    Command format on Raspi
    32 Posts 3 Posters 16.6k Views
      Russ @tuicemen
      • tuicemenT Offline
        tuicemen @Russ
        @russ Ya seen that And fixed it
        • tuicemenT Offline
          tuicemen @Steve Porter
          @steve-porter here is the script : X10.sh
          you can test in in the command line by typing sh X10.sh i6 on
          to turn your fan off simply change the on to off
          • tuicemenT Offline
            @steve-porter, I brushed up on Mochad, reading from early posts made by the original developer here https://forums.x10.com/index.php?topic=22045.0
            It seems it is possible to send RF as well as PLC and even dim.
            though it seems the dimming function was a bit clunky and depended on the age of the Lamp modules.
            The current script (I provided) will do on/off for all 256 X10 addresses for PLC only if you wish RF, the script could be modified to handle it easy enough. Your commands.json lines would needed to be edited with an additional parameter.
            Dimming functions (not currently available with TRIGGER) would be a little more complicated and depending on how Alexa sends the dim may need some conversion.
            • Steve PorterS Offline
              Steve Porter
              You guys ROCK! Thanks for your guidance for an old 80's c programmer (I'm 63 and still learning *-).....)
              K, so I got all my desktop commands into the Raspi .json file. Had to delete my desktop and Raspi from Trig website, then reinstall the Raspi. K, so now commands half way work. Funny thing, Alexa can turn things on , but not off. Hmmmm.....Really just for the paper trail.....just was wondering why, Hmmmmm?
              K, so I'll work on the script route, sounds like the best way to go....
              Steve PorterS 1 Reply Last reply Reply Quote 0
                Steve Porter @Steve Porter
                @steve-porter Just realized that "Alexa, Turn off living Room Fan" also turns the fan ON......another Hmmmmmm.....
                • tuicemenT Offline
                  @steve-porter you only have a year on me I'm still learning too.
                  I find I have to go through my TRIGGER calls and scripts a couple of times to catch my typos. I seem to have more of them lately 😞
                  The Script route really is the best route.
                  I've read several posts on other Home Automation sites complaining about mochad not working correctly for them. It was one reason I chose not to use that Home Automation software.
                  Mochad was originally created for the North American market and it seems like that maybe why some users have problems though I think it is mainly the RF side of it.
                  Are you using mochad as a addon for another Home Automation software?
                  What X10 hardware are you interfaceing with?
                    Steve Porter @tuicemen
                    @tuicemen I'm mostly now using smart plugs and light bulbs via WiFi but still have a bunch of X10 stuff. My pool light and waterfall both have 220v X10 modules, and the smart plugs won't work with fan motors. And for my house ceiling fans I installed X10 "relay" switches cause they're way cheaper than the smart switches that would work.
                    I moved all the X10 stuff from my Windows Desktop to the Raspi. Mochad wouldn't compile without a bunch of errors, which is why I modified it. The version I started with was mochad-0.1.17. I've heard rumblings of a mochad-0.1.19 version floating around somewhere, so I'm bumping this one to mochad-0.1.21 just to be sure. Mochad recognized my X10 CM15a with no problem. That's the same hardware I was using with my Windows installation for years.
                    I'm going to be setting up the script stuff you and Russ pointed my towards today.
                    Cheers
                    (P.S: I'm in California, what region are you?)
                    • tuicemenT Offline
                      @steve-porter I'm in Ontario Canada.
                      My setup is still mostly x10 though I have wemo, zwave, sonoff modules (WiFi), mylight (rf & wifi), Broadlink RM (for IR and some RF ) I've integrated most of my setup with HomeGenie so I can control it all from anywhere, schedule things and view status of things and my cameras. I move my stuff from windows to the PI mainly due to my off grid place so I could reduce power consumption of a PC Running.
                      I actually moded a CM15A so a PI zero W fits inside.
                      https://forums.x10.com/index.php?topic=30322.0
                      I did this mod to 3 different CM15As all are running HomeGenie.
                      One I added a hat to give me extra USB ports and I'm thinking of upgrading that one pi to the ZeroW2.
                        @tuicemen Oh, SWEET! 😎 So sounds as if this was a consulting gig for someone else? Very nice!
                        • tuicemenT Offline
                          @steve-porter said in Command format on Raspi:
                          No, not really. I did create a CM15A Pi combo for the new owners of X10 (Authinix) mainly to show the CM15A could be upgraded as a Pro option to their limited WiFi Module(WM100).
                          The other two were for myself. I do know of a few others that created these combos for their CM15As based of my shared info.
                            @tuicemen Got it all working tonight. YAY! Thanks again guys. Just to get it all in one place, here's what works for me:
                            /root/.TRIGGERcmdData/commands.json
                            {"trigger":"Living Room Fan","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"Living Room Fan","allowParams": "true"},
                            (duplicated for each X10 house unit, i.e. i6, i5, etc.)
                            Script:
                            echo "pl $1 $2" | nc -w 1 localhost 1099
                            echo "sent powerline command $1 $2 to mochad"
                            Even with you guys' help this was a bit of a pain. This really should all be put into a simple install guide. But, it works great!
                            Cheers!
                            Steve PorterS 2 Replies Last reply Reply Quote 1
                              @steve-porter Oops,
                              "home/pi/scripts/X10.sh"
                              • tuicemenT Offline
                                @steve-porter glad to see you have it all setup and working.
                                setup is a bit of a pain for new users especially with a large number of devices possible in a X10 setup.
                                A setup wizard sure would help even for me just adding one new device once in a while.
                                  @steve-porter Actually, I just noticed in my example .json command I left a comma in at the end of the line. That'll be a gotcha. The LAST command line in that file can not have a comma, it won't tell you that, it'll just not update the .json file.
                                  • tuicemenT Offline
                                    @steve-porter yep that will mess things up. I remember reading another post about that so that isn't something that you alone have experienced. I found a couple times the file didn't update for me for different errors in command lines.
                                    I've gotten into the habit of double checking if it saves.
