger en @computer con parametro @params"
                            Tell me if you need to translate something else?
                            Thanks,
                              @russ Any news on the French support?
                                @alain-coderre, this is the latest from Google tech support. They've acknowledged a problem on their end, but it's still taking a while.
                                Jun 28 (1 day ago)
                                to me
                                Thank you for the confirmation. I will coordinate this to our internal team to continue the investigation. We will provide updates as soon as we finished the investigation. We thank you for your patience and understanding.
                                Regards,
                                Christian Dale
                                Actions on Google Support Team
                                  Russ @Russ
                                  @Alain-Coderre, fyi, this is the latest email from Google from 3 days ago. I'm still waiting for a solution.
                                  We apologize if you were inconvenienced by the delay in helping with your issue. We understand the issue you've been experiencing hasn't been resolved. We want you to know we’re working it. You’ll get updates from us on the status of the issue until it’s resolved.
                                  Note: This is a follow-up email. We require no action on your end unless you have any feedback or a follow-up question.
                                  We thank you for your patience and understanding. Regards, Christian Dale Actions on Google Support Team
                                  Regards,
                                  Christian Dale
                                    @Alain-Coderre, I finally got my TRIGGERcmd Alexa skill approved for French, in case that helps.
                                    Google just keeps giving me the same apology for the delay (same as I'm giving you basically), so I'm still on hold with getting Google Assistant to work with any other languages. Sorry about this. I could probably get it working if I just started from scratch, so I'm thinking about making a separate Google Assistant action for French. I hate to do that, but at this point I don't know what else to do.
                                      @russ Thanks for the update!
                                      • N Offline
                                        nick beau
                                        Any news for this post?
                                          Russ @nick beau
                                          @nick-beau,
                                          At this point if you want to run commands by speaking French, I recommend using Alexa.
                                          Google acknowledges their problem, but they don't seem to know how to fix it, so I don't have an ETA on French language Google Assistant support.
                                            @Alain-Coderre and @nick-beau, fyi, Google seems to have corrected whatever was wrong because I tried again recently and I didn't have that problem. I was able to submit both French and German for approval. They both got rejected, but I think I corrected the problems they identified, and I resubmitted. I'm crossing my fingers. Hopefully we'll have German and French working soon.
