    Command format on Raspi
    32 Posts 3 Posters 15.6k Views
    • tuicemenT Offline
      tuicemen @Steve Porter
      @steve-porter you only have a year on me I'm still learning too.
      I find I have to go through my TRIGGER calls and scripts a couple of times to catch my typos. I seem to have more of them lately 😞
      The Script route really is the best route.
      I've read several posts on other Home Automation sites complaining about mochad not working correctly for them. It was one reason I chose not to use that Home Automation software.
      Mochad was originally created for the North American market and it seems like that maybe why some users have problems though I think it is mainly the RF side of it.
      Are you using mochad as a addon for another Home Automation software?
      What X10 hardware are you interfaceing with?
      Steve PorterS 1 Reply Last reply Reply Quote 0
      • Steve PorterS Offline
        Steve Porter @tuicemen
        @tuicemen I'm mostly now using smart plugs and light bulbs via WiFi but still have a bunch of X10 stuff. My pool light and waterfall both have 220v X10 modules, and the smart plugs won't work with fan motors. And for my house ceiling fans I installed X10 "relay" switches cause they're way cheaper than the smart switches that would work.
        I moved all the X10 stuff from my Windows Desktop to the Raspi. Mochad wouldn't compile without a bunch of errors, which is why I modified it. The version I started with was mochad-0.1.17. I've heard rumblings of a mochad-0.1.19 version floating around somewhere, so I'm bumping this one to mochad-0.1.21 just to be sure. Mochad recognized my X10 CM15a with no problem. That's the same hardware I was using with my Windows installation for years.
        I'm going to be setting up the script stuff you and Russ pointed my towards today.
        Cheers
        (P.S: I'm in California, what region are you?)
        • tuicemenT Offline
          @steve-porter I'm in Ontario Canada.
          My setup is still mostly x10 though I have wemo, zwave, sonoff modules (WiFi), mylight (rf & wifi), Broadlink RM (for IR and some RF ) I've integrated most of my setup with HomeGenie so I can control it all from anywhere, schedule things and view status of things and my cameras. I move my stuff from windows to the PI mainly due to my off grid place so I could reduce power consumption of a PC Running.
          I actually moded a CM15A so a PI zero W fits inside.
          https://forums.x10.com/index.php?topic=30322.0
          I did this mod to 3 different CM15As all are running HomeGenie.
          One I added a hat to give me extra USB ports and I'm thinking of upgrading that one pi to the ZeroW2.
            @tuicemen Oh, SWEET! 😎 So sounds as if this was a consulting gig for someone else? Very nice!
            • tuicemenT Offline
              @steve-porter said in Command format on Raspi:
              No, not really. I did create a CM15A Pi combo for the new owners of X10 (Authinix) mainly to show the CM15A could be upgraded as a Pro option to their limited WiFi Module(WM100).
              The other two were for myself. I do know of a few others that created these combos for their CM15As based of my shared info.
                @tuicemen Got it all working tonight. YAY! Thanks again guys. Just to get it all in one place, here's what works for me:
                /root/.TRIGGERcmdData/commands.json
                {"trigger":"Living Room Fan","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"Living Room Fan","allowParams": "true"},
                (duplicated for each X10 house unit, i.e. i6, i5, etc.)
                Script:
                echo "pl $1 $2" | nc -w 1 localhost 1099
                echo "sent powerline command $1 $2 to mochad"
                Even with you guys' help this was a bit of a pain. This really should all be put into a simple install guide. But, it works great!
                Cheers!
                Steve PorterS 2 Replies Last reply Reply Quote 1
                  Steve Porter @Steve Porter
                  @steve-porter Oops,
                  "home/pi/scripts/X10.sh"
                  • tuicemenT Offline
                    @steve-porter glad to see you have it all setup and working.
                    setup is a bit of a pain for new users especially with a large number of devices possible in a X10 setup.
                    A setup wizard sure would help even for me just adding one new device once in a while.
                      @steve-porter Actually, I just noticed in my example .json command I left a comma in at the end of the line. That'll be a gotcha. The LAST command line in that file can not have a comma, it won't tell you that, it'll just not update the .json file.
                      • tuicemenT Offline
                        @steve-porter yep that will mess things up. I remember reading another post about that so that isn't something that you alone have experienced. I found a couple times the file didn't update for me for different errors in command lines.
                        I've gotten into the habit of double checking if it saves.
