<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Command format on Raspi]]></title><description><![CDATA[<p dir="auto">Re: <a href="/forum/topic/12/raspberry-pi-setup">Raspberry Pi setup</a></p>
<p dir="auto">Hi, I've been running TriggerCMD on my Windows desktop for a couple of years. I'm working on getting it running on Raspi 4, with GUI. I've successfully installed, and see the Raspi in "My Computers" and the 4 default commands.</p>
<p dir="auto">A few questions to help clarify things for me:</p>
<ol>
<li>
<p dir="auto">Does TriggerCMD find and use mocad? I have that installed and running but not sure TX is working. I had to change a bunch of variable declarations and definitions in the source code to get it to compile OK.</p>
</li>
<li>
<p dir="auto">Should I have an Icon in the RasberryPI tool bar?</p>
</li>
<li>
<p dir="auto">I don't understand the command formatting. How do I get this:<br />
"C:\Program Files (x86)\Common Files\X10\Common\ahcmd.exe" sendplc I6 on</p>
</li>
</ol>
<p dir="auto">to this format?<br />
{"trigger":"Reboot","command":"shutdown -r","ground":"background","voice":"reboot","allowParams": "false"},</p>
<p dir="auto">How are these fields defined?</p>
<p dir="auto">Steve</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1927/command-format-on-raspi</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 21:08:57 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1927.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jan 2022 22:29:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Command format on Raspi on Mon, 31 Jan 2022 11:20:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> yep that will mess things up. I remember reading another post about that so that isn't something that you alone have experienced. I found a couple times the file didn't update for me for different errors in command lines.<br />
I've gotten into the habit of double checking if it saves.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5482</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5482</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Mon, 31 Jan 2022 11:20:16 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sun, 30 Jan 2022 23:52:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> Actually, I just noticed in my example .json command I left a comma in at the end of the line. That'll be a gotcha. The LAST command line in that file can not have a comma, it won't tell you that, it'll just not update the .json file.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5473</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5473</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Sun, 30 Jan 2022 23:52:06 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sun, 30 Jan 2022 12:22:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> glad to see you have it all setup and working.<br />
setup is a bit of a pain for new users especially with a large number of devices possible in a X10 setup.<br />
A setup wizard sure would help even for me just adding one new device once in a while.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5463</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5463</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 30 Jan 2022 12:22:28 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sun, 30 Jan 2022 06:10:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> Oops,<br />
"home/pi/scripts/X10.sh"</p>
]]></description><link>https://www.triggercmd.com/forum/post/5462</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5462</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Sun, 30 Jan 2022 06:10:10 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sun, 30 Jan 2022 04:30:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> Got it all working tonight. YAY! Thanks again guys. Just to get it all in one place, here's what works for me:</p>
<p dir="auto">/root/.TRIGGERcmdData/commands.json<br />
[<br />
{"trigger":"Living Room Fan","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"Living Room Fan","allowParams": "true"},<br />
]</p>
<p dir="auto">(duplicated for each X10 house unit, i.e. i6, i5, etc.)</p>
<p dir="auto">Script:<br />
"/home/pi/scripts/X10.sh i6"</p>
<p dir="auto">echo "pl $1 $2" | nc -w 1 localhost 1099<br />
echo "sent powerline command $1 $2 to mochad"</p>
<p dir="auto">Even with you guys' help this was a bit of a pain. This really should all be put into a simple install guide. But, it works great!</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://www.triggercmd.com/forum/post/5461</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5461</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Sun, 30 Jan 2022 04:30:05 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sat, 29 Jan 2022 22:13:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> said in <a href="/forum/post/5458">Command format on Raspi</a>:</p>
<blockquote>
<p dir="auto">Oh, SWEET! <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/emoji-one/1f60e.png?v=6297cc46437" class="not-responsive emoji emoji-emoji-one emoji--smiling_face_with_sunglasses" style="height:23px;width:auto;vertical-align:middle" title="8-)" alt="😎" />  So sounds as if this was a consulting gig for someone else? Very nice!</p>
</blockquote>
