    Turn on a computer
    raspberry pi
    16 Posts 3 Posters 19.5k Views 2 Watching
    • Wesley CorreaW Offline
      Wesley Correa @Russ
      @Russ First thanks for feedback. see how this triggers however in the cloud appears only GNOMEtriggerIDRAC.png triggersCMD2.png
      Wesley CorreaW 1 Reply Last reply Reply Quote 0
        Wesley Correa @Wesley Correa
        @Russ I changed the IDRAC trigger the ground parameter to foreground and it appeared in the cloud ... but why the IDRAC trigger does not appear when this background
          Russ @Wesley Correa
          @Wesley-Correa, the foreground agent adds/removes/runs foreground commands, and the background agent adds/removes/runs background commands. So I think the background agent isn't running.
          To install the background agent on the Pi, you'll need to do this:
          sudo su -
          Then you can check its status like this:
            Wesley Correa @Russ
            @Russ Okay, but how to identify the output from the command if this is first or second?plano.png
              Russ @Wesley Correa
              @Wesley-Correa, to capture the output of a command, you can make the command direct "standard out" and "standard error" to a text file like this:
              yourcommand &>> /tmp/commandlog.txt
              Use a single > if you want to over-write the txt file every time instead of appending to it.
              Please explain what you mean by "first or second".
                Wesley Correa @Russ
                @Russ I say that in the trigger parameter it is like {"trigger": "idrac", "command": "/ usr / bin / idrac.sh", "ground": "foreground", "voice": "power on", " allowParams ":" false "},
                foreground appears in the cloud, but when you put the background
                  Russ @Wesley Correa
                  @Wesley-Correa, when you switch your command from foreground to background, you can't tell which agent added it just by looking at the website. I suggest adding something to your trigger name to specify background, like this:
                  {"trigger": "idrac background", "command": "/usr/bin/idrac.sh", "ground": "background", "voice": "power on", "allowParams":"false"},
                  Then use systemctl status triggercmdagent to see that the background agent added it.
                  BTW, I got rid of some extra spaces you had in your json entry that might have caused a problem.
                    Wesley Correa @Russ
                    @Russ Thank you all right now.
                      Russ @Wesley Correa
                      @Wesley-Correa, awesome. I'm glad that worked out.
                        Wesley Correa
                        Hello, I intend to create one more command, and share access. in that case I have to create another commands.json?
                        because the entries created in commands.json I cannot share
                          Russ @Wesley Correa
                          @Wesley-Correa, if you share your computer with another TRIGGERcmd user, all of the commands on that computer are shared.
                          Are you seeing the commands you created in commands.json on the website?
