actually i can't use my token on the pc, any help for this? i don't want lose all my triggers created
Posts made by Mark Hollis
after format my pc, i can't use trigger cmd, it say that i need to subscribe for add a new computerposted in Windows
RE: TriggerCMD down?posted in General Discussion
@Russ yes it was down for about 2 hours yesterday, now work correctly
it is down now, don't know if is related to alexa skill or to triggercmd
RE: TRIGGERcmd not starting at bootposted in General Discussion
@Russ i already have uac disable, and ticked administrator to that shortcut in that folder, but this way don't start when windows 10 start
@Russ yes exactly
the link to exe is in this folder C:\Users\Carmelo\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\TRIGGERcmdwithout checking run as administrator, triggercmd start correctly at boot
@Russ i have a startup problem on windows 10, if i set triggercmd to launch as administrator, it won't launch at window startup, you know why? thanks for help
RE: New agent version with Portuguese and Spanish translationposted in General Discussion
thanks, can you use a number version for see effectively if there is a new version to update? actually it always update even if on last version
RE: lag and slow commands from some daysposted in General Discussion
@russ hello, yesterday i haved a slowdown on a command, don't know if is related to this problem
@russ i have these slowdowns for example when i use media player home classic keys (ID) with autohotkey, seem that autohotkey start many seconds after the vocal command
can you check please? in the past there wasn't this slowdown -
@russ italy, slowdowns of more than 10 seconds
from some days i notice a retard in vocal commands,anyone is experience the same?
RE: Javascript error occurred in the main processposted in General Discussion
problem is still there actually
RE: Is possible set 2 or 3 alexa words in the same command?posted in General Discussion
@Russ nope i wanted mean more alexa words for the same command on cmdtrigger
as title, is possible do this?