<p dir="auto">No, not really. I did create a CM15A Pi combo for the new owners of X10 (Authinix) mainly to show the CM15A could be upgraded as a Pro option to their limited WiFi Module(WM100).<br />
The other two were for myself. I do know of a few others that created these combos for their CM15As based of my shared info.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5459</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5459</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sat, 29 Jan 2022 22:13:23 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sat, 29 Jan 2022 21:57:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> Oh, SWEET! <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/emoji-one/1f60e.png?v=6297cc46437" class="not-responsive emoji emoji-emoji-one emoji--smiling_face_with_sunglasses" style="height:23px;width:auto;vertical-align:middle" title="8-)" alt="😎" />  So sounds as if this was a consulting gig for someone else? Very nice!</p>
]]></description><link>https://www.triggercmd.com/forum/post/5458</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5458</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Sat, 29 Jan 2022 21:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sat, 29 Jan 2022 21:27:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> I'm in Ontario Canada.<br />
My setup is still mostly x10 though I have wemo, zwave, sonoff modules (WiFi), mylight (rf &amp; wifi), Broadlink RM (for IR and some RF ) I've integrated most of my setup with HomeGenie so I can control it all from anywhere, schedule things and view status of things and my cameras. I move my stuff from windows to the PI mainly due to my off grid place so I could reduce power consumption of a PC Running.<br />
I actually moded a CM15A so a PI zero W fits inside.<br />
<a href="https://forums.x10.com/index.php?topic=30322.0" rel="nofollow ugc">https://forums.x10.com/index.php?topic=30322.0</a><br />
I did this mod to 3 different CM15As all are running HomeGenie.<br />
One I added a hat to give me extra USB ports and I'm thinking of upgrading that one pi to the ZeroW2.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5456</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5456</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sat, 29 Jan 2022 21:27:07 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Sat, 29 Jan 2022 19:56:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> I'm mostly now using smart plugs and light bulbs via WiFi but still have a bunch of X10 stuff. My pool light and waterfall both have 220v X10 modules, and the smart plugs won't work with fan motors. And for my house ceiling fans I installed X10 "relay" switches cause they're way cheaper than the smart switches that would work.</p>
<p dir="auto">I moved all the X10 stuff from my Windows Desktop to the Raspi. Mochad wouldn't compile without a bunch of errors, which is why I modified it. The version I started with was mochad-0.1.17. I've heard rumblings of a mochad-0.1.19 version floating around somewhere, so I'm bumping this one to mochad-0.1.21 just to be sure. Mochad recognized my X10 CM15a with no problem. That's the same hardware I was using with my Windows installation for years.</p>
<p dir="auto">I'm going to be setting up the script stuff you and Russ pointed my towards today.</p>
<p dir="auto">Cheers</p>
<p dir="auto">(P.S: I'm in California, what region are you?)</p>
]]></description><link>https://www.triggercmd.com/forum/post/5452</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5452</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Sat, 29 Jan 2022 19:56:27 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Thu, 27 Jan 2022 13:06:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> you only have a year on me I'm still learning too.<br />
I find I have to go through my TRIGGER calls and scripts a couple of times to catch my typos. I seem to have more of them lately <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /><br />
The Script route really is the best route.<br />
I've read several posts on other Home Automation sites complaining about mochad not working correctly for them. It was one reason I chose not to use that Home Automation software.<br />
Mochad was originally created for the North American market and it seems like that maybe why some users have problems though I think it is mainly the RF side of it.<br />
Are you using mochad as a addon for another Home Automation software?<br />
What X10 hardware are you interfaceing with?</p>
]]></description><link>https://www.triggercmd.com/forum/post/5425</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5425</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Thu, 27 Jan 2022 13:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Thu, 27 Jan 2022 10:55:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> Just realized that "Alexa, Turn off living Room Fan" also turns the fan ON......another Hmmmmmm.....</p>
]]></description><link>https://www.triggercmd.com/forum/post/5418</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5418</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Thu, 27 Jan 2022 10:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Thu, 27 Jan 2022 10:48:49 GMT]]></title><description><![CDATA[<p dir="auto">You guys ROCK! Thanks for your guidance for an old 80's c programmer (I'm 63 and still learning *-).....)</p>
