    TriggerCMD down?
    12 Posts 4 Posters 2.3k Views 1 Watching
    • OPTIMUS PЯIMΞO Offline
      OPTIMUS PЯIMΞ @Avik Basu
      @Avik-Basu I Can get my triggers to work sometimes, but most often the trigger is very delayed or not triggered at all.
      Avik BasuA 1 Reply Last reply Reply Quote 1
      • Avik BasuA Offline
        Avik Basu @OPTIMUS PЯIMΞ
        @OPTIMUS-PЯIMΞ I’m seeing the same thing as you now - periodically able to access and trigger commands, but then get an access error for several minutes. Issues started about 4 or 5 hours ago. Appears to be improving but would love to hear an update from anyone that knows why this is happening. I’ve been using TriggerCMD for about 4 months and never had an issue. Really like this program and find the support and discussion resources to be very helpful.
        OPTIMUS PЯIMΞO 2 Replies Last reply Reply Quote 0
          @Avik-Basu I have used this for years, this is a temporary issue, probably with a datacenter or such. Hopefully someone can fix it soon.
            @Avik-Basu I updated the client, could be worth a try and see if it helps, it seems to have helped me. Rightclick on the icon and choose "Update agent".
              Russ @OPTIMUS PЯIMΞ
              @OPTIMUS-PЯIMΞ , sorry guys. There was an outage this morning but it's fixed now.
              I'm not sure, but it was likely a denial of service attack.
              I figured out what was happening and patched the code so it can't happen again.
                Avik Basu @Russ
                @Russ Thanks for the fix! Do I need to update the agent or am I good to keep running as is? I’m a few hours away from the remote computers so just wondering.
                  Russ @Avik Basu
                  @Avik-Basu the agent is fine, no need to update. I patched it on the server side.
                  BTW this is where I keep track of agent version releases:
                  https://www.triggercmd.com/forum/topic/14/triggercmd-agent-versions
                  • Mark HollisM Offline
                    Mark Hollis
                    it is down now, don't know if is related to alexa skill or to triggercmd
                      Russ @Mark Hollis
                      @Mark-Hollis, it's not down and it looks like it wasn't down at all today. What problem are you seeing?
                        Mark Hollis @Russ
                        @Russ yes it was down for about 2 hours yesterday, now work correctly 🙂
