    2. Wesley Correa
    Wesley CorreaW Offline
    • Posts 10
    Wesley Correa
    @Wesley Correa
    Wesley Correa Unfollow Follow
    • RE: share triggers
      Thanks for the feedback, they really are excuses I'm sorry ok. your answer is already very clear.
      Wesley CorreaW
      Wesley Correa
    • share triggers
      I have 4 events inside a trigger Is it possible to share with someone just one event that is inside the trigger?
      Wesley CorreaW
      Wesley Correa
    • RE: Turn on a computer
      Hello, I intend to create one more command, and share access. in that case I have to create another commands.json?
      because the entries created in commands.json I cannot share
      Wesley CorreaW
      Wesley Correa
    • Socket is trying
      what are these messages?
      Wesley CorreaW
      Wesley Correa
      @Russ Thank you all right now.
      Wesley CorreaW
      Wesley Correa
      @Russ I say that in the trigger parameter it is like {"trigger": "idrac", "command": "/ usr / bin / idrac.sh", "ground": "foreground", "voice": "power on", " allowParams ":" false "},
      foreground appears in the cloud, but when you put the background
      Wesley CorreaW
      Wesley Correa
      @Russ Okay, but how to identify the output from the command if this is first or second?plano.png
      Wesley CorreaW
      Wesley Correa
      @Russ I changed the IDRAC trigger the ground parameter to foreground and it appeared in the cloud ... but why the IDRAC trigger does not appear when this background
      Wesley CorreaW
      Wesley Correa
      @Russ First thanks for feedback. see how this triggers however in the cloud appears only GNOMEtriggerIDRAC.png triggersCMD2.png
      Wesley CorreaW
      Wesley Correa
      @Russ I'm trying to connect a DELL R420 through IDRAC using IPMI, I created .sh to run through TRRIGERCMD I added the content to json but it doesn't appear in the cloud. the existing triggers are working normally ... just mine that add doesn't show.
      is running on raspberry py B + with Debian 10 buster.
      I bought an eco dot + I am waiting to arrive and use Alexa but I need to solve this could you help me please?
      Wesley CorreaW
      Wesley Correa