<p dir="auto">K, so I got all my desktop commands into the Raspi .json file. Had to delete my desktop and Raspi from Trig website, then reinstall the Raspi. K, so now commands half way work. Funny thing, Alexa can turn things on , but not off. Hmmmm.....Really just for the paper trail.....just was wondering why, Hmmmmm?</p>
<p dir="auto">K, so I'll work on the script route, sounds like the best way to go....</p>
]]></description><link>https://www.triggercmd.com/forum/post/5417</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5417</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Thu, 27 Jan 2022 10:48:49 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Wed, 26 Jan 2022 18:11:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a>, I brushed up on Mochad, reading  from early posts made by the original developer here <a href="https://forums.x10.com/index.php?topic=22045.0" rel="nofollow ugc">https://forums.x10.com/index.php?topic=22045.0</a><br />
It seems it is possible to send RF as well as PLC and even dim.<br />
though it seems the dimming function was a bit clunky and depended on the age of the Lamp modules.<br />
The current script (I provided) will do on/off for all 256 X10 addresses for PLC only if you wish RF, the script could be modified to handle it easy enough. Your commands.json lines would needed to be edited with an additional parameter.<br />
Dimming functions (not currently available with TRIGGER) would be a little more complicated and depending on how Alexa sends the dim may need some conversion.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5408</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5408</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 26 Jan 2022 18:11:20 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Wed, 26 Jan 2022 13:46:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a>  here is the script : <a href="/forum/assets/uploads/files/1643204603843-x10.sh">X10.sh</a><br />
you can test in in the command line by typing  <strong>sh <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a> i6 on</strong><br />
to turn your fan off simply change the on  to off</p>
]]></description><link>https://www.triggercmd.com/forum/post/5399</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5399</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 26 Jan 2022 13:46:20 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Wed, 26 Jan 2022 13:35:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> Ya seen that And fixed it</p>
]]></description><link>https://www.triggercmd.com/forum/post/5398</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5398</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 26 Jan 2022 13:35:44 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Wed, 26 Jan 2022 13:40:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> said in <a href="/forum/post/5387">Command format on Raspi</a>:</p>
<blockquote>
<p dir="auto">I would really like to be able to send the variables [i6 on], or [i6 off] to the same trigger. In the TriggerCMD web interface you can trigger with parameters, but I just don't see how to get those parameters into the trigger command string.</p>
</blockquote>
<p dir="auto">you would only need one line in your commands.json file per X10 address<br />
your line would be this</p>
<pre><code>{"trigger":"Living Room Fan","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"Living Room Fan","allowParams": "true"
<p dir="auto">To turn the living room fan on you'd say "Alexa turn On Living Room Fan" or "Alexa Living Room Fan On"</p>
<p dir="auto">To turn the living room fan off you'd say "Alexa turn Off Living Room Fan" or "Alexa Living Room Fan Off"</p>
<p dir="auto">Alexa adds the condition on or off to the end of your request thats why a script is needed in your case so that the on/off condition gets place in the correct location.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5396</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5396</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 26 Jan 2022 13:40:43 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Wed, 26 Jan 2022 13:33:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a>, that should work fine.</p>
<p dir="auto">All parameters get appended to the end of the command you put in the <strong>command</strong> field.</p>
<p dir="auto">If you need to embedded parameters in the middle of your command, you'll need to use a script, and refer to the positional parameters as $1 and $2 inside the script.</p>
<p dir="auto">Also if you need to put quotes in your command (in commands.json), you'll need to escape them with a backslash like this:</p>
<pre><code>\"
<p dir="auto">That way the json parser won't think the quotes are part of the json field start/end.  The GUI editor handles that for you, so if you're building a command for a Raspberry Pi you could copy paste the json from a Windows computer.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5393</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5393</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 26 Jan 2022 13:33:04 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Wed, 26 Jan 2022 02:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> Thank you for your replies, I appreciated it very much. Creating the shell script would shorten the amount of text in the commands.json triggers. It apprears that I would still need a trigger for each x10 unit on, x10 unit off.</p>
<p dir="auto">Something like this:<br />
{"trigger":"Living Room Fan On","command":"echo "pl $1 $2" | nc -w 1 localhost 1099","ground":"background","voice":"Living Room Fan Off","allowParams": "true"}</p>
<p dir="auto">and be able to pass the i6, on. (just my attempt at a guess, this doesn't work)</p>
]]></description><link>https://www.triggercmd.com/forum/post/5387</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5387</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Wed, 26 Jan 2022 02:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Tue, 25 Jan 2022 17:57:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> said in <a href="/forum/post/5369">Command format on Raspi</a>:</p>
<blockquote>
<p dir="auto">I've never worked with scripts in linux, but I have edited the commands.json file.......</p>
</blockquote>
<p dir="auto">Creating a script is very easy I'll walk you through this simple one.<br />
open the text editor nano at the prompt type</p>
<li>sudo nano <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a></li>
<li>in the window that opens paste the script contents from my previous post or type in the lines.</li>
<li>hit the ctrl x keys to exit</li>
<li>you'll get a prompt to save press y for yes</li>
<li>next you'll get the confirmation of the file name press enter if it is OK</li>
<li>now you need to make the file executable  type chmod +x <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a></li>
<li>to test type sh <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a> i6 on</li>
<li>sh <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a> i6 off should turn off the module</li>
]]></description><link>https://www.triggercmd.com/forum/post/5382</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5382</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Tue, 25 Jan 2022 17:57:38 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Tue, 25 Jan 2022 17:07:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> just quickly put together a multi use script for mochad called <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a></p>
<pre><code>#!bin/bash
echo "pl $1 $2" | nc localhost 1099
echo "sent powerline command $1 $2 to Mochad"
<p dir="auto">If your stumped on how to create this I can upload the file.<br />
your line in the commands.json file would look like this for house code i unit code 6:</p>
<pre><code>{"trigger":"i6","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"six","allowParams":"true"},
<p dir="auto">Note: this would require your <a href="http://X10.sh" rel="nofollow ugc">X10.sh</a> script to be in the home/pi/scripts folder to turn on or off a different module you simply add another line to the commands.json file changing the i6 to the address you wished and the voice to something else.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5381</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5381</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Tue, 25 Jan 2022 17:07:33 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Tue, 25 Jan 2022 16:34:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/steve-porter" aria-label="Profile: steve-porter">@<bdi>steve-porter</bdi></a> , I'm new to TRIGGERcmd but not X10 or scripts<br />
I played with mochad on a Raspberry pi a bit but it never seemed stable for me.<br />
I use HomeGenie (HG) now with X10 but I believe you could do something similar to what I did with <a href="https://www.triggercmd.com/forum/topic/1941/homegenie-x10-control-with-single-bash-script">x10 and HG</a> with a mochad script.<br />
You could create 1 script that would handle all your X10 devices On &amp; Off I can't remember if mochad did diming but if so the script could allow that as well.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5380</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5380</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Tue, 25 Jan 2022 16:34:02 GMT</pubDate></item><item><title><![CDATA[Reply to Command format on Raspi on Tue, 25 Jan 2022 05:21:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> Hi Russ, just spent a week debugging mochad on Linux/Raspi. It now works sending to X10 perfectly, using the above command line example:<br />
"echo "pl i6 on" | nc -w 1 localhost 1099</p>
<p dir="auto">I've never worked with scripts in linux, but I have edited the commands.json file and have a couple of commands working and showing up in the web interface, and they work.</p>
<p dir="auto">Right now one to turn on a fan, a separate one to turn that fan off. So I added a new one, changing "allowParams": "false" to "true". So now the Parameters button is there. How do I format the command in commands.json to pass the "on"/"off" param to this:<br />
{"trigger":"Living Room Fan On","command":"echo "pl i6 on" | nc -w 1 localhost 1099","ground":"background","voice":"Living Room Fan On","allowParams": "true"} ?</p>
<p dir="auto">I tried putting [param] in a few ways but haven't found the correct format.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5369</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5369</guid><dc:creator><![CDATA[Steve Porter]]></dc:creator><pubDate>Tue, 25 Jan 2022 05:21:20 GMT</pubDate></item></channel></rss>
